Technical 1950 Chevy and a box of parts
Discussion in 'Traditional Customs' started by BoxOfParts, Feb 4, 2024.
  1. SS327
    SS327
    Distributor don’t matter if it’s 6 or 12 volts.
    6inarow likes this.
  2. BoxOfParts
    BoxOfParts
    Thanks, ordering some points today.
    Toms Dogs and SS327 like this.
  3. BoxOfParts
    BoxOfParts
    Had to cut a wrench so I could tighten the upper starter nut. I am glad I put studs
    on the starter holes these starters are heavy.
  4. BoxOfParts
    BoxOfParts
    Fuel pump and beather are on ,
    Squablow, Okie Pete, 6inarow and 2 others like this.
  5. BoxOfParts
    BoxOfParts
    Plugs are in, coil is on. Going to order a oil pressure switch ,and if i cant get the screw off the points maybe a new distributor
  6. patsurf
    patsurf
    leave that in there!!..adjuster screw!!
    Moriarity, Toms Dogs and saltflats like this.
  7. saltflats
    saltflats
    from Missouri
    The screw is already out that holds the points. Joust slide it up the pivot shaft.
  8. BoxOfParts
    BoxOfParts
    Thank you guys, almost destroyed it!
    Installed the new points and gapped them at .019. Now I know what that screw does
  9. BoxOfParts
    BoxOfParts
    I put an oil pressure gauge on the side of the block. I want to make sure I have oil pressure before I start it - by priming the engine. Unfortunately the tool that I got does not fit my engine, so now I am in search IMG_4063.jpg
    Okie Pete and saltflats like this.
  10. tb33anda3rd
    tb33anda3rd
    don't forget a little lube on the cam follower on the points
  11. patsurf
    patsurf
    you will confuse him--he will now grease a 'lifter'.....
    Okie Pete likes this.
  12. BoxOfParts
    BoxOfParts
    Sad sad day ,put oil in the engine , getting ready to prime it and i cant get the oil pump shaft to turn. Thought my battery was weak on the drill so i put a screw driver and it did not want to turn. The engine was rebuild about 7 years ago was still in the metal crate we I got it. Going to take the engine out again and see what happen...
    Squablow and Okie Pete like this.
  13. TrailerTrashToo
    TrailerTrashToo
  14. tb33anda3rd
    tb33anda3rd
  15. BoxOfParts
    BoxOfParts
    Rust inside the pump.
    Im sure glad I tried priming the engine, cant imagine the damage it would have caused
    Squablow, Okie Pete and saltflats like this.
  16. BoxOfParts
    BoxOfParts
    It has been a long couple of nights ,but there is set screw that holds the pump in place . Is there anything i should know about it when its time to put the new pump back ?
  17. TrailerTrashToo
    TrailerTrashToo
  18. 50chevytx
    50chevytx
    No just make sure it’s in the hole and lock it down
  19. BoxOfParts
    BoxOfParts
    New pump is on!!!
    Cleaning up the oil pan ,got new oil pan bolts and running a die to clean the treads on the block
  20. BoxOfParts
    BoxOfParts
  21. BoxOfParts
    BoxOfParts
  22. BoxOfParts
    BoxOfParts
  23. saltflats
    saltflats
    from Missouri
    Maybe move the alternator to the other side of the swing adjuster bracket.
    SS327 likes this.
  24. BoxOfParts
    BoxOfParts
    I hope like this?
  25. patsurf
    patsurf
    SS327 likes this.
  26. BoxOfParts
    BoxOfParts
    The side cover was installed wrong, So I am thinking about getting a fancy chrome one lol
    Squablow, tb33anda3rd and Okie Pete like this.
  27. BoxOfParts
    BoxOfParts
    Just cant get a brake with this engine, oil pan gasket leaked. After cleaning all the surface area again I was looking inside the block making sure no debris got inside and notice some cam lobes pitted
    Squablow likes this.
  28. BoxOfParts
    BoxOfParts
    Got my camshaft back went with a regrind from Schneiders , they gave it a bump on the lift hope to get 5 more horsepower . Now going to work on the lifters and clean the lifters bores.
    Okie Pete and Squablow like this.
  29. Squablow
    Squablow
    You're having some tough luck on that "fresh" rebuild, but glad you're keeping at it. It's always a bit of extra effort to jump in where someone else left off, trying to figure out what the last guy did. Making progress though.
  30. RICH B
    RICH B
    What do you mean "going to work" on the lifters.
    Hopefully not the ones in that bucket; you should use new lifters on a fresh cam.
