Projects 1938 plymouth coupe project
Discussion in 'The Hokey Ass Message Board' started by gas man, May 7, 2025.
  1. gas man
    gas man
    from socal
    So what does everyone think about this idea? I have a chevy 6 inch drop axle. I got a sleeve and spacer made so the axle end is the same size as my plymouth end. Any reason I shouldn't install my plymouth spindle on this ? 20250624_171827.jpg
    das858 and Deutscher like this.
  2. earlymopar
    earlymopar
    Are the spindle centerline distances the same between the 2 axles?
  3. If the camber angles are the same you’re good
    But using a gm spindle and changing the bolt pattern isn’t difficult
  4. gas man
    gas man
    from socal
    Yes, extremely close.
    I was going to go all gm but I wasn't sure about the steering arm. Figured I get the sleeves made by a friend for free and at least give it a try. Trying to save money where I can.
  5. gas man
    gas man
    from socal
    I got my front end mocked up. I need to weld the leaf spring pads to the axle still. My king pins fit great. I pulled the 2nd and 4th leaf from the bottom and dropped the motor in to get an idea of ride height. Chevy 6 inch drop axle sleeved for plymouth spindle.
  6. RodStRace
    RodStRace
    It looks like it's camera angle, but that looks like the top of the tire is kicked out. Of course, the top of the engine looks kicked out the other way, so that's why I started with that.
  7. gas man
    gas man
    from socal
    I just went and checked with my super sophisticated method. Is this good enough? I would ***ume it is but then again im learning as i go from all of you. 20250629_191820.jpg
    Deutscher, osage orange and RodStRace like this.
  8. RodStRace
    RodStRace
    Good enough for a roller! :p
    I kind of figured it was close, but the pic didn't help.
    If anyone is annoyed by a tenth of a degree, they can chip in for the axle bend at the alignment shop! :D
    osage orange and gas man like this.
  9. They will kick out some without all the weight.
    osage orange likes this.
  10. gas man
    gas man
    from socal
    C notch is in.
    Deutscher, tr_rodder and bobss396 like this.
  11. choptop4
    choptop4
    20250627_082404.jpg 20250627_082404.jpg 20241212_134737.jpg making skirts for mine right now. Don't know if I'll use them, but make them before paint.
  12. Onemansjunk
    Onemansjunk
    from Modesto,CA
    This is my favorite part.
  13. gas man
    gas man
    from socal
    Alright, I finally see light at the end of the tunnel on the rear trailing arms. I decided to go with c10 arms and make new holes for the u bolt. I cut a tube in half so the arms are still like the original. Doing this has really slowed me down and taken more time then it should have. I installed a crossmember with some reinforcement pads at the ends. I didnt go all the way across the frame but if I should, just let me know. Next is airbag mounts and the tabs for the front of the truck arms. I should pick up speed after that. 20250731_172131.jpg
  14. MERCURYGUY
    MERCURYGUY
    Looks pretty good to me and a lot better than the 32 roadster I began many moons ago
  15. Ruben Cruz
    Ruben Cruz
    Don't put big money into it if you plan on selling these mid 30's Mopars don't get Chevy money....
  16. gas man
    gas man
    from socal
    Made some progress this labor day, and boy did I labor on this 100 degree day. Nothing fancy here. Still need to add the pan hard bar. If you see something I should change or add please let me know.
  17. SuperWildcat
    SuperWildcat
    Nice start for a project. I really like the mid to late 30's Dodge and Plymouth Coupes.
  18. gas man
    gas man
    from socal
    I got the engine and t5 transmission in. Installed new head gasket and new gaskets all around. Im going with a spare carter yf carb i had laying around. Converted to 12v negative ground. I got the engine to run for about 10 seconds by filling the bowl with fuel. I need to add a fuel cell in the trunk. I installed new rubber body mounts. Pertronix ignition should come in the mail anyway, im gonna ditch the points ignition i think. I just started looking at the brakes tonight. My goal is to drive it about 2 miles around dec 1st to get my Christmas tree with it. Gonna full speed for the new few weeks.
    RodStRace, bobss396 and tr_rodder like this.
  19. gas man
    gas man
    from socal
    I got an aluminum radiator barely in, and I mean barley. Ran new brake lines, new pads , new wheel cylinders. I picked up some white walls , coker , 6.00x16. Next up is making my driveshaft, buying a fuel cell for the trunk because the stock tank sits to low in my opinion. IMG_20251125_184340_479.jpg
