Technical T5 and a flathead and a rear
Discussion in 'Traditional Hot Rods' started by gdrummer, Jul 5, 2025.
  1. gdrummer
    gdrummer
    hey ya'll,
    so i'm planning a T5 swap into my 37 ford panel delivery. when i do the swap, rather then use the stock rear and wishbones i'm planning on changing the rear to a ford 8" and was thinking about a 4 link set up. so i would like some feedback as to what would be the way to go. triangulated, panhard bar, or a watts setup. also, how about spring set up. coilovers, leaf springs, shocks, bags? so many choices i was hoping for some opinions from folks who have done this swap before. wanting to make the changes so the truck will be a bit more friendly on the highway.
    thanks
    PS currently the truck currently has a 59AB but i have a 8BA i'm building that will be going in as well.
    cheers!
    winduptoy and Toms Dogs like this.
  2. Blues4U
    Blues4U
    from So Cal
  3. Wanderlust
    Wanderlust
    There’s your answer right there, unless you really want to make it more complicated than it needs to be
  4. tjm73
    tjm73
    Parallel leaf will get the job done. Simple and cheap. If you want to go with a multi-link type suspension I don't think you can beat a 3 link with a panhard bar.
    winduptoy likes this.
  5. gimpyshotrods
    gimpyshotrods
    Pete and Jakes ladder bars.
    Stock rear leaf, or an aftermarket replacement for the same.
    Aftermarket spring hangars.
  6. krylon32
    krylon32
    from Nebraska
    I've done quite a few customer Fat Fender ch***is with the 8 inch Maverick rear and a Ch***is Engineering Parallel rear leaf kit. It's a bolt in and they've worked good. Tooting my own horn a little but if you use my Cornhusker R&C T5 kit and a 39 pedal ***embly the FH-T5 install is also easy. For the center X give 40ragtopdown on here a try. His X member kits fit and are priced right.
  7. joel
    joel
    Yep; that's how I'd do it. Actually did it on my avatar except sbc instead of FH and Doug Nash trans instead of T5.
    Current project is '41 p/u FH, t1740 Trans open drive to banjo rear with buggy spring.
  8. gdrummer
    gdrummer
    hey thanks for the replies.
    i like the idea of the parallel leaf set up. it looks like its easier and cheaper than the 4 link.
    how is the quality on the speedway kit?
    thanks again!
  9. krylon32
    krylon32
    from Nebraska
    Which Speedway Kit? When I build a customer ch***is I look to quality not always price.
  10. Okie Pete
    Okie Pete
    Ian Russel used Speedway parallel spring kit on his buddies car . It also had a OT front suspension grafted on .
    Use what your wallet can handle.
    Maybe find a donor car and remove the springs, mounts and rear axle . The spring pads on the axle will probably need to be relocated. Just keep a build sheet in the glovebox for future reference.
  11. Vic Walter
    Vic Walter
    Plans for exhaust ?
    Parallel 4 bar + panhard allows good room for mufflers and tail pipes over the axle and out the back.
    Tri-angulated 4 allows good room for mufflers but can be tight for tail pipes over the axle.
    Draglinks + panhard do not leave much room for mufflers.
    Whatever bars you use, be sure to use rubber/neoprene joints, not heim / metal on metal.
    Watts link is cool but is unnecessarily more complicated.
    Coilovers are very common just be sure to not to use to heavy a spring rate springs.
    Air bags offer lots of adjustability.
    Traverse springs are more traditional.
  12. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Built a nice 36 Ford with Mustang parallel leaf springs ,tube shocks, nine in rear, and 5 spd trans. Had to reposition the hole only in the main spring to get it centered in the frame frt to rear. Made all of my own bracket rt frt and rear. 8 in will work fine if u want the 5 on 4.5 pattern(small Ford,Mopar) Rear of frame will need to be boxed to have a nice,strong base to mount your shackles to,but also boxed the frt mount ***embly as well! IMG_2603.jpeg IMG_2411.jpeg IMG_2414.jpeg
    winduptoy, Okie Pete and Deutscher like this.
  13. gdrummer
    gdrummer
    so i just went to order the rear leaf spring kit from speedway and it's on backorder with no date of when it will be back in stock.
    anyone know of another supplier that might have it?
    thanks
  14. joel
    joel
    Try Heidts/ Ch***is Engineering rear leaf spring kit with shock mounts and shocks.
  15. Also used CE leafs.
    Super EZ.
    I also like the P&J ladder bars.
    both get the job done.
  16. 05snopro440
    05snopro440
    If you go for ladder bars, the ones I got for my A from Roadster Supply are beautiful.
    Glad I bought them over Pete and Jakes just for the forged parts alone. Same price.
    PXL_20250403_144530947.MP.jpg PXL_20250403_144536016.MP.jpg PXL_20250403_144538474.MP.jpg
    Deutscher and winduptoy like this.
  17. tjm73
    tjm73
    Leaf spring setup doesn't seem like it'd be that hard to engineer. Find a small pickup that weighs about the same and go from there. Ford Rangers were plentiful from '83-2011. They weighed less than 3000 lbs to 38000ish. Might be a good source. Easy to find. Cheap. Easy to service if needed.
