Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. patsurf
    patsurf
    don't think i've seen any rigs that had down pressure by cable!
    Six Ball, SS327 and deathrowdave like this.
  2. Boneyard51
    Boneyard51
    The Double drum# 29 cable unit on the back, is just that, two high speed winches. One for the front blade, one for the rear s****er! The front blade needs eight pulleys to get the blade off the ground! I ***ure you guys you do not need down pressure on that 14 foot blade! When we hauled it , some 80 miles to the ranch, we had to take the blade and push arms off! It was all my one ton wanted hauling the two arms and all my friends two ton winch truck wanted hauling the blade! We never needed to “ push” the blade into the ground, but did have to hold it up ! The pictures really don’t do justice to this monster!
    Bones
  3. deathrowdave
    deathrowdave
    from NKy
    Used them stringin big pipe in the ground . Some had a huge weight hanging on one and a side winch one the other side to lower pipe into the ditch . I was on a job where a fool lost one on frozen ground . Layed it on its side , tossed him onto the track , spit his head open . He was ok when he returned from his week suspension .
    jet996, Six Ball, SS327 and 3 others like this.
  4. RodStRace
    RodStRace
    I watch Diesel Creek, so I have a inkling of the weights and size involved!
    Much bigger than Squatch253's stuff, although the rock crusher isn't a toy.
    Six Ball and Boneyard51 like this.
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    My ****ter-brain just had a memory.
    I've seen postings about line wrenches and their issues.
    What to do when on the road, and your tool chest is home.
    An Old buddy of mine, one day, handed me a little 6 or 8 inch pipe wrench.
    He said "This Works". He was correct,
    Don't leave home without it.
    jet996, Algoma56, vtx1800 and 3 others like this.
  6. Six Ball
    Six Ball
    from Nevada
    For sure the second one with down pressure was a modification. I don't know why. The friend who owned it brought it over the Sierras from the Sacramento Valley. It had obviously never seen a rock. The original paint underneath look new. Somewhere I have a picture of my JD 420C sitting crosswise to the 14' D9 blade. The 420 has a 6.5' Blade and is 11' in length. It is a good size for a handy homestead dozer. I used to haul it all over on the bed of my 1940 International Model D with a 16' flatbed.
  7. Wobbly
    Wobbly
    from Ireland
    Not sure if this tip has been suggested before so feel free to delete if it has. When fitting/torquing the wheel/lug nuts on your expensive wheels I apply insulation tape to the outside of the socket in such a manner that it also covers the front face of the socket adjacent to the hexagon. No more socket rash on your wheels or lug nut washers.
  8. jnaki
    jnaki
    upload_2025-6-26_6-39-35.png step 1 and 4
    Hello,
    When we started our parts bins in our dad’s old fishing boxes, we had limited space for the little nuts and bolts. Washers were a small item, as well as lock washers when needed. So, they all needed to be close by. We used to bring the fishing box over and open it up near where we were working. At the time it was handy, but took up valuable space.
    So, as the new parts began their turn to get ***embled, access to the small nuts and bolts were necessary to fit the needs. Obviously not all are the same sizes. But in our fishing tackle box. We had limited divided spaces for everything.
    We began to use our mom’s cardboard egg cartons as a receptacle for different sizes of nuts and bolts and the carton could be snapped closed for the next days work without having to scrounge around in the parts bins. Just open the egg carton and the necessary parts are there.
    But, those cardboard egg cartons had a shelf life and sometimes they did wear out and break open. Spilling all of the little parts. Not good.
    Now, the companies are using sturdy, but light weight plastic egg cartons for the eggs. There are still paper cartons, but these have double uses. Note the little egg openings from 12 to 24 when opened. When one set of 12 parts in the outer set of holes is used, the two sides can be flipped over to seal the center holes like a flip lid.
    step 3 and 4
    Jnaki
    Step three, flip one side over to lock items in place.
    Step 4 flip the top smooth lid over to lock everything in place. If you have three or more clear egg cartons, they can be stacked but, in a square, cross pattern to be more secure.
    These light weight plastic cartons can be carried anywhere in the shop and placed on a counter. The clear sides makes identifying easier than the paper cartons. If any of the original real eggs cracked and there was some spillage, make sure you wash out the holes and spray with 90 % alcohol. YRMV
    Note:
    When these clear plastic egg cartons are opened, they also make good receptacles for water color paints or oil paints for toddler paint activities. They are pretty easy to clean and the snap lid stays shut when placed on a flat counter. But, for little construction parts or car parts in a repair or rebuild, they allow capture of the parts without having to chase them all over the counter.
  9. RodStRace
    RodStRace
    Muffin tins from the thrift store are good for various project bins, too. The cheaper one-use aluminum ones if you have those around will work also.
    I saw a yoga mat in the thrift store the other day. They make a nice bench top pad for dis***embling carbs or other small, fragile stuff. The texture tends to keep stuff where you put it.
    I've got a gun cleaning mat for this too. The better ones are resistant to chemicals.
    I haven't found a good tray for various ***embly stuff that holds both the liquid and a dedicated brush, but I do have anti-seize, oil, loc-***e, grease and carb and brake cleaner a**** other sprays and cans all on a cart.
    I try to keep all the Personal Protection Equipment in one handy place, too.
  10. j hansen
    j hansen
    From the web,,,
    jet996, fauj, Deutscher and 13 others like this.
  11. brading
    brading
    For a homemade brake spring tool have a look at this. I knew Mart on here made one a while back but this looks quite easy to make.
  12. Are you talking about the pliers type thing to install the return springs? That's the only tool I can find in that section of the book. They are available cheaply around the traps, probably not worth making.
    brading likes this.
  13. brading
    brading
    That's what I was talking about
  14. RICH B
    RICH B
    Mentioned cable releases on another thread; a bicycle shop is a good source of cables for hot rods; strong, flexible, and very adaptable. I've used them for trunk & hood release, throttle, seat adjusters, etc.
    jet996, seb fontana, loudbang and 4 others like this.
  15. Fabber McGee
    Fabber McGee
    In the early 90s I built this forklift/loader for a helping hand around here on the homestead out of old pickup parts. I wanted a good view of the forks or bucket and the whole area front and back so I put the seat on the side. That made throttle linkage pretty complicated.
    What I did was get a couple long pieces of 3/8 tubing at NAPA with inverted flare fittings on the ends, like brake tubing and tied them together with an inverted flare coupling. Then slipped a piece of 1/4 inch nylon air brake tube inside that and a cable, maybe 3/32 or 1/8 inside the air brake tube.
    With that done I was able to bend the whole works to fit any place I wanted to go. To locate the housing (3/8 tube) at the pedal end I tacked a nut that fit the threads on the tubing nut to pedal bracket I built and the engine end is clamped over the outside of the steel tube to make it adjustable. I figured the cable would eventually wear through the nylon tubing in one of the bends, but in over 30 years I haven't had one problem with the throttle cable.
    With this set up, a guy could open his trunk from the front bumper, or actuate any damned thing he can dream up from any distance.
    Yellow color of the picture was from the sun filtering through forest fire smoke. I had just made the brackets to hang that telescoping mast on there and built the man basket so I could work on second story siding on my house. Around 2005. Used a 12v hydraulic pump from a pickup snow plow to raise the fork mast so I could tell it up or down from the basket without the engine running.
    jet996, j hansen, loudbang and 3 others like this.
  16. Fabber McGee
    Fabber McGee
    Oh, by the way, although my motor forker is not a hot rod, it is sort of HAMB friendly. I started with a give away 1961 International Travel-all 4 wheel drive with no engine.
  17. j hansen
    j hansen
    From the Web,,,
    Wobbly, seb fontana, fauj and 8 others like this.
  18. drtrcrV-8
    drtrcrV-8
    #2579 : I'd bet Jeff Foxworthy & Larry The Cable Guy would just LOVE this one!!! LOL!!!
    seb fontana, j hansen and TagMan like this.
  19. Six Ball
    Six Ball
    from Nevada
    I'D DO THAT! Dad Gum I bet that would work.
    chryslerfan55, j hansen and Sharpone like this.
  20. RodStRace
    RodStRace
    Better than thinkin "I don't gotta torch, let's build a fire under it!"
    Six Ball and Sharpone like this.
  21. nrgwizard
    nrgwizard
    from Minn. uSA
    Or swinging a 15+lb sledge.
    Marcus...
    chryslerfan55, jet996 and Six Ball like this.
  22. Six Ball
    Six Ball
    from Nevada
    For a totally different reason I did build a fire under my bulldozer once. There was 2 miles of road with 3 feet of snow and the crawler would barely turn over with 12v to the 6v starter. It has to turn for starting fluid to work. No power for a block heater. A little fire under the pan to thin the oil and it fired right up.
  23. Fabber McGee
    Fabber McGee
    Amazing how now days everyone is scared to death to give a diesel a little whiff of starting fluid. Used to be almost no diesel engine would start below 40 above without just a little sniff of smelling salts to wake it up.
    When we go ice fishing, or ride snowmobiles to a remote cabin and leave our pickups parked for a couple days in the cold we always carry a propane weed burner and a couple joints of 6" stove pipe with an elbow on the end. Shove the stovepipe under the pickup elbow first, weed burner in the outboard end and warm the engine for 20 minutes while we load up. Sometimes the weather has changed from 20 above going in to 30 below coming out, but the pickups always start.
    rpm56, chryslerfan55, jet996 and 3 others like this.
  24. Brendan1959
    Brendan1959
    I installed an AliExpress Magnetic scale dro on my old lathe, some small aluminium angle, some bits from my s**** bin, an old 12v plug pack. Works fine all for under $100 AUD ($60 USD)
  25. RodStRace
    RodStRace
    I'd be interested in hearing what @mamllc says about this.
    For a limited production run like shown in the video, I could see it. For your mentioned application (reliefs behind a board) I'd think a router would be quicker and easier.
  26. X-cpe
    X-cpe
    It is called cove cutting. You can usually go wider and deeper than with a router. Width is controlled by the angle of the fence board to the blade. I can't tell you what the go/no-go angle is. The fence board can be on either side of the blade so long as the far end is angled away. If the bottom end of the fence is angled away from the blade, the force of the blade will pull the workpiece away from the fence. Like the video showed, you have to make incremental cuts. A push stick or board is absolutely necessary. This is NOT a finger friendly procedure.
    chryslerfan55, Six Ball and Sharpone like this.
  27. deathrowdave
    deathrowdave
    from NKy
    “ You can usually go wider and deeper. “
    Hey wait a minute , ahh never mind
  28. lilredex
    lilredex
    Yes, but also use br*** fittings with ferrules. I hate those rubbers on transmission lines, they always give out when you are out in nowhere land.
    chryslerfan55, hammer-time and BJR like this.
  29. RodStRace
    RodStRace
    I was going to go out and set up a picture, but naw...
    When you are taking it apart to rebuild, you use baggies for the hardware, right?
    Get those magnetic trays from HF, set it close, then flip the baggie open on top. The bits stay in place and just pick up the bag when done with that part.
  30. s.e.charles
    s.e.charles
