Technical Heim to tie rod question
Discussion in 'Traditional Hot Rods' started by '50_SEDAted, Jun 23, 2025.
  1. '50_SEDAted
    '50_SEDAted
    Howdy.
    The rear radius arms on my roadster originally had a front heim joint on either side and I am replacing them with tie-rod ends. I can see that when I put the tie rod end in the bracket hole (5/8") it goes in past the taper and snugs up on to the shoulder. I haven't cinched it down yet, but I'm guessing it'll probably/maybe pull right up to the ball joint. I'm guessing I need to put some sort of tapered bushing in there? It'd have to be an awfully thin-walled bushing, though. Or is it OK to cinch to the shoulder in this application?
    Or could I press in a bronze or br*** sleeve and then taper with a reamer?
    Thanks for yer help!
  2. '50_SEDAted
    '50_SEDAted
    5/8" heim swivel bore, 5/8" shackle/bracket bore, 5/8" tie rod shoulder
  3. Mart
    Mart
    Someone with a lathe could make you some shouldered bushes that would press in and allow the tapered tie rod end to be snugged up. I had to do this when I bought some spindles that had been drilled out.
  4. chickenridgerods
    chickenridgerods
    from DSM, IA
    You need a tapered boss. Either via a shouldered insert that fits into that straight boss - which sandwiches the straight boss between the inserts shoulder and the nut on the backside, or by removing the existing boss and welding in a tapered one (or by cutting off the tab entirely and replacing it with one that has a tapered boss).
  5. alchemy
    alchemy
    Yeah, quicker and easier to just cut that tab off and weld on a fresh one that hasn’t been butchered.
    dirt t, lostone and gimpyshotrods like this.
  6. Dave G in Gansevoort
    from Upstate NY
    I’d go with new brackets with the correct size bosses also
  7. seabeecmc
    seabeecmc
  8. 29Sleeper
    29Sleeper
    from SoCal
    That tab isn't butchered. It's just for a different application. The original owner built the car with heim joints that use a bolt to secure them. This owner wants to use a ball joint which mounts with a taper.
    As for me if the heims were worn I'd replace them and not try to reinvent the wheel.
    joel and alanp561 like this.
  9. 31 Coupe
    31 Coupe
    More importantly, what are you going to do with the 5/8"-18 UNF to 11/16"-16 UNF thread adaption.
    Luckily, the drill size for 11/16"-16 is 5/8" (0.625") for 75% engagement.
  10. Marty Strode
    Marty Strode
    This !
