Projects United Pacific 5W Deuce Build
Discussion in 'The Hokey Ass Message Board' started by Groovy, Feb 18, 2017.
  1. RockyMtnWay
    RockyMtnWay
    PM’d you with a couple pics.
  2. Groovy
    Groovy
    Started the fan shroud. Gotta cut the fan hole and split it in half to make installation easier... IMG_8311.JPG IMG_8313.JPG IMG_8312.JPG IMG_8311.JPG IMG_8317.JPG IMG_8314.JPG IMG_8311.JPG
  3. Groovy
    Groovy
    Fan hole is cut and shroud cut in half to make installation easier... IMG_8377 - Copy.JPG IMG_8384.JPG IMG_8385.JPG IMG_8386.JPG IMG_8387.JPG
  4. deuceguy
    deuceguy
  5. Brand Apart
    Brand Apart
    from Roswell GA
    Curious, are you going to attach the 2 pieces of the shroud to each other after installing ?
  6. ClutchDumpinDan
    ClutchDumpinDan
    Don’t know how I missed this thread over the years. Gorgeous work. Thanks for taking the time to post so many pics. Not enough build threads like this anymore :)
  7. Groovy
    Groovy
    I plug welded two pieces of 3/32" thick metal and tapped the holes for 8-32 machine screws... IMG_8403.JPG IMG_8400.JPG IMG_8401.JPG IMG_8402.JPG
  8. RockyMtnWay
    RockyMtnWay
    I know our garages aren’t that warm yet, but how goes the battle?
    Really enjoying this build thread.:cool:
  9. Groovy
    Groovy
    Sand blasted and body filler applied... IMG_8433.JPG IMG_8434.JPG IMG_8446.JPG IMG_8447.JPG IMG_8448.JPG
  10. Chief 64
    Chief 64
    That’s the most beautiful shroud I have ever seen!
  11. Groovy
    Groovy
    IMG_8610.JPG IMG_8611.JPG IMG_8613.JPG IMG_8614.JPG IMG_8607.JPG IMG_8604.JPG IMG_8608.JPG IMG_8606.JPG
    Fan shroud is painted and installed...
  12. Groovy
    Groovy
    IMG_8689.JPG IMG_8691.JPG IMG_8688.JPG IMG_8690.JPG IMG_8692.JPG Made a map / stuff holder for the p***enger side kick panel...
  13. Groovy
    Groovy
    Welded up a pair of pedestals for the seat head rests. Also painted a pool ball with red flake to use as a shifter ball... IMG_8693.JPG IMG_8699.JPG IMG_8695.JPG IMG_8698.JPG IMG_8697.JPG
    The 39 guy, loudbang and Robdski like this.
  14. Groovy
    Groovy
    Stuff holder is painted & installed... IMG_8727.JPG IMG_8728.JPG IMG_8729.JPG IMG_8730.JPG
  15. Quality workmanship! Keep it up!:)
  16. Groovy
    Groovy
    Head rest is painted. Nine pieces of metal come together to make one plus two pieces of wood... IMG_8734.JPG IMG_8735.JPG IMG_8736.JPG IMG_8737.JPG IMG_8738.JPG
    The 39 guy likes this.
  17. DDDenny
  18. Groovy
    Groovy
    I found it in a pile of stuff a customer was throwing away... I've been searching for information about it. The local Dodge/Plymouth don't know anything about it???
  19. Groovy
    Groovy
    Steering wheel riser has been shaped with body filler to make the transition from the wheel to the stalk smooth... IMG_8751.JPG IMG_8750.JPG IMG_8748.JPG IMG_8744.JPG IMG_8742.JPG IMG_8741.JPG
  20. patsurf
    patsurf
  21. Groovy
    Groovy
    Head rests are completed... IMG_8806.JPG IMG_8807.JPG IMG_8805.JPG IMG_8804.JPG IMG_8803.JPG IMG_8802.JPG IMG_8801.JPG
  22. The 39 guy
    The 39 guy
    Wow, nice ideas,great workmanship!
  23. Groovy
    Groovy
    They've finally arrived. Coker tire said I was the first person to be put on the waiting list for the new Roadster Radial back in February. This will give the Rod the proper look... IMG_8832.JPG IMG_8834.JPG IMG_8835.JPG IMG_8836.JPG IMG_8833.JPG
  24. deucetruck
    deucetruck
    from Missouri
    I like the tire choice. What sizes did you go with?
    Thanks.
  25. Groovy
    Groovy
    7.50R16 & 6.0R16
    I went too small with the Excelsior Stahl Sport. 7.0R16 rear and 5.5R16 Front. Rear tire looked way to small...
  26. RockyMtnWay
    RockyMtnWay
    Can’t wait to see them mounted and on. I’m still waiting on mine. :D
  27. deucetruck
    deucetruck
    from Missouri
  28. Groovy
    Groovy
    Excelsior Roadster radials have been mounted. Rear tire fills up the wheel well nicely. These are heavy tires... IMG_8910.JPG IMG_8911.JPG IMG_8912.JPG
