Let's talk 1950 Buicks
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jun 16, 2025.
  1. Squablow
    Squablow
    I love that a 21 year old guy would buy that car and be excited to rebuild the straight 8. Would be very cool with the '41 "compound carburetion" dual carb setup, and a stick. Never was fond of the Dynaflow.
    A while back I photoshopped what one of these would look like converted into a 2 door sedan using Sedanette doors but keeping the current roof and rear window, and I really liked the results, I wish I still had that picture somewhere. It would be pretty simple to do, if you could find the doors and maybe the B pillars out of the fastback. A one-of-none 2 door sedan Special with a built straight 8 would be pretty cool.
  2. Roothawg
    Roothawg
  3. Roothawg
    Roothawg
    He’s not 15 anymore. We spent 2 years building it. He’s 21 now.
    Sharpone and guthriesmith like this.
  4. Damon777
    Damon777
    SS327, Roothawg and Sharpone like this.
  5. Roothawg, OT some, but just wondering if you ever got moved into the new place
    Ben
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    A simple upgrade would be a Roadmaster carburetor. Same bolt pattern, but the throttle plates are 1/4 of an inch larger in diameter.
    Roothawg likes this.
  7. Dan Hay
    Dan Hay
    A super should have a bigger motor than the special, Supers usually (depending on the year) shared the Roadmaster powertrain.
  8. NEVER in the Straight Eight era. After 1953 and the Nailhead V8, yes.
    Well, that is not entirely true . Straight eight Supers never had the Roadmaster 320 ci engine.
    In 1950 ONLY the Super had a larger engine than the Special . 1950 Super had the FIRST 263. Special had the LAST 248. 1951-1952 they both had the 263.
    Ben
    SS327, 1oldtimer and Dan Hay like this.
  9. tubman
    tubman
    Nope. The Super generally shared the smaller motor with the Special. When they did put the big engine in the small body, it was called the Century.
    Dan Hay likes this.
  10. manyolcars
    manyolcars
    probably because those cars were never considered to be traditional street driven hotrods. they were slow, sluggish and underpowered. the opposite of a hotrod
    guthriesmith likes this.
  11. Roothawg
    Roothawg
  12. guthriesmith
    guthriesmith
    Yea, there is that. :D But, at least it doesn't have a bunch of new parts on it and knowing Colby, it won't when he is done either.
    SS327 and Sharpone like this.
  13. Roothawg
    Roothawg
    Nope.
  14. Stooge
    Stooge
    Dont forget Expensive! I had the 320 (1947 engine) for my '37 coupe rebuilt a year ago and it was about $9k, but i also had the babbit rods converted to insert bearings. Factory changed to insert bearings around 48 or 49, so he might be good to go in that respect.
    When i got my car, it had no engine or trans, and i kind of decided i would go with whatever i found first with the choices being nailhead and muncie or straight 8, and i found the correct displacement, slightly newer engine a few towns over, so i went that route. Im glad i did, its something different than what im used to being around, but they are cool looking and honestly, just the size of this thing is funny enough. May not be a big crazy powerhouse, but im getting antsy inching closer to being able to start it and hear my engine run in the car.
    I have a few of the smaller engine dual carburetor intakes, i think one is cracked though and the carburetors need to be gone through.
    i am building my own intake and exhaust for my 320, maaaybe sort of regret it where its added a bunch of time, effort and money to this project, but a boy needs a hobby, and seeing 12 tubes all lined up in a row is kind of cool! Im finishing this up in the next week or so and getting it cerakoted, just getting it all cleaned up and making sure i dont need any more provisions for things
    (the exhaust was painted black but i sanded it off so it looks a little grimey) 3201.jpg 3202.jpg
  15. Sharpone
    Sharpone
  16. Ant movement on the Buick?
    Ben
    SS327 and Damon777 like this.
  17. The 4 port hole version in 1950 was only the Roadmaster and the front sheetmetal was longer. The '41 compound carburetion was the easiest upgrade unless you find and aftermarket Edmunds manifold for the smaller engines. A weird fact is the early '50 had the latch to open the hood in one of the port holes (one on either side) and a tool in a pocket on the drivers kick panel, the later '50 had hood release cables (one on each side of the underside of the dash).
  18. BJR
    BJR
    I have a 49 Super Sedanette parts car with all the parts to do this. PM if interested.
    SS327 likes this.
