Projects uncle Charlie's hot rod model A projects
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Feb 19, 2025.
  1. ct1932ford
    ct1932ford
    I took a ride to Charlie's yesterday afternoon to see what mischief was going on. Sure enough , Slackers were slacking. Well at least two of us were.:rolleyes: IMG_7980.jpeg IMG_7983.jpeg IMG_7981.jpeg IMG_7982.jpeg
  2. rusty valley
    rusty valley
    Great project. Looks like Charle is hiding a 40 Ford coupe from us.
    bchctybob, tb33anda3rd and ct1932ford like this.
  3. Metal workers credo..."measure once, cut twice, learn to weld". ;)
    Another great thread to follow!
    Outback, dwollam, bchctybob and 3 others like this.
  4. winduptoy
    winduptoy
    ....your welding hood is on fire....
    my wife would tell me I 'have a marvelous grasp of the obvious'
    tb33anda3rd and cactus1 like this.
  5. tb33anda3rd
    tb33anda3rd
    thanks, yes his 40 is a beauty.
    thanks for following
    it has a magnifying lens in it, I wear cheaters. my eyes get a work out trying to adjust.
    winduptoy likes this.
  6. winduptoy
    winduptoy
    same here...I miss my eyesight when I was younger...and my hands shake so much now I can thread a needle with the sewing machine running...
    you are doing a remarkable fabrication job for a slacker....really enjoying seeing your approach and outcome!
    tb33anda3rd and bchctybob like this.
  7. I just landed into this today, it held my interest for obvious reasons. Nice ingenuity and execution, go Charlie go. 3A1BB6F3-657D-42A8-9B67-2492C5B084B0.jpeg
  8. tb33anda3rd
    tb33anda3rd
    thank you and thanks for following
    thank you
    good find, post a build thread when you started on it.
    osage orange and winduptoy like this.
  9. I have some pictures posted at eighty bushel build, but lots of stuff ahead of that one.
    winduptoy and tb33anda3rd like this.
  10. AVater
    AVater
    Ted,
    Got behind a bit on my reading here and want to call out my amazement with the progress and creativity you “slackers” have brought to this build. Nice work and execution! Love the faux quarter window detail in the cab.
  11. tb33anda3rd
    tb33anda3rd
    I fixed my screw up . I bent up a bead on another piece of the donor roof then bent a flange along the bottom. i welded it to the bottom of the back of the cab panel at the correct height. I will finish off the cab corners after the back is welded in. image5.jpeg image6.jpeg image4.jpeg
  12. tb33anda3rd
    tb33anda3rd
  13. tb33anda3rd
    tb33anda3rd
    had a chance to spend the day with the slacker. we fitted up the rear floor pan and the lower back panel. image10.jpeg image9.jpeg
  14. tb33anda3rd
    tb33anda3rd
    we then fit the lower panel. I had to work the outer edges with a hammer and dolly to create the start of the cab corner. image8.jpeg
  15. tb33anda3rd
    tb33anda3rd
  16. tb33anda3rd
    tb33anda3rd
    to finish the cab corners I need to make a couple filler pieces . I made a template . image2.jpeg
    Okie Pete, Deutscher, dwollam and 4 others like this.
  17. tb33anda3rd
    tb33anda3rd
    we cut the tank open to make room for a full set of gages and made a new dash panel . image1.jpeg
    Okie Pete, Deutscher, dwollam and 5 others like this.
  18. tb33anda3rd
    tb33anda3rd
    Charlie laid out where he wanted the gages and I cut the holes for him. I added a few beads and stepped the original shape into the panel. image4.jpeg image3.jpeg image2.jpeg image1.jpeg image0.jpeg
    Outback, Okie Pete, Deutscher and 9 others like this.
  19. patsurf
    patsurf
    Deutscher, Paul B and tb33anda3rd like this.
  20. tb33anda3rd
    tb33anda3rd
    thank you
  21. NoSurf
    NoSurf
    Great build thread. Great work. Thank you for posting.
    tb33anda3rd likes this.
  22. partssaloon
    partssaloon
    Fantastic posts, love reading and watching your progress
  23. Dino 64
    Dino 64
    from Virginia
    That dash is outstanding !
  24. tb33anda3rd
    tb33anda3rd
    thanks we are having fun!
    thank you, thanks for following
    thank you, Charlie has a good eye for turning junk into something cool.
  25. atch
    atch
    Outback and tb33anda3rd like this.
  26. That is really coming together. Any thoughts as to a box yet?
  27. tb33anda3rd
    tb33anda3rd
    thanks, Charlie may do the dash two tone. Despite the mis match, those are the gages Charlie scrounged and he likes.
    Outback, Deutscher and winduptoy like this.
  28. tb33anda3rd
    tb33anda3rd
    Charlie and I were talking about it today. he plans on starting with a wood deck, then add metal pickup sides to it. We also have an old 40 ford hood to make a boat tail/turtle deck style bed covero_O.
    thoughts?
  29. atch
    atch
    You guys going to find spots for temp and oil pressure gauges?
  30. tb33anda3rd
    tb33anda3rd
    it has an A four banger , when antifreeze hits the windshield it is too hot, and it has a dipstick that will have to be checked :D:cool:
