Hot Rods Badly Flooded Ford 94 Carbs
Discussion in 'The Hokey Ass Message Board' started by mdogg1950, Jun 4, 2025.
  1. mdogg1950
    mdogg1950
    First of all, MANY thanks to everyone on here for all your help. It's been a journey, a labor of love to get my '50 Merc running right. Said car has (2) 94's, a mild cam and a dual point vintage Mallory. New Auto lite 216 plugs. On recommendation from a member, I swapped my 7.5 power valves to 3.5's. Jets are #48. Floats have lowered 1/16" also per recommendation.
    Here's the problem: In the course of switching PV's, I must have fiddled with the throttle linkage to such an extent that the engine is badly flooded. Plugs are wet after a few seconds of cranking. (I have spark). So, I remove 'em, wipe 'em dry and crank again. Maybe a few pops. Starter fluid is useless.
    Any thoughts? I'm considering removing all the plugs and cranking the engine to dry it out. Maybe let it sit for a few days? I've never experienced a problem like this, but I'm a latecomer to the Flathead party.
    Thanks again,
    Matt
  2. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Take an air hose and blow your internals dry. Low pressure, throttle blades open, plugs out. No smoking! Crank it over a couple of cylinders. Yes right down the throat.
  3. F-ONE
    F-ONE
    from Alabama
    If I had your set up, I'd throw those 94s out the window and get some English made 97s.
    I have to run a 94 right now.
    They are old.
    They require specific parts that's harder to find like the right power valve.
    I have enough trouble with one Amerasian 94 much less two.
    Edelbrock dumped them for a reason.
    You may have to save your pennies for a while, but the only advantage a 94 has is its compatibility to the Ford LOM distributor. Since you have a Mallory I'd go with new Strombergs.
  4. Jmountainjr
    Jmountainjr
    In your original post it seemed you had bad flood issue started after changing power valves. It was pointed out that the 94s have power valve seats that differ from current Holley power valves. Remove one of the new 3.5s and compare the seat area to one of the 7s that seemed ok as far as flooding. If the PV seat is not correct you are dumping gas into the intake. As to the correct power valve rating you need some manifold vaccum while driving to calculate the correct kick in point. But you need to get it running first.
    winduptoy likes this.
  5. winduptoy
    winduptoy
    Yes, I suspect that you just have power valves filling the intake with raw fuel. The new power valves have a radius on the top of the threads to the underside of the power valve. This radius bottoms the valve out in the thread before the gasket can seat and be compressed to seal. The old PV had a flat there so it could thread in farther and compress the gasket.
    you can carefully file the radius off by chucking it up in a drill.....or order some correct ones from Charlie Price.
    I'll try to go dig and take a photo or two for your reference....
  6. winduptoy
    winduptoy
    IMG_20250605_173511399.jpg the one in front is the one with radius.... will have the symptoms you are referring to
    the one in the back....is the fix..it is squared off....get new, proper gasket/seal too
    good luck
    guthriesmith likes this.
  7. mdogg1950
    mdogg1950
    Thanks for the info folks, makes the Rochester 1bbl on my '49 Chev seem ultra simple. But what's life without a challenge, eh?
  8. mdogg1950
    mdogg1950
    After further review, I apparently installed the PV gaskets incorrectly. Soooo....this time after tinkering with the gaskets, I filled the bowls with gas and waited for leaks. None! On went the carbs, and apparently this situation is solved. Thanks again for the WEALTH of info.
    Kiwi 4d and gimpyshotrods like this.
  9. Jmountainjr
    Jmountainjr
    Just curious. While redoing the PV gaskets did you confirm that you have the correctly machined PVs?
  10. mdogg1950
    mdogg1950
    No, I didn't. But now I've got the knowledge in case I suspect trouble. Thanks to all.
