Projects 1950 Chopped Chevy Sedan Delivery
Discussion in 'Traditional Customs' started by RMONTY, Jan 15, 2016.
  1. RMONTY
    RMONTY
    Mixed up some epoxy primer today and took care of a few items. Got lots more to do! Learning how to adjust the gun for how I like it. There is more to this painting stuff than meets the eye. ;) 20250622_110334.jpg 20250622_110345.jpg 20250622_110834.jpg 20250622_110844.jpg 20250622_111324.jpg 20250622_135328.jpg 20250622_135402.jpg 20250622_135436.jpg 20250622_145710.jpg
    Deutscher, Outback, alanp561 and 9 others like this.
  2. jasonb357
    jasonb357
    Just went through all 4 pages, good stuff! Keep up the good work.
    trevorsworth and RMONTY like this.
  3. RMONTY
    RMONTY
    Trevor and Saul showed up so we put Saul to work painting. Me and Trevor stayed out of his way
    He did a great job on all these little parts.
    20250704_113146.jpg 20250704_113206.jpg 20250704_113213.jpg 20250704_150611.jpg 20250704_150623.jpg 20250704_150723.jpg 20250704_150651.jpg
    Deutscher, drdave, Outback and 11 others like this.
  4. trevorsworth
    trevorsworth
    We'd better see all those little parts bolted together over the next few days!! I don't think I did **** today except bring the Soulman to the work site and cut him loose.
  5. RMONTY
    RMONTY
  6. RMONTY
    RMONTY
    Banged some sheet metal around. Not a lot of progress, but progress nonetheless! 20250705_221021.jpg 20250705_221057.jpg 20250705_221127.jpg 20250705_221303.jpg
    Deutscher, Paul B, 50chevytx and 11 others like this.
  7. drdave
    drdave
    Looking good Robin! Looks like it won’t be long now before you are knocking down some miles!
    RMONTY likes this.
  8. RMONTY
    RMONTY
    Got a little ways to go....not sure if I am going to have time to get everything done before Dewey in September.....doing as much as I can, when I can!
    drdave likes this.
  9. Lone Star Mopar
    Lone Star Mopar
    Nice work Robin & crew !
    RMONTY likes this.
  10. RMONTY
    RMONTY
    Thanks brother! You gonna have to come hang out on a Sunday, or any day really. The p***enger door that you donated has really helped!
    Lone Star Mopar likes this.
  11. RMONTY
    RMONTY
    Trevor and Saul came by today and we did a little work on the Sedan Delivery today. Trying to get all the bare metal covered so I don't have to keep dealing with rust. We shot some primer and also got the window put in the rear door. That was a bit challenging for a couple of rookies but we made it happen.
    Almost forgot about the gas struts I installed on the hood instead of trying to get the springs on. A couple of weekends ago Trevor and I tried using a tool I made years ago to remove the springs to put them back on, and the spring broke when we tried stretching it out with the floor jack to install the tool. It could have been disastrous, breaking like that. Trevor suggested putting the gas struts on, I searched it on the innerwebs and damned if there wasn't a video for putting gas struts on a 51 Chevy. $25 bucks on Amazon later, and it was a done deal. Very east installation. All it required was drilling a few holes in incon****uous places.
  12. RMONTY
    RMONTY
    A couple more pics from yesterday from Trevor's camera roll.....we ALMOST mixed up enough epoxy primer to getting the p***enger side done but had to mix up just a tad bit more. It will be nice to see the entire car in primer finally! IMG_2858.jpg IMG_2869.jpg IMG_2859.jpg
  13. RMONTY
    RMONTY
    One thing about the stainless on the rear window. I don't know if it is because the rubber seal is different or what, but the little piece that connects the 2 halves together just barely covers the ends and if it slides just a 1/8" either way it won't cover both ends. I'm going to use a small dab of silicone under it to hold it in place. I actually need to order some black urethane sealer for the window channels so I will probably use a dab of that. I'd hate to lose that little piece.
  14. 325w
    325w
    Wish you would think twice about urathane to set your gl***. When it dries it’s tough to get loose. Gl*** setting rubber tape works fine. Opinion only
    drdave and Pist-n-Broke like this.
  15. RMONTY
    RMONTY
    That's exactly what I want to "glue" the window channels/tracks in with. Not to glue the gl*** in. This is the channel/tracks in the door frame tha is along the opening that the gl*** rides in. I probably am not describing it very well. Here is a couple of pics of what I'm talking about. 20251006_081744.jpg 20251006_081809.jpg
    Deutscher, Stogy, loudbang and 2 others like this.
  16. 325w
    325w
    Got yeah! Be sure to wear rubber gloves. I’ve still got black stains on hands from 20 years of urethane in the car factory
    SS327, Stogy and RMONTY like this.
  17. 1-SHOT
    1-SHOT
    from Denton
    We always used a small chain to put hood springs on. Hook one end of the spring on the car and put the end of the chain on the other end of the spring and pull on the chain and hook the spring on the other side of the hinge and relax your pull on the chain Easy Peasy your done. I worked in a body shop when these hood springs were common.
  18. RMONTY
    RMONTY
    I had forgotten you worked there. I have used that stuff before and it is nasty for sure! Hope you are doing well sir.
    That steering column i got from you years ago has worked well on this old car. Much easier to turn than the 49-52 columns.
    325w, Stogy, loudbang and 1 other person like this.
  19. drdave
    drdave
    Car sure looks great in primer Robin!!!
    Stogy, RMONTY and guthriesmith like this.
  20. RMONTY
    RMONTY
    Thanks Dave......trying to get the thing where I can at least leave it outside for a few hours without worrying about flash or surface rust. I am real close to driving it again. Getting that back window in was an arduous task but plenty of Dawn and a piece of small rope did the trick. It should make it a bit more pleasant to drive too with the back door and window in it.....LOL! that 235 is rowdy sounding!
    Deutscher, Outback, Stogy and 2 others like this.
  21. RMONTY
    RMONTY
    Thinking about getting some lumber and making some walk boards to go along side the car and slide them through a couple of 6' step ladders. Make a scaffolding of sorts to get the top of the car sprayed with primer. Maybe tip the car up on one side to make it easier to spray by jacking it up and putting some ramps or something under the front and back wheels. There is a lot of real estate up top to get prepped and primed. Im sure the brain trust/think tank of Trevor and Saul will come up with something!!
  22. Lone Star Mopar
    Lone Star Mopar
    Looks good, nice work dudes !
    RMONTY and Stogy like this.
  23. drdave
    drdave
    I had the same struggle with the back window in my Merc. I paid a guy (pro) to put it in before I left for Indy and the bottom popped loose on the way. Took him 4 hours. When I got home, dad and I had it done in 20 minutes, but it was a whole lot of dawn and a few blisters on the heel of my hand from banging it in. LOL
  24. guthriesmith
    guthriesmith
    Amazing how getting it in primer makes such a huge difference. Looks great Robin!
    RMONTY, 38Chevy454 and Outback like this.
  25. poco
    poco
    from oklahoma
    Hope to see you in Dewey
    RMONTY likes this.
  26. 1-SHOT
    1-SHOT
    from Denton
    I worked at a body shop and saw 5 gallon cans around the walls of the paint booth and that’s what Shorty uses when he fainted a roof or hood. A lot of times I painted them for him
    Deutscher, RMONTY, drdave and 2 others like this.
  27. 325w
    325w
    That was a good unit. Glad you got it.
    RMONTY likes this.
  28. RMONTY
    RMONTY
    I broke the driver's side windshield half when we installed the windshield. Bumping it with the heel of my hand. Pissed me right off and I said "I'm done for the day!".....ordered another piece and it went in a lot easier for some reason.
  29. RMONTY
    RMONTY
    Yes I like it all one color! It looks like something beside a pile of mismatched parts!
    guthriesmith likes this.
  30. RMONTY
    RMONTY
    That's the new goal.....I think it's a real possibility!! I'm highly motivated to get 'er done!!
