Hot Rods The car I've been waiting for
Discussion in 'The Hokey Ass Message Board' started by wheeldog57, May 8, 2024.
  1. wheeldog57
    wheeldog57
    Get it outside and look at it from a distance is the only way 20250322_133159.jpg 20250322_133226.jpg
    Tim, adam401, lewk and 11 others like this.
  2. wheeldog57
    wheeldog57
    Been fitting and welding the cowl to the subrails. Got both sides tack welded to secure it. Passenger side got more welding to the subrails extension then fitted the cowl patch panel, uggh! Much more to do here but I'm 20250327_182708.jpg 20250327_182714.jpg 20250328_185508.jpg 20250328_203740.jpg 20250328_204449.jpg 20250328_204832.jpg making progress
  3. wheeldog57
    wheeldog57
    Not easy fitting and re-fitting. Cutting and more fitting. Stand back and look, more cutting and fitting 20250329_114122.jpg 20250329_123709.jpg 20250329_183311.jpg
    Nothing fits, every piece needs massaging
  4. J. A. Miller
    J. A. Miller
    from Central NY
    Looking better every day!!
    porkshop and wheeldog57 like this.
  5. Jacksmith
    Jacksmith
    from Aridzona
    Yep, and when you're finished, if no-one can see the work that was done... it's perfect!
  6. wheeldog57
    wheeldog57
  7. wheeldog57
    wheeldog57
    Cut down 37 truck dash fits pretty good and even looks kinda cool 20250401_201506.jpg 20250406_185514.jpg 20250406_194140.jpg
  8. flamedabone
    flamedabone
    That little thing is gonna be a whole car one of these days real soon. Keep it up and don't catch the carpet on fire.
    -Abone.
    wheeldog57, porkshop and Thor1 like this.
  9. wheeldog57
    wheeldog57
    Wheel well and quarter patch in. Mucho grinding in my future 20250413_104821.jpg 20250413_104808.jpg 20250413_104757.jpg
  10. wheeldog57
    wheeldog57
    Been working alot but had a couple hours of quality time with the 33 today 20250504_172213.jpg 20250504_191808.jpg 20250504_191841.jpg
    Continuing sub rails to body work. While I'm mig welding these tight areas I am thinking about how tough it must have been for a teenager in the 50s to braze a channeled car, damn!
    bchctybob, catdad49, 40FORDPU and 6 others like this.
  11. Jacksmith
    Jacksmith
    from Aridzona
    Lookin' more & more solid each time!
    4274SPEED, wheeldog57 and porkshop like this.
  12. wheeldog57
    wheeldog57
    Needing to chop up the dash and bit more to get it to fit. Truck dash is straight across on the top and 33 car is curved. I have a plan- let's see if it'll work 20250505_200143.jpg 20250505_200149.jpg 20250505_200157.jpg
  13. wheeldog57
    wheeldog57
    Gathering much needed goodies is part of the fun for me. Visited with old pal Pete, he's got model 40 stuff 20250515_155850.jpg 20250515_194256.jpg 20250515_194323(0).jpg
  14. Looking awesome so far. Keep the updates coming.
  15. wheeldog57
    wheeldog57
    Got an original radiator from a fellow Snapper for mock up. Turns out the radiator mounts on brackets in front of the cross member. I don't have those. I called and went over to another friend's house, he's got a beautiful 34. I measured up where the radiator is supposed to go and made a crude drawing. Anyway - measure, cut, grind, bend, fit, cut, bend, clamp, fit, stand back and look. More fitting to do 20250516_151242.jpg 20250516_151247.jpg 20250516_151301.jpg 20250516_151305.jpg 20250516_171523.jpg 20250516_171603.jpg
  16. Looking good Ron!
    porkshop likes this.
  17. wheeldog57
    wheeldog57
    Mocked up a 34 shell and then put on the chrome hood. Mike brushed it black. It fit pretty good and I decided to strip the paint off- oh my that was a really good idea. All shiney and smooth. 20250517_143219.jpg 20250517_143235.jpg 20250517_143259.jpg 20250517_195138.jpg 20250517_193801.jpg 20250517_193742.jpg 20250517_193729.jpg
  18. The37Kid
    The37Kid
    Looking good! Are the new doors for patches? I would think the doors that came with the body would fit best.
    Bob
  19. wheeldog57
    wheeldog57
    @The37Kid those doors are for the next build, a 3 window
    simplestone and porkshop like this.
  20. The37Kid
    The37Kid
    OK! You can never have too many future projects.
  21. choptop40
    choptop40
    Minotti Style
  22. wheeldog57
    wheeldog57
    I moved the car over to the other bay to make room for the roadster. I have a lot of fixing to do on this side. 20250527_192527.jpg 20250527_192507.jpg 20250527_192457.jpg 20250527_192446.jpg 20250527_192435.jpg
  23. wheeldog57
    wheeldog57
    In the last couple pictures you can see the last foot of bead is cut off and right above that they "relieved" the quarter at the deck lid opening. This along with the huge missing part in front of the wheel well really messed up everything.
    Here I spent a few minutes lining things up better. Next is measuring and tack welding- lots of measuring and tack welding 20250528_180653.jpg 20250528_181334.jpg 20250528_181343.jpg
    bchctybob, catdad49, drdave and 4 others like this.
  24. wheeldog57
    wheeldog57
  25. wheeldog57
    wheeldog57
    Doesn't look like much but this has already made a difference. Very thin and wavy metal from previous work. Small steps here, i cannot afford to make it any worse than it was. 20250529_203310.jpg
  26. Jacksmith
    Jacksmith
    from Aridzona
    Baby steps... progress is progress!
  27. wheeldog57
    wheeldog57
    I tore into the sub rails on the driver side tonight. Previous owner had overlapped plate (2 pieces) from cowl to B pillars. This was tack welded and it came out relatively easily. Lower cowl patch and below the door panel are barely tacked on. Lots of measuring and fitting before I weld anything. Tonight was cut out stuff, step back and look. Sometimes you don't get a lot done but I am making progress
    bchctybob, rod1, drdave and 6 others like this.
  28. wheeldog57
    wheeldog57
    The B pillar is twisted to the rear, door side hinges bent a little. I asked Frank to come by and take a look. He said I bet the door opened while driving- AHA!
    Today I pulled the door off, pulled pillar forward and added a gusset to the front side of the B pillar. 20250703_135523.jpg 20250703_142436.jpg 20250703_144517.jpg 20250703_144537.jpg
    bchctybob, porkshop, rod1 and 8 others like this.
  29. wheeldog57
    wheeldog57
    Need to heat up and bend lower door side hinge back and then I think that'll get things much closer.
    I ran out of MIG wire- that 11lb spool lasted a very long time.
    porkshop and NoSurf like this.
