Technical 37 Plymouth Truck electrical question (not stock)
Discussion in 'The Hokey Ass Message Board' started by johnny jackson, Jun 2, 2025.
  1. johnny jackson
    johnny jackson
    RodStRace, thanks for the correction on the Tach wire. I labeled it wrong.
  2. johnny jackson
    johnny jackson
    Also, thanks for your information. I do believe i got it figured out. I bench tested the ignition switch and found that Speedway instructions had me wire it wrong. I believe that mistake caused it to short. Waiting for the new fuse box terminals to arrive.
    pprather likes this.
  3. RodStRace
    RodStRace
    Glad it seems to be diagnosed, hope the repair gets it all going.
    I don't know how well the interaction with the phone techs went, but once this is resolved you might want to post up a correction and your ignition part # so others will not run into this.
    Sorry if I came across as brusque, it's difficult to diagnose stuff without eyes on the problem and not knowing what parts are involved.
  4. johnny jackson
    johnny jackson
    Thank brother, I appreciate your help. Yep, I will post something that details the solution. The Speedway motors instructions for a GM Column ignition switch has the "Starter" pin and the "Ignition" pin reversed (or backwards). I bench tested the switch I found out which pins do what. Then I was able to move the pins in the harness connector to make it work. Now I am waiting on the blow ATO fuse terminals, then I will continue the wiring.
    RodStRace and pprather like this.
