Hot Rods Engine turned chrome???
Discussion in 'The Hokey Ass Message Board' started by jcrapola, Jun 14, 2025.
  1. jcrapola
    jcrapola
    it is not worth anything. I cannot imagine there would be any “profits” from selling a chiwanese steering wheel from Speedway motors. Unless you happen to be in the market for one?
    heehee
    lothiandon1940 and 05snopro440 like this.
  2. jcrapola
    jcrapola
    Thanks for the additional info. That is super informative and helpful.
    I do cheat a little and use a conversational mill at work to setup and execute the turning. I spend a few mins programming and the spacings come out perfect. Reading your instructional, I really feel like it is cheating. Damn.
    I am not sure the spokes are wide enough to leave a border, but I am gonna try it. I sure like the way it came out on your projects. That is some home-brewed Bad***ery on display in your post.
    Thank you again! That is exactly the type of info I was hoping for when I posted!
    lothiandon1940 and Bandit Billy like this.
  3. Bandit Billy
    Bandit Billy
    That's a fine compliment right there! I started doing this only a couple of years ago based on info I gleaned from the HAMB. Since then, I have done tons of projects on my cars. I'm a certified engine turned junkie! It doesn't fingerprint, it doesn't smudge, it hides imperfections and like you said, it doesn't reflect sunlight back in your face.
    I just use my drill press with a grid I laid out in sharpie, a couple of clamps and a straight edge. A mill would be nice, but I don't own one. Check this out, I did these breathers on one of my cars. I did this by holding the breather with my hands and lifting it into the Cratex spinning in the drill press. Completely by hand. You can handle this steering wheel. I look forward to seeing the results. If you mess up, just sand and polish...like a magic eraser.
    rattlecanrods, Tim and lothiandon1940 like this.
  4. Dan Hay
    Dan Hay
    Here’s another solution you didn’t ask for: sprint cars have vinyl padding that snaps over the steering wheel. Easy to install and remove when you want to show off your wheel.
    05snopro440 likes this.
  5. 05snopro440
    05snopro440
    Vinyl sleeves that Velcro on would work. Like a handlebar center pad on a snowmobile.
  6. Deuce Lover
    Deuce Lover
    There is a guy in CO that does the engine turning for 32 & 33 Ford gauge panels. He requires that the panel be chromed ,then he does the engine turning.Here is a pic of the panel he did for my friend in FL.First pic is the chromed panel sent to the engine turner.
  7. patsurf
    patsurf
    now THERE is the answer to the o.p.!!
    Kelly Burns likes this.
  8. jcrapola
    jcrapola
    BOOM! That is what I was seeking. Thank you!
    Bandit Billy likes this.
  9. crminal
    crminal
    05snopro440 and Bandit Billy like this.
  10. jcrapola
    jcrapola
    Love that interior! Looks like it has some wonderful memories in there.
