Technical Buick nailhead spark plug wire covers
Discussion in 'The Hokey Ass Message Board' started by deucepickup32, Jun 20, 2025.
  1. Managed to find a pair plus a single on marketplace. Going on my Vicky with a 401. Does anyone have pics of how they install as in where to secure the brackets that I will make.
    Bandit Billy likes this.
  2. BJR
    BJR
    Isn't there a threaded hole or head bolt in line with the holes in the covers?
  3. swifty
    swifty
    I made my own brackets for the finned Weiand covers on my 401 but you can buy them from Russ Martin at Centerville. Have a look at his website. Made mine out of a bit of steel bar with a Nutsert
    @BJR I think that only applies to the early engines which had the plug wire covers as standard
    deucepickup32 likes this.
  4. RICK R 44
    RICK R 44
    On my 322 there are threaded holes in the head. Install studs in these holes. They line up with the holes in the covers. These holes go into the water jackets. If the 401 is the same there will be bolts in the holes to prevent coolant from leaking. Remove the bolts and install the studs.
  5. Forgot to say that it is a 401
    swifty likes this.
  6. swifty
    swifty
    You did say it was a 401 in Post#1.
  7. iafraser39
    iafraser39
    from Warmland
    I made my own brackets for my 425.
    Not a big project. The brackets fit on the head bolts.
  8. Doh..
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, Buick only used them from 1953-56, and the '53 covers differ from the '54-'56.
  10. Do you know what the difference is ?
  11. Msgr. Doug Cook
    Msgr. Doug Cook
    Check out Russ Martin, he sells a nice adapter kit to fit the early plug covers on the later Nailheads.
