Hot Rods 34 coupe..Dismembered to drag coupe.
Discussion in 'The Hokey Ass Message Board' started by Kiwi Kev, Mar 12, 2024.
  1. I began adding some structure into the frame where I had cut some of the 1 inch tubing
    out for ladder bar clearance. I added a couple of drive shaft loops, now I know what shape to make the floor. There is a lot of work to do to the frame when the body comes off later. Boxing, gussets, finish welding etc. IMG_1669.jpeg IMG_1678.jpeg IMG_1681.jpeg IMG_1684.jpeg
  2. neilswheels
    neilswheels
    from England
    Great work, nice little list of parts going in this. What material did you use for the ladder bars?
    elgringo71 and 427 sleeper like this.
  3. Ladder bar material is 1” OD x .250 wall seamless tubing. Heavier wall than needed, I was gifted a few lengths of it.
  4. neilswheels
    neilswheels
    from England
    Thanks Kev
    elgringo71, 427 sleeper and mad mikey like this.
  5. IMG_1834.jpeg IMG_1838.jpeg IMG_1848.jpeg I have been spending many hours putting patch panels, new rockers etc in the lower body, pic’s to come. I also figured out how I want to mount the gauges. There is not going to be a dash board, just flat aluminum recessed firewall. Like I said earlier in this thread, nothing over engineered on this car. A piece of 2” aluminum angle will work just right. Eventually I will make a nicer version with the top shaped to match the cowl. Also I think I found a home for my Mooneyham Blowers pin. I am not sure if I will run this tach, I have a Jones cable drive I would like to run but not sure if I will be able to use it or not.
    rod1, slayer, BigRRR and 17 others like this.
  6. I would love to find a black face Eelco temperature guage if anybody has a lead on one. Also another black black face Eelco in that isn’t temp, oil pressure or amps to fill the other hole.
  7. Tim
    Tim
    from KCMO
  8. mad mikey
    mad mikey
    Simple, effective, and functional, PERFECT! Love your work Kev.:cool:
  9. These pics show the condition of the lower quarter panels, rockers and cowl sides. New metal needed everywhere. IMG_1855.jpeg IMG_1856.jpeg IMG_1694.jpeg IMG_2041.jpeg
    Upper driver side cowl had an old repair where someone had brazed up some holes and left a warped mess so I cut that out and welded in some new metal. IMG_1696.jpeg
    New rockers needed to be modified to clear the frame I am using, 35/36 highly modified swap meet special. Doors clear fine. Kind of funky but on this car funky is good.
    After many hours some satisfying progress….
    JalopyJimbo, BigRRR, cactus1 and 20 others like this.
  10. There is a lot more patching to do. It needs a new panel below the trunk, top chop needs finishing, doors need fitting and one needs a lower panel, new latches etc, etc. To keep myself motivated I sprayed on a few cans of primer to give it a different look. IMG_1858.jpeg IMG_1869.jpeg IMG_1870.jpeg
  11. brady1929
    brady1929
  12. 57tailgater
    57tailgater
    from Georgia
    Killer! Those headers are awesome! Keep up the great work!
  14. theman440
    theman440
    from Las Vegas
    How the hell did I miss this? This car is Rad!
  15. mad mikey
    mad mikey
    Looking great Kev. What a MONSTER!:cool::)
  16. ASBO
    ASBO
    from KERNOW
  17. duecesteve
    duecesteve
    That's a BIG model
    Kiwi Kev and chryslerfan55 like this.
  18. mad mikey
    mad mikey
    I could never see enough of this build!:);):cool:
  19. Super cool. Keep the updates coming.
  20. slayer
    slayer
    keep up the top notch work!
  21. ne'erdowell
    ne'erdowell
    Definitely not your average street car :eek:
    porkshop, duecesteve and Kiwi Kev like this.
  22. wrenchbender
    wrenchbender
    Kevin I knew you were building this car I had no idea you had a thread till the other day I’ve now gotten caught up on the build and you and I have the very same style and taste this winter I plan on at least mocking my ****py 34 together and yes mine is worse than yours but poor guys have poor ways lol it’s taken me 20 years to gather up enough stuff to get mine to at least roller stage so I understand your struggle the hyder mccloud car is my inspiration on my build though I love the 15 oz coupe and 554 car the hyder car was more of a working mans car compared to the others as there wasn’t fancy mag wheels on it or lots of sponsors to it and I think that is what makes it so perfect to me I do have a set of mag rear 5spokes I could put on it I probly won’t I’ll just use the good ol steel wheels of course they will cost me more in the long run mainly cause I have to buy them lol when I do get started on it I’ll try to start a thread so you can tell me what I’m doin wrong lol keep up the good work
    elgringo71, slayer, mad mikey and 5 others like this.
  23. Marty Strode
    Marty Strode
    Looks great Kev, will be simple to do the floor ! You are perhaps the most resourceful Hot Rodder that I know.
  24. mad mikey
    mad mikey
    That is great Jackson, wish I could do the same. Look forward to your build. Kevs build on this monster is by far my favorite on the HAMB. Just keeps getting better.:)
    porkshop, 427 sleeper and Just Gary like this.
  25. wrenchbender
    wrenchbender
    yes Kevin’s car is definitely top notch my **** box is another story I do have a blown Hemi to put in it but I also have a 394 olds and just not sure which one to use yet guess I’ll just mock it up with both and decide from there lol mine will be more of a strip car than a street car but who knows that can change anytime lol what’s better than driving a fuel coupe down the street
