Technical 2 skateboard wheels, a shaft collar, drill press and cutt off wheel walk into bar
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Jun 24, 2025.
  1. probably the lowest level tech thread ever posted. I like the yo yo shift knobs. The thread @Moriarity has on em got by brain juice flowing
    Ordered some cheap skateboard wheels and found a stainless shaft collar online.
    $10 for 4 wheels shipped.
    $8 collar plus shipping.
    Was wondering what I could do with the limited stuff I have so I put a bolt thru a skateboard wheel and chucked it in my ****py drill press
    tried a few different cutting methods. A cutoff wheel worked the best.
    IMG_7030.jpeg IMG_7031.jpeg precession :)
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    pretty freakin cool man....
  3. Thanks. The interior of the Merc is red with a white headliner. Should look ok
    Needs polished. Thinking about clearing the wheels. Might hold up better
  4. The collar is technically 1.999 OD
    The wheels are 2.047. According to the online info
    The slight oversize kinda looks better than I thought it would. Used wet sand paper to roll it in at the cut.
    My local hardware store only had 1/4 acorn nuts.
    5/16 would look better.
    Deutscher, porkshop, 6inarow and 11 others like this.
  5. ClayMart
    ClayMart
    Spiff-O-Matic 2000 ! ! !
    :D
  6. bchctybob
    bchctybob
  7. Bandit Billy
    Bandit Billy
    The stickers, something you printed? The surface is curved, how did they adhere without wrinkles?
  8. The skateboard wheels come that way
    Deutscher, porkshop, clem and 23 others like this.
  9. 41 GMC K-18
    41 GMC K-18
    Ian Roussel would approve indeed!
    I'd shift it!
    Deutscher, porkshop, Outback and 9 others like this.
  10. The shaft collar IMG_6559.png There’s thick washers and spacers also online.
    This was cheaper than buying a section of tubing.
    Tube would be cheaper in the long run if making multiple.
    Skateboard wheels can be bought in different diameters and lots of different colors
  11. 36cab
    36cab
    As a long time skateboarder I can attest that there are some pretty cool graphics on some of the wheels that would work great as a shifter knob.
    porkshop, catdad49, Oneball and 8 others like this.
  12. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Anthony, proving once again you're not just another pretty face
    :p
    porkshop, CSPIDY, tomcat11 and 16 others like this.
  13. KoolKat-57
    KoolKat-57
    from Dublin, OH
  14. guthriesmith
    guthriesmith
    That’s pretty dang cool Anthony!
  15. Sharpone
    Sharpone
    Absolutely Awesome. Antony how wide is the collar? I had a Cal Custom on a 4 speed way back, wood I believe walnut.
    Can I borrow/steal your design? The reason I ask is that I bought a B&M unishifter for my Dart project , it has a ****py plastic t handle with the B&M logo I’ve been thinking about what to replace it with. It’s 1/2” fine thread on the shifter. Your yo yo idea would be perfect.
    Dan
  16. twenty8
    twenty8
    You’d have to drill it. Comes 3/8 course
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    if he drills a hole for1/2” threads in something 9/16 wide and then taps it I am afraid it will break through or will have very little material on each side of the hole
  19. Might be ok on this. It’s thick
  20. One place listed 5/8 wide spacers. I’ll try to look
    Granger says they can sell a 6” long piece of stainless tubing.
    Not cost effective unless ya want to make a few of em
  21. GZ
    GZ
    from Detroit
    Awesome-sauce!!!!
  22. Sharpone
    Sharpone
    Thanks @Moriarity and @anthony myrick 5/8” would be better, I’ll look at Grainger and McMasters but 9/16 might be ok it’s an auto so I won’t be banging gears - Dang it!
    Dan
  23. Shitbox
    Shitbox
    from Nor Cal
    As someone that’s skated for the past 40 something years glad to see others using wheels as shift knobs. I go the easy way(sorry cars no where near driving so bike will have to do):
    Always run them with bearings in so you can spin them.
    Graphics should be screen printed(no idea what those are since im a Spitfire lifer).
  24. winduptoy
    winduptoy
    shifty character .....heavy on the character
  25. 31 Coupe
    31 Coupe
    You need a lathe Anthony ...... it would offer you so many more artistic opportunities.
  26. jim snow
    jim snow
    Nailed it. Looks great. Snowman ⛄️
  27. deathrowdave
    deathrowdave
    from NKy
    I have one , my friend if I lived near you we could make tons of fun stuff . Just completed nylatron bushings for mower wheels .
  28. Dad, an uncle and a couple cousins are machinists.
    I’m just dumb enough to be dangerous around one
  29. Paulz
    Paulz
    The cab mounts are cut down urethane skateboard wheels.
