Projects uncle Charlie's hot rod model A projects
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Feb 19, 2025.
  1. tb33anda3rd
    tb33anda3rd
    went to the slacker's to get some stuff done today. started by moving #1 ch***is out to the shed so Charlie has room to build the bed. had to get a shot of it outside. image1.jpeg
  2. tb33anda3rd
    tb33anda3rd
    once back in the shop, I s****ed out the inside of the old gas tank and removed a couple baffles for the gage clearance. image3.jpeg
    Okie Pete, Deutscher, dwollam and 2 others like this.
  3. tb33anda3rd
    tb33anda3rd
    Outback, Okie Pete, TFoch and 5 others like this.
  4. tb33anda3rd
    tb33anda3rd
    image6.jpeg image7.jpeg image8.jpeg then made sure everything clears. Charlie will take it back out and paint and wire everything. we plan on replacing the tek screws with nut-serts
    Okie Pete, TFoch, Deutscher and 6 others like this.
  5. tb33anda3rd
    tb33anda3rd
    after lunch we decided to get the roof started. I started by bending the back panel and forming it around the roof rib. image0.jpeg image1.jpeg
  6. tb33anda3rd
    tb33anda3rd
    trimmed the roof panel to fit as good as I could, it was actually about three inches shorter than I wanted but this was the biggest piece left of the salvaged '65 suburban roof. I welded it across the back and nailed it to the windshield header across the front. I folded the sides over the side rail. image2.jpeg
    Okie Pete, TFoch, Deutscher and 9 others like this.
  7. tb33anda3rd
    tb33anda3rd
    next for the roof is to address the front gap and then make side pieces/rain gutters over the doors. image8.jpeg
    Okie Pete, TFoch, ct1932ford and 2 others like this.
  8. tb33anda3rd
    tb33anda3rd
  9. ct1932ford
    ct1932ford
    Looking great! Love the dash treatment.:cool:
    tb33anda3rd likes this.
  10. tb33anda3rd
    tb33anda3rd
    thanks, what color two tone for the dash, Charlie wants dark brown outer edge, like most of the interior eventually and something lighter [?] on the "inset"
  11. Grumpy ole A
    Grumpy ole A
    I don’t know how I missed this build. This is a very interesting build. Excellent work, keep it up. Thanks
  12. ct1932ford
    ct1932ford
    If the interior is going to be brown, then dark brown outer edge with cream inset.
    If I were doing it the interior would be black and Wimbledon white inset .
  13. tb33anda3rd
    tb33anda3rd
    thanks, we keep picking at it a little every week.
    Deutscher likes this.
  14. tb33anda3rd
    tb33anda3rd
    Charlie likes the brown but I will suggest the black and white.
  15. ct1932ford
    ct1932ford
    Brown and cream would be okay. Maybe with gold body!
  16. tb33anda3rd
    tb33anda3rd
    Charlie says no to black and white.
    ct1932ford likes this.
  17. Grumpy ole A
    Grumpy ole A
    I love this build. Putting something together that never existed like it is. With the dark brown and cream dash, then the exterior could a kind of cream with a brown belt.
  18. ct1932ford
    ct1932ford
    Spent some time at Uncle Charlie's this morning. Checking out some alignment issues. Once we figured that out we went into the cooler house and shot the s&;:t for awhile.:eek::cool: IMG_8491.jpeg IMG_8493.jpeg IMG_8492.jpeg
    Okie Pete, TFoch, Deutscher and 7 others like this.
  19. tb33anda3rd
    tb33anda3rd
    I stopped at Charlies to help him square up the bed. we made some head way.
    Okie Pete, TFoch, Deutscher and 5 others like this.
  20. This is a great shot. The proportions for the box look about right. Fun, fun, fun.
  21. Grumpy ole A
    Grumpy ole A
  22. deathrowdave
    deathrowdave
    from NKy
    It doesn’t get any better !
  23. Deutscher
    Deutscher
    from Germany
    What a great build, thanks for sharing it with us.
    Greetings Harald
  24. tb33anda3rd
    tb33anda3rd
    thanks, Charlie is having fun!
    thanks
    glad you like it.
    thank you and greetings! Charlie was stationed in Germany in the 50's
    ct1932ford and Deutscher like this.
  25. tb33anda3rd
    tb33anda3rd
    Charlie has been busy, he primed the weld spots and bed then started mounting the fuel tank. image0.jpeg
    Okie Pete, TFoch, dwollam and 5 others like this.
  26. tb33anda3rd
    tb33anda3rd
    Deutscher, Okie Pete, TFoch and 5 others like this.
  27. tb33anda3rd
    tb33anda3rd
    I am not sure how he plans to paint it but he took the dash panel out, removed the gages and prepped it for paint. image1.jpeg
    Deutscher, Okie Pete, TFoch and 6 others like this.
  28. tb33anda3rd
    tb33anda3rd
    Charlie was given some foam by a friend and I brought over some old material I took out of a 1948 suburban that should work to make a seat. image0.jpeg image1.jpeg
    Deutscher, Okie Pete, TFoch and 3 others like this.
  29. tb33anda3rd
    tb33anda3rd
    Deutscher, Okie Pete, TFoch and 4 others like this.
  30. tb33anda3rd
    tb33anda3rd
    worked on the cab corners for the slacker today. image7.jpeg image6.jpeg image5.jpeg image4.jpeg
