Technical What's the Best Way to Clean Spark Plug Wires?
Discussion in 'The Hokey Ass Message Board' started by 5window, Jul 2, 2025.
  1. 5window
    5window
    Got a set of pretty shabby/mildewy/dirty wires on a '60's vehicle that I'd like to clean up. YouTube's mostly about WD40 while AI touts brake cleaner/carb cleaner. I'd like something that will last a while, not harm the ire insulation and won't fry my liver. I'd appreciate suggestions.
  2. fastcar1953
    fastcar1953
    Goop hand cleaner works for me.
  3. I’ve cleaned a lot of stuff with those tub-o-towels in the yellow bucket from oreilley’s.
    Blues4U and seb fontana like this.
  4. slowmotion
    slowmotion
    409 and an old T-shirt.
    alanp561 and Hot Rods Ta Hell like this.
  5. Dawn on a rag works pretty good If you got some really stubborn grease on them purple power works excellent just make sure to wipe it off fairly quickly and sometimes purple power will remove ink writing on plug wires I've never used it on some of those cool clear wires I don't know how safe it would be for those.
  6. chlsnk
    chlsnk
    Goop hand cleaner.
    ol'skool likes this.
  7. chevyfordman
    chevyfordman
    Simple Green
    seb fontana and CSPIDY like this.
  8. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Yep, I first tried 409 in the 70's (on yellow plug wires) and it worked so well, I've stuck with it for 50 years...
    slowmotion likes this.
  9. Clydesdale
    Clydesdale
  10. '29 Gizmo
    '29 Gizmo
    from UK
    Stick them in the dish washer when the wife is out.
  11. GuyW
    GuyW
    I used to wipe them down with a gasolined rag
    Special Ed and seb fontana like this.
  12. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    Simple Green Wipes have always worked well for me.
    seb fontana likes this.
  13. Clydesdale
    Clydesdale
    Put new ones on everytime you drive it........
    I hear @Moriarity might be able to help :D
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    down-the-road likes this.
  15. squirrel
    I can't remember ever cleaning a spark plug wire.
  16. 1971BB427
    1971BB427
    from Oregon
    I use Purple Power concentrated degreaser for a lot of cleanup. So I remove my plug wires and mix up some Purple Power 50/50 with water in a bucket. Just enough to get the wires coiled in the bucket and wash them with a rag. They come out looking new, and ready to put back on the engine.
    I buy PP in 2.5 gallon jugs and use it for cleaning my concrete floors, and dirty engine bays, or greasy parts. Mostly at lighter concentrations of 10 parts water to one part PP. But for tougher grime I go 50/50.
  17. 302GMC
    302GMC
    from Idaho
    Don't forget to re-polarize them when dry ...
    brigrat, alanp561 and slowmotion like this.
  18. slowmotion
    slowmotion
    Only the suppression models, solid cores are good to go.
    302GMC likes this.
  19. ClayMart
    ClayMart
    I'd say dish soap (Dawn) and water or maybe some of those "scrubs in a bucket" things. The cream style hand cleaner doesn't seem like a bad idea either, especially if it has lanolin in it. Maybe rinse with water and spray with WD40 to displace any moisture that may be trying to wick its way into the insulation and boots. For a finishing touch wipe everything down with a very light coating of dielectric grease.
  20. RodStRace
    RodStRace
    I was a fool and bought those SS Yellow wires. Before I got smart and threw them away, I spent way too much time trying to keep them pretty. That and doing other people's in the shop taught me that as usual, milder is better (soap/spray cleaner) and when you go stronger (full strength simple green, carb cleaner) the wires were very sticky and much easier to get dirty and stained. You can wipe them with a rubber/plastic dressing to fix this. I try to keep leaks at bay and use good ol' Black wires now.
    deathrowdave likes this.
  21. 2devilles
    2devilles
    If they're really dirty, I wet down paper towels with WD-40 and scrub them with that. I made myself white Taylor spark plug wires for the 390 in one of my Cadillacs, and that's about the best way I could keep them clean. (And I'll never do white plug wires again).
    ClayMart likes this.
  22. 2OLD2FAST
    2OLD2FAST
    from illinois
    You've never had leaky valve covers on a SBC & wiped the wires off to work on them , must lead a charmed life ...
  23. 5window
    5window
    Thanks to all.
  24. 5window
    5window
    At the price of dielectric grease, it probably would be cheaper to buy new wires ! :)
  25. ClayMart
    ClayMart
    What??? :confused: You don't already have a half used tube in the back of a drawer in your tool chest? Plus you can spread it really, REALLY thin.
    :rolleyes:
    alanp561 likes this.
  26. squirrel
    either that, or my memory is gone....
  27. RockyMtnWay
    RockyMtnWay
    If memory serves, Wd40 works for taking off the ‘bold’ advertising print as well.
  28. 2devilles
    2devilles
    Never have had that happen on 6 different cars worth of wires, but I only run Taylors (at least when they were made in the USA, which I believe they're not now since they got bought out by Pertronix.)
  29. Bandit Billy
    Bandit Billy
    I buy these every time I check out at summit. One abrasive side, one smooth. It will take automotive paint and clear off your skin without killing you. I use them to clean my tools after a messy job, and I use them to clean my spark plug leads (they don't remove the lettering like thinner will. I recently used them to clean my car remote fobs which they did without removing the icons. I have one in my truck, one in my trailer and a couple in the shop. Smell like oranges.
    deathrowdave, brigrat and alanp561 like this.
