Technical Need advice on radiator
Discussion in 'Traditional Hot Rods' started by Langan, Jun 9, 2025.
  1. Same ride
    Same size radiator
    Same gauge
    Same fan
    Same no shroud
    Both the copper and aluminum cooled the ride
    Different variables? .060 350 with ****py dished pistons and 64cc heads. Cheap thick gaskets
    Stock bore 500, slight mill on the head
    Timing? Don’t really know. Set both with a vacuum gauge
  2. ekimneirbo
    ekimneirbo
    from Brooks Ky
    [QUOTE="anthony myrick,] The 500 runs 185 (too dang cool) the 350 ran 215 to 220. Never boiled over[/QUOTE]
    [QUOTE="anthony myrick, ]Different variables? .060 350 with ****py dished pistons and 64cc heads. Cheap thick gaskets
    Timing? Don’t really know. Set both with a vacuum gauge[/QUOTE]
    Anthony, that's a pretty broad operating range difference for most of us...........:D:D:D:D:D
    So are you saying that the Cadillac ran 185 degrees with either radiator and the Chevy also ran the 215/220 degrees with either radiator......OR are you saying one ran 185 with one radiator and the 350 ran 215 with the other radiator? Also, what was the thermostat rated for on each engine when it ran these temps? :)
    chryslerfan55, 05snopro440 and X-cpe like this.
  3. All I’m saying was both worked.
    The caddy runs too cool in my opinion. Would rather see it in the 210 range
  4. 19Eddy30
    19Eddy30
    from VA
    Tape , Restriction to Taylor your Temp..
    Just curious have you moved the temp sender to different Location & note Temps ?
    I have mentioned that I have experiment and used up to six temp gauges all calibrated to different location locations with different temp readings
    10-25 ish average , one spot was 40 higher . I found that P S cooler then D S. My testing was on 1gen sbc & bbc , Oem blocks ,
    My aftermarket block has different cooling .
    On one of my engine Now I have been playing with Im my thinking I am running coolant threw block Front to Rear , coming from rear of intake back to radiator # 8 lines one on each side , in front T ing with
    A 1/4 ID line to Rad.
    I do not have correct test equipment I am trying to balance the temps on each cylinder at the head combustion chamber and spark plugs.
    Might be a wast of time , I do not know .
    chryslerfan55 and ekimneirbo like this.
  5. deucemac
    deucemac
    I had Br***works build me a radiator for my avatar roadster 2009. Not one problem with it ever! I have in excess of 40k trouble free miles on it and in 100° weather it runs 190°! It wasn't cheap in cost nor quality and I am very happy with it.
  6. proartguy
    proartguy
    from Sparks, NV
    Hot weather so the cooling questions start. If it is not puking coolant it is probably ok.
    My understanding of fan shrouds is all the air has to be pulled by the fan as that provides air flow for as much surface as possible, so no “high speed” holes. Walker radiators have a high fin count and may require a proper fan. Br***works typically have fewer fins for better air flow. Mine has worked great for 33 years, engine driven fan, & shroud.
    Air flow out of the engine compartment is essential. The photos of the o/p Model A look pretty much filled up.
  7. The average old engine cooling designs are not optimal. Especially the sbc. Meaning the internal design for the cooling
    But these old engines manage to survive.
    I don’t over think this stuff
    All the radiators I’ve used have worked regardless of what they’re made out of
    just put a 292 in the kids 61. Old school 4 blade fan.
    Aluminum radiator, no shroud.
    so far so good.
  8. Speedway aluminum radiator
  9. CSPIDY
    CSPIDY
    Roadkill fix
    Remove the dam hood!
    never fails!
    Okie Pete and chryslerfan55 like this.
  10. 05snopro440
    05snopro440
    Quality aluminum rads use 2 thicker cores (better flow). Cheap aluminum rads use up to 4 thinner cores (more restrictive). One advantage of aluminum is that it has a higher strength so the tubes can be larger.
    If you're trying to solve a cooling issue, get something with two 1" or thicker cores.
  11. 69fury
    69fury
    from Topeka
    Actually caused my perfectly running car (69Plymouth Fury) to start overheating. The air used to go throgh the grille and core support as the hood was sealed to the core support. Without the hood (painting it) i found the air went through the grille and over the core support. Hood back on and it was cured.
    -rick
  12. 05snopro440
    05snopro440
    chryslerfan55, Langan and ekimneirbo like this.
  13. 05snopro440
    05snopro440
    On my 46 GMC, I take the hood off when cruising on hot days. When it's around 100°F in traffic, in traffic you can see the heat going up. Since the hood has no openings, all that hot air has to go down with the hood on. It runs a bit cooler, but I find the heat up in the cap of the hood causes a bit of boiling of the fuel in the carburetor if it's too hot out which obviously causes a surge when leaving a stop light.
    Taking the hood off of a land barge versus a hot rod are two different things. Your Fury has a small grille, so it needs the hood to keep air going through the grille. A hot rod with the hood off lets the heat escape easier. Two different things.
    chryslerfan55 and 69fury like this.
    Toured Brice Thomas’s facility. Know the owner
    Very cool process.
    I like fuel efficiency.
    Excessive wear over 195?
    Hmmm. I’m not buying that at face value.
    Newer cars far out mile our older ones and run in that 210-215 range.
    For some crazy reason the vette scientists like their cars running around 220+
    But it’s kinda like oil
    believe whatever science ya like. Just use oil
    and use a radiator on non air cooled rides.
  15. Bandit Billy
    Bandit Billy
    Never trust the science. Buy what the internet says is good. Never fails. o_O
    Almostdone, Okie Pete, joel and 4 others like this.
  16. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Agreed.....with that in mind, here is something else from the internet. :D
    At what temperature does oil break down?
    "No, there is no "exact" temp where it degrades. For example, if "250" is the answer, that does not mean the oil is perfectly fine with zero degradation at 249, but at 251 its falling apart. Its somewhat of a linear process. The degradation process starts low, and ramps up into very high temps. A quick search tells us:
    • Conventional motor oil: Can withstand temperatures up to 250°F, but starts to break down at 275°F
    • Petroleum-based engine oil: Begins to oxidize, or break down, at around 240°F
    • Full synthetic oils: Can handle temperatures above 300°F, and some can withstand temperatures as high as 700°
    Time is a big factor. Running the oil at 275 for 5 minutes is nearly nothing. Running it at 275 for an hour is very different."
    While I'm not saying the above info is absolutely correct, it is logical that as oil temp rises that it does affect the oils ability to lubricate and cool the moving parts. The question then is "at what temp does my oil of choice" begin to have issues. An engines oil temp is normally higher than its coolant temp during normal operation. Obviously there is an operating range rather than just one temp thats acceptable. I prefer to try to stay at the lower end of that range and have more of a "cushion" so to speak. I honestly can say that I don't remember ever seeing someone have a problem much less lose an engine from operating at 175/195 degrees. Maybe a little less efficient, maybe a little more wear or maybe not, but never a catastropic failure caused by that temp range. So, I'm good with that........:)
  17. Never had an issue operating 210 to 220 either in my personal experience
    Not on my older OHV carb engines either other than an occasional vapor lock issue. A fuel return line cured that on the current one.
    coming from a newer car perspective. A low engine temp code pops up. Can’t specify the too low temp for every car. A generic guess is staying under 200.
    my pro life was seeing car temps in the 210 to 230 range was normal.
    Old stuff was whatever it ran and didn’t boil over growing up. Old straight 6 GMCs and stovebolts tended to generate heat under load. Those ran a good bit hotter than my daily 235 did.
    the old Porsche stuff I worked on. Check oil warm. At least 175. Shut it down if it exceeds 250ish. I’d probably shut it down before that.
    we’d back off on a vw around 220-230 oil temps
    Crazy how cool temps vary by foot control.
    Some race car stuff couldn’t be cranked until the oil was warmed to around that 170ish minimum.
    Think the oil temp gauge went to around 340*
    all this discussion is why manufactures removed numbers from gauges or installed idiot lights.
    “My 350 has 10psi at idle warm” complaints started back up when they put numbers on gauges.
    That same customer never thought about it with an idiot light that didn’t come on until around 7psi or just had a non numerated gauge.
    The kids 61 has the temp gauge with no numbers. Don’t have a clue what it’s running. The gauge needle stays in the middle
    No boil over
    Undersized (compared to the original core size) aluminum radiator.
    4 blade fan. No shroud.
    so far so good even pulling a loaded trailer
  18. gimpyshotrods
    gimpyshotrods
    That is a very generous way of describing it.
    I watched the computer simulation of the cooling system in an SBC when I was still at GM.
    It is a miracle that it works at all.
    anthony myrick likes this.
  19. Langan
    Langan
    from Eagle ID.
    I am thinking that maybe some rust slag from inside first motor got pumped on top of rad. cores? First motor sat on stand for about 10 years because I had it so i built truck
    Ran fine but had very little oiling to rockers. So found out the Felpro pan gaskets deteriorated and plugged oil pump. Block was full of flakes of rust.
    So now on 3rd engine all run hot.
  20. gimpyshotrods
    gimpyshotrods
    I set up everything in my fleet that is water cooled to run at 210ºF.
    If no liquid coolant and no steam are coming out, it is not overheating.
    All engines run hot. Many here do not run hot enough.
  21. ems customer service
    points remember: gasoline can make a difference, and al***ude, alcohol free gas will make the engine run cooler, the gas for higher al***udes will make it run hotter than normal alcohol gas.,
    the alternator: I has this problem on my cars it was just not strong enough for elec fans and the interior blower fan, I upgraded to a 100amp at 1000rpm it eliminated the overheating problem and kept the a/c on,
    you don't need a shroud this elec fans removal will allow more air over the engine
    whats happen when you take the engine hood off?
  22. Beanscoot
    Beanscoot
    Can't you just put in a higher temperature thermostat, like a 205?
  23. I’m gonna try one.
    I’m gonna verify temps with a hand held thermometer first.
  24. SDS
    SDS
    Get the Walker re-cored. Their br*** tanks are great, but their cores always ****ed. I did this and have zero cooling problems.
    I do have a Zip setup (as recommended by Eddy) and an old school mechanical SBC steel fan. With a 190° thermostat, the only time it goes over 190 is if I'm stuck in a traffic jam for a lengthy period of time and it's over 80° outside. I could probably cure that with a more modern efficient fan.
    Langan, Blues4U and ekimneirbo like this.
  25. DDDenny
    I'll suggest Ron Davis for an aluminum radiator but not because they are the cheapest.
  26. joel
    joel
    I use a high flow water pump and Custom Auto Radiator (copper br***) with 17" mechanical fan and Robert Shaw thermostat (180). It idles on the thermostat and in slow traffic. When I go to freeway speeds, the temp. cycles a couple of times up to 195 then settles around 185. I also have a coolant recovery tank with a 13# radiator cap and no shroud. 10.2 C.R. 327. I believe that if the radiator has enough heat rejection capacity, the flow rate will reach an equilibrium which also removes heat from the engine at a higher rate.
  27. Mo rust
    Mo rust
    If it doesn't burp out coolant, it's not hot. (***uming it has coolant and the initial overfill is allowed to exit) Move your temperature sending unit from the head to the front of the intake and quit worrying. Also you won't like the Chinese aluminum radiators for a 28/29 grill shell. All of them that I have found will show the tanks on top and or bottom. For that, you would need a Walker/Johnson or maybe one of the other higher end brands. If you do replace your Walker, I might be interested in buying it. (You really should probably keep it though)
  28. Almostdone
    Almostdone
    ekimneirbo likes this.
  29. I will toss in my story. Have 1978 VW Rabbit diesel. Had a copper aftermarket radiator that corroded out, why? That way when I got it in 1995. Picked up an aluminum core, plastic tank radiator off of Craigslist or was that the Penny Saver. Hole in the plastic tank from a rub and a bad tube to tank juncture. Sanded the spot on the plastic tank, JB Weld. Acid etched the tube spot, neutralized the aluminum, then JB Weld. Again, 1995, still running fine. But frequent changing the radiator fluid because of chemical reaction with aluminum, a known problem.
    firstinsteele likes this.
