Projects Building a 57 Chevy Shop Truck
Discussion in 'The Hokey Ass Message Board' started by swade41, Nov 1, 2017.
  1. chevy57dude
    chevy57dude
    "Twisted Mystery'' lol. Glad you got it running. Vertigo sounds a little scary.
    swade41 likes this.
  2. deathrowdave
    deathrowdave
    from NKy
    I have had my runs with the vertigo **** also . Not good . Hang tough it will move on just as it appeared . Tuck is lookin great !
    chevy57dude and swade41 like this.
  3. swade41
    swade41
    from Buffalo,NY
    I think this is it for the 307, it'll be a backup motor to sit in the corner till it's needed, at least I know it does run decently and has antifreeze in it
  4. Dooley
    Dooley
    from Buffalo NY
    when my father blew up his 327 he bought a 68 Biscayne with a 307 and powerlgide for $50.00 in 79-80. when i drove the car in 83-85 it still had the 307. makes a good backup motor for the bucket esp for your kid driving it.
    swade41 likes this.
  5. Bandit Billy
    Bandit Billy
    I bought a 69 Camaro with a 307 to play with. They are the perfect raw material from which to build a muscle car because they have a V8 VIN number and the 307 is so weak you know it hasn't been drag raced, slid around corners and abused. I also got decent money for the little small block when making room for the 396. They have their place. Enjoying the build.
    swade41 likes this.
  6. X-cpe
    X-cpe
    Are you kidding? :D Having been a teen, raised one and taught them for 27 years, there is no car that they can't figure out a way to abuse.
    427 sleeper, Bandit Billy and swade41 like this.
  7. swade41
    swade41
    from Buffalo,NY
    I'm still not above putting the 6-71 on it, at least it might make 300 hp !
    But if it really takes 100 hp to turn the blower that would mean it'd knock it down to a 100 hp motor, I don't know if it'd crank out another 200. Lol
  8. Motorwrxs
    Motorwrxs
    Swade41 do you plan on running the fender well headers? How much clearance for an exhaust should you choose to run an exhaust with those headers?
  9. swade41
    swade41
    from Buffalo,NY
    Unfortunately the tri-five headers interfere with left hand turns
    I have a set of the "fat fender" ones but #7 tube hits the column
    I have two cars with fenderwell headers and i ran the pipe under rocker and exited before the rear tire
    rod1, 4 pedals, 57tailgater and 2 others like this.
  10. 427 sleeper
    427 sleeper
    Hell, at that point you'd be money ahead to run a Flathead! LOL!!!
    swade41 likes this.
  11. swade41
    swade41
    from Buffalo,NY
    Ha !
    I have everything except carb linkage and a crank hub for the pulley, so it's like "free" horsepower lol
    427 sleeper likes this.
  12. 57tailgater
    57tailgater
    from Georgia
    Nice comparisons on the headers. Have always wanted to run fenderwells on my truck but ***umed there would be some interferences. I have late '60's C10 full length headers on mine and it's nice as they come down low enough to clear the frame crossmember. But the fenderwells are soooooo cool! How close is your engine to the stock location?
    swade41 likes this.
  13. Motorwrxs
    Motorwrxs
    Thanks for the pics…I am running block hugger headers on my 57… not a fan. Not really interested in paying big bucks for some long tubes.
    swade41 likes this.
  14. swade41
    swade41
    from Buffalo,NY
    I'm not sure how close to a stock location it is, this was a 6 cylinder truck.
    I mocked it up with an hei and placed the engine so that the hei base was about one inch off the firewall. I used the tubular engine mount placed inside the frame rails and raised it as high as it would go.
    Not sure if you can tell anything by where the crank pulley is or the space between valve cover and firewall.
  15. 57tailgater
    57tailgater
    from Georgia
    Front to back mine may be an inch or so further rearward and I am using a stock style bell housing and non-HEI distributor and valve covers are closer to firewall. So we are pretty close overall.
  16. swade41
    swade41
    from Buffalo,NY
    Did a little to the 57, pulled the 205/75/15's off the old Cragars
    Pulled the old bias plys off the aluminum slots I want to run
    Married those two together
    And think it looks pretty good
  17. swade41
    swade41
    from Buffalo,NY
    Then I hooked everything up to run the 307, since it was jacked up already why not try and find this oil leak.
    Ran it for a couple minutes and it leaked this much out, it's a good leak
    It looks to be coming from in-between the timing cover and the oil pan, I had already snugged the oil pan bolts once, so that ain't it.
    This will be a backup engine so I'll replace the pan gasket when the time arrives to call it into service.
    Next up will be removing the front clip, motor/trans and start cleaning up the front half of the frame.
  18. swade41
    swade41
    from Buffalo,NY
    Just about ready for front clip and engine/trans pluckin !
  19. fastcar1953
    fastcar1953
    Following along. I just picked up a 56 . 571169990_25382587784672168_4998507821585957958_n.jpg 570389190_25382588638005416_7162360723898322881_n.jpg 570631435_25382591204671826_5549374018254623613_n.jpg 571120158_25382589074672039_7718604322828109080_n.jpg 568682390_25382588188005461_708188802801850872_n.jpg
  20. swade41
    swade41
    from Buffalo,NY
    That's a good looking truck
    Tickety Boo, porkshop and Dooley like this.
  21. fastcar1953
    fastcar1953
    Thanks . 350 TH350 P/S P/B 3 inch lower springs in front and just got 3 inch lower for rear.
    New chrome grille and bumpers plus headlight rings. Tilt wheel . Alum radiator. Even the radio works. lol
    Needs bigger tires up front.
    Older build been sitting. Needs things freshened up.
    2 tailgates. Ditched the visor. Not my style.
  22. swade41
    swade41
    from Buffalo,NY
    Me and my son pulled the front clip today instead of watching football, if I had more room I would've pulled the engine/trans.
    I need to get a plan together so I can pull that on a separate day from the power washing the ch***is day.
    I would need to move 2 cars, the bike, the front clip and the stack of tires to pull the engine/trans and need to move all 3 cars plus that other stuff to get the truck outside.... ugh
    rod1, X-cpe, LOST ANGEL and 6 others like this.
  23. 427 sleeper
    427 sleeper
    Jesus Christ Man! It looks like a tire shop in there, instead of a garage! LOL!!! Like the tire department at Sears!
    porkshop, loudbang and lumpy 63 like this.
  24. swade41
    swade41
    from Buffalo,NY
    But I have 9 pairs of skinny front runners, which makes it all ok. LOL
    I don't know how I ended up with so many pairs with rubber on them, that's the problem. Without rubber I could just stick them on the rack with the others.
  25. swade41
    swade41
    from Buffalo,NY
    I'm making good use of my son LOL today we pulled the engine/trans, went pretty smooth too.
    Tomorrow I'll get it outside for the power washing, hopefully that'll knock the crud off so they're won't be as much dust when wire wheeling the frame.
  26. Motorwrxs
    Motorwrxs
    Swade41 watched your YouTube video on your 51 Henry J…sweet looking ride. Paint job looked legit, especially for a roller paint job.
    porkshop likes this.
  27. swade41
    swade41
    from Buffalo,NY
    Thanks, kinda like the water drops on this truck, something new to do, I did one test panel then just went for it. Of course I manage to half *** know how to do it by the ending of it all. Lol
    No roller job on this one but I'm still undecided on how I'm going to paint the rest of the truck. I guess when I see the bed outside tomorrow from a distance it'll let me know which direction I should go in or start over lol
    porkshop, LOST ANGEL and Motorwrxs like this.
  28. LOST ANGEL
    LOST ANGEL
  29. X-cpe
    X-cpe
    A couple of strings of Christmas lights and you're ready early.
    swade41 and 427 sleeper like this.
  30. swade41
    swade41
    from Buffalo,NY
    2 in the yard and one in the driveway to get the 57 out
    It didn't come as clean as I had hoped but at least the dirt is off of it
    Windows look much cleaner at least
    I sprayed the other fenders down too
    Then Sta-Bil atized the t-bucket, Henry J and 41 truck, took them for a spin making sure to open up the secondaries in them to get the treated fuel in there too. I put the Henry J in it's winter parking spot and moved all the other stuff back in an unorganized organized manor.
    X-cpe, porkshop, LOST ANGEL and 3 others like this.
