Hot Rods 324 olds water pump
Discussion in 'The Hokey Ass Message Board' started by lodaddyo, Jun 29, 2025.
  1. lodaddyo
    lodaddyo
    Im trying to put single belt pulleys on my 56 324 olds. Is there a longer length water pump i can get . The pulleys are not lining up with the water pump i have on it. I also need the right crank bolt and washer for the crank pulley i have if anyone might have one
    Thanks!
  2. Marty Strode
    Marty Strode
    Could you use a spacer between the pump and pulley?
    warhorseracing, ClayMart and lodaddyo like this.
  3. lodaddyo
    lodaddyo
    If i cant find the right pump, thats probably what ill do. Just machine a spacer
    Tim and warhorseracing like this.
  4. Rckt98
    Rckt98
    I may be wrong but from memory the crank pulley you have is for an earlier engine. The pump pulley is correct for a 56 engine.
    Turns and bchctybob like this.
