Technical 46-48 Lincoln hub caps
Discussion in 'The Hokey Ass Message Board' started by deucepickup32, Jun 17, 2025.
  1. Trying to determine if 46-48 Lincoln caps and trim rings will fit a 40 style wheel. No luck in finding dimensions. Time for something different then the basic Ford cap
  2. Tim
    Tim
    from KCMO
    I know a ford cap will fit on a Lincoln wheel so I’d say the likelihood is good that it would work going the other way as well
    trim ring should fit. The only think I can see or have seen mentioned about them being different from a ford wheel is the little metal tangs for holding the center caps on. The wheels also tend to be on the skinny side.
    I think you’re good
  3. Thanks and it’s an option. The info I have found is that they came with both 15 and 16 inch wheels so that would be a determining factor as well
    lothiandon1940 likes this.
  4. I don't think that they will work.
  5. I bought these at a swap meet a few yrs. ago. Not sure of the year, but they won't fit any Ford wheel I have around here. 20170203_074055.jpg
  6. alchemy
    alchemy
    Pretty sure those are the years that Lincoln used clips on the wheels.
  7. I am thinking that they won’t fit my wheels either. Awaiting a response from seller for a dimension. Thanks all for the responses. Back to the drawing board
  8. alchemy
    alchemy
    I think the diameter is the same but the inner lip is different shape.
  9. Tim
    Tim
    from KCMO
    You can buy and add the riveted on tabs to your ford wheels I believe they are available. Anyone have a photo of the backside of a Lincoln cap?
    deucepickup32 likes this.
  10. Tim
    Tim
    from KCMO
    Ahh, I see. Yeah I guess I’d just add the tabs. I know I saw someone here doing that not super long ago. If I see the thread I’ll share a link.
  11. fordpatina
    fordpatina
    The trim ring will fit but the lincoln zephyr hubcaps will not fit a ford wheel. Lincoln wheels have clips and ford wheels have knobs
