Technical 2 skateboard wheels, a shaft collar, drill press and cutt off wheel walk into bar
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Jun 24, 2025.
  1. zman
    zman
    from Garner, NC
  2. https://www.extsw.com/collections/2-od-316-ss?page=4
  3. Kosmos55
    Kosmos55
    I like it. Try these white rubber boots with it. Advertised for boat throttle cable.
  4. That’s cool
    porkshop, catdad49, Okie Pete and 3 others like this.
  5. Sharpone
    Sharpone
  6. A piece of stainless exhaust tubing would work.
    Weld a nut on the inside
  7. Sharpone
    Sharpone
    You’re a gentleman a scholar and a genius I happen to have some SS exhaust tubing.
    Thanks
    Dan
  8. 1952henry
    1952henry
    Nicely done! Clever
  9. lostone
    lostone
    from kansas
    This is my favorite type of homegrown tech.
    Taking something totally different than it's intended use and modifying it to fit your intended use !!
    Great job Anthony!!
  10. Phillips
    Phillips
    Anthony this kicks *** thanks for sharing!
  11. Rodney Dangercar
    Rodney Dangercar
    To play off of a famous person I've read here...
    I'd shift it! Pretty cool idea for a unique shift knob.
  12. Anthony, I’m beginning to think y’all got too much free time on your hands.
  13. 31 Coupe
    31 Coupe
    I have a machine shop at home and it's amazing how many friends you inherit over the years because of that.
  14. panhead_pete
    panhead_pete
    Never thought to use my drill press like that, thanks!
  15. Okie Pete
    Okie Pete
    Very Kool and informative.
  16. joel
    joel
    Nice work; kinda looks like the knob on a Hurst Syncro lock 3 speed shifter, but nicer
  17. catdad49
    catdad49
    Anthony, you're a pretty Shifty fellow ( but in a Good way)!
  18. Michael Ottavi
    Michael Ottavi
    Anthony if I had a teacher like you in high school I might have amounted to something. Can an 80 year old enrolls in your shop cl***?
  19. MMM1693
    MMM1693
  20. AccurateMike
    AccurateMike
    Cab mounts=hockey pucks. They come in different durometers too. Mike
  21. Hockey pucks = body lifts back in the day
  22. AccurateMike
    AccurateMike
    Eggs Zachary ! Mike
  23. swade41
    swade41
    from Buffalo,NY
    Nice job on that, lot of possibilities there to make others
  24. Moriarity
    Moriarity
    SUPER MODERATOR
  25. Okie Pete
    Okie Pete
    What’s a hockey puck ? Don’t think Walmart carries those around here . lol I saw a beer keg handle made out of a stack of poker chips once . I thought that it would be a good idea for a different looking shift knob . But then again I have a cow horn I need to put in something. Maybe the 31 A
  26. HOTRODPRIMER
    HOTRODPRIMER
    Anthony, that's slick , A little of the old a,a little of the new and you just made a cool vintage looking yoyo shiftier.
  27. I was too impatient to go to a friends shop or school to use a lathe.
    This took about an hour. The cutting/grinding isn’ near as fast as a lathe.
    But I didn’t measure squat. Just ground and sanded until it fit and looked ok.
  28. DDDenny
    We had some guys like that in the machine shop, called them "bit machinists", as in take off a little bit until it (kind of) fits.
  29. I usually build on the fly.
    It’s thought out
    But…..one of the best builders on the planet told me “one modification usually leads to 10 more”
    Facts.
