Projects 29 Coupe, The Wolf Special
Discussion in 'Traditional Hot Rods' started by scoob_daddy, Apr 16, 2023.
  1. scoob_daddy
    scoob_daddy
    from Georgia
    A few post to follow! I haven’t updated since January… catch me on IG for more regular updates…
    Clutch kit made up locally for Cad to LaS trans.
  2. scoob_daddy
    scoob_daddy
    from Georgia
    F-1 Steering box in process. All clean.
    I bought a Chadillac Designs steering box flange kit. I then made a lathe arbor to turn down the existing flange to accept the new one. I plan to revise this arbor to instead bolt to the gear cover holes, that way the box can be turned regardless of whether or not the bushing is installed. This way will also make it easier to offset the diameters in the 4 jaw chuck to account for the castings core shift. The diameter shown is not the final dimension, just my proof of concept.
  3. scoob_daddy
    scoob_daddy
    from Georgia
    Sort of off topic, but I figured y'all would get a kick out of the Kitchenaid mixer I had pinstriped for my wife. Striping done by Hot Rod Walt. Friend & Front Man of The Psycho DeVilles.
    New welder & plasma cut machines. Now for some real progress!
  4. scoob_daddy
    scoob_daddy
    from Georgia
    Grabbed the crustiest LaSalle case in the pile and tore it down. After cleaning, I was pleasantly surprised to find that it’s in great shape.
    Ken at K&M Aerospace walnut blasted the input shaft and recut the pilot bearing diameter. He also splined the output shaft to fit the Ford torque tube U-joint & widened the existing snap ring grooves for modern eyeleted circlips, as the original ones are a huge PITA.
    Despite being a machinist myself, I’m content with sending this work off. I’ve got no ego in this. My department at work doesn’t even have a dividing head so If someone else has the tooling and process down, go right ahead.
    Lastly, I had the bottom cover chrome plated.
    I’ve realized that having parts chromed is addicting. Comparable to getting tattooed. Once you have one, the next time you have a couple hundred bucks burning a hole in your pocket, you’ll want another.
    3blapcam, AHotRod, don colaps and 9 others like this.
  5. Tim
    Tim
    from KCMO
    Who doesn’t like chrome! Good update :)
    scoob_daddy likes this.
  6. 59sedandelivery
    59sedandelivery
    DAMN!!!!! I just went 3 pages from a Banger to a POWER PAK and then one of my favorites the CADDY Build!!!! Im in for the subscript..... keep posting anything...
    scoob_daddy and Outback like this.
  7. Outback
    Outback
    from NE Vic, Oz
    Thanks for posting here, not all of us are on the Gram.
  8. scoob_daddy
    scoob_daddy
    from Georgia
    Thanks ya'll... More updates it is then, now I feel like an ***hole! ha!
    Deutscher, Outback, Zax and 2 others like this.
  9. Grumpy ole A
    Grumpy ole A
    Thanks for the updates. I had to go back and refresh my memory of where your build is at. I am still a bit envious of you and your dad going through the old speed shop. I love poking around in old places to see what can be found but that place is amazing.
  10. scoob_daddy
    scoob_daddy
    from Georgia
    First some hokey machinist screw jack action to press out the reverse cluster gear shaft.
    Followed by drilling, chamfering, & tapping the hole pattern for the Ford rear bearing mount. There is .050 wall thickness at the 3/8-16 thread major diameter & bearing bore, so the old bearing is mocked in place while tapping to keep the bearing bore from deforming/cracking where thin.
  11. scoob_daddy
    scoob_daddy
    from Georgia
    Small updates,
    I scored this Edelbrock 4x2 CD-694 manifold & matching valve covers from Squeak Bell’s collection. I'm very happy with this look.
    I wasn’t thrilled with the look of allen headed grub screws- splitting hairs I know… So I turned back some 7/16-14 bolts to 3/8 OAL, then slotted them in the mill. These will go in with Loc***e 545 then peened in several places to plug up the old tail shaft holes in the rear of the LaS case.
  12. Tim
    Tim
    from KCMO
    Looking good!
  13. Zax
    Zax
    Nice! Love the intake
  14. Steve Reddy
    Steve Reddy
    Great stuff, loving the road trips with Dad, wish I had done more:(
  15. Outback
    Outback
    from NE Vic, Oz
    Nice score on the intake & rocker covers.
    & The little details matter.
    Thanks for the update's
  16. cball
    cball
    That intake looks great man! Great job on the details
    scoob_daddy and osage orange like this.
  17. AHotRod
    AHotRod
    I don't do Instagram either, so get on here and keep the journey alive.
    what frame height are you targeting?
  18. Grumpy ole A
    Grumpy ole A
    Love those valve covers and the intake. This is going to be awesome.
  19. 3blapcam
    3blapcam
    I just caught up as well! I am really digging the build and hope you continue to update here. I'm on IG but am over the advertising & BS scripted "made for the Gram" posts. I hope you're still plugging away!
    3blap.
  20. cfmvw
    cfmvw
    Being a machinist myself, I'm enjoying your fabrication work! Just did a similar slotted head project for a Singer sewing machine base that is my kitchen island; needed to replace the rivets for the wheels, and hex bolts weren't going to cut it, so I turned the 1/4"-20 hex heads round and milled a slot. Just one of those fun projects!
