Projects 1956 Chevy Carryall new wood body
Discussion in 'The Hokey Ass Message Board' started by mamllc, Mar 17, 2025.
  1. G Baese
    G Baese
    Brilliant joinery!
    Its a big job but you are kicking ash!
    All the best from an appreciative violinmaker.
    GB
  2. Okie Pete
    Okie Pete
    WOW amazing craftsmanship thank you for sharing
    pineknot4 likes this.
  3. mamllc
    mamllc
    The three front pieces have been copied and fit to the truck. Still some cleaning up to do but that will wait till the side rails are made. IMG_5780.JPG IMG_5781.JPG IMG_5783.JPG IMG_5786.JPG IMG_5814.JPG IMG_5817.JPG
  4. patsurf
    patsurf
    winduptoy and porkshop like this.
  5. Toms Dogs
    Toms Dogs
    from NJ
  6. The37Kid
    The37Kid
    I've never seen wood "Machined" are the cutters the same as metal work or a totally different deal. Thanks for taking us along for the ride.
    Bob
  7. What a fantastic build. Woodworking is a lot more of a stressful endeavor as you only get to cut once. Please keep the updates coming on this build. Always wanted to build a woodie hot rod.
    winduptoy, porkshop and tractorguy like this.
  8. mamllc
    mamllc
    Not really much different than cutting with a router, just more controlled. I have a vertical mill that I cut a lot of wood on. The cutting inserts I use are made for cutting aluminum. The tooth profine is very similar to a tool designed for wood cutting, the main difference is speed, you turn the tool faster in wood.
  9. TRAVLR
    TRAVLR
    Amazing... absolutely amazing!
    porkshop likes this.
  10. hotrodA
    hotrodA
    WOW! Amazing craftsmanship! How did you learn these skills?
    Bill's Auto Works likes this.
  11. mamllc
    mamllc
    Learned as a result of not being smart enough to say NO! Someone asked me if I could build a wood body for a car he was considering buying and I said I could, without really knowing weather I could or not. He called my bluff and bought the car, and I had to figure it out. I'm not aware of any place that teaches this kind of woodwork, but neither am I aware of any of todays youth that are interested in learning it.
  12. mamllc
    mamllc
    First car, before and after. Did not reuse any of the original wood. Picture 002.jpg Recovered_JPEG Digital Camera_2287.jpg
    rod1, 41 GMC K-18, Baumi and 24 others like this.
  13. Deeluxe
    Deeluxe
    from island
    This. Is. Rad.
    Woody wagons have been on my mind!
    Favourite current build.
    winduptoy likes this.
  14. 1971BB427
    1971BB427
    from Oregon
    Like a giant gun stock duplicator! Really extremely nice work!
  15. GuyW
    GuyW
    My question is: is the truck frame rigid enough that the wood won't be "worked" / flexed during driving?
    ...that would be a shame...
  16. TFoch
    TFoch
    Excellent craftsmanship!
  17. woodiewagon46
    woodiewagon46
    from New York
    If anyone on this site is in the Connecticut area, this Saturday July 12th is Woodies at Mystic Seaport. Woodies will be on display on the Mystic Seaport Village Green from 10:00AM until 3:00PM.
  18. brigrat
    brigrat
    from Wa.St.
    Had to look, glad I did, thanks 4 sharing!
  19. mamllc
    mamllc
    The frame on this truck is at least as rigid as anything the wood station wagons were built on so I don't expect any problems. The wood bodies definately do move, They tend to be somewhat "creaky" when driven. I try to isolate the wood parts as well as I can to try to keep it to a minimum, but it's still there.
  20. ClayMart
    ClayMart
    It still strikes me as slightly odd to think that at one time auto body repair shops probably had a skilled carpenter or wood worker on staff. Or were these kinds of repairs handled by the metal workers as well? Did the auto makers supply some "rough fit" wood framing, or was everything custom made on-site from stock lumber?
  21. mamllc
    mamllc
    Well.......I know Ford had service parts available, at least for the Iron Mountain cars. Probably ran enough parts while the line was set up to build the cars plus some spares. I've seen pictures of the inside of the Iron Mountain plant, think of the number of individual parts in a wood car body and a seperate line for each one such that you could put a rough piece of wood in one end and spit a finished part out the other. As far as the coach builders, and there were quite a few of them, building bodies for everyone but Ford, I really don't know. It would make sense that service parts might have been part of a contract. As far as the skill level of the guys actually doing the repair work, I guess that would depend on the owner of the shop. The repair work that I see tends to be of a poor quality, but a repair made from factory service parts should appear to me to be all original. I doubt that any dealerships or auto body shops were set up be able to repair wood bodies from scratch, once the service parts were gone. I suspect that if you wrecked one you were on your own.
    Bill's Auto Works and ClayMart like this.
  22. patsurf
    patsurf
    can't believe
    def time for someone to chime in here-where is some old timers who worked in bodyshops in the 50-60's and had to fix some?--JUST asked tardel this exact ? a couple of days ago!
  23. RodStRace
    RodStRace
    I'd guess that there were more wood craftsmen across the country in the first half of the century.
    I'd also guess that Woodies in general were wealthy or business owned, higher cost vehicles that required more maintenance and upkeep, meaning that they had connections in place. It would be interesting to see insurance data on them, as far as miles traveled, accident rates and value over time (depreciation).
    The change from new prized possessions to cheap surf wagons was a different arc than the same YMM sedan. By the 60s, they were already either at the bottom of value due to condition or a niche collectable.
    lothiandon1940 and ClayMart like this.
  24. mamllc
    mamllc
    The major roof parts are done for now. I'll install the bows and slats after the quarter panels are built.
    rod1, Okie Pete, 41 GMC K-18 and 19 others like this.
  25. RMR&C
    RMR&C
    from NW Montana
    Outstanding!
    51 mercules and porkshop like this.
  26. patsurf
    patsurf
    427 sleeper likes this.
  27. mamllc
    mamllc
    When it leaves here it will be fully built and ***embled but in bare wood. The customer is going to handle the finishing.
  28. patsurf
    patsurf
    we will all be waiting for those pics as well as the in process!!
    427 sleeper and mamllc like this.
  29. rockable
    rockable
    You sir are a top shelf craftsman! Can't wait to see how this turns out!
    lothiandon1940 and 427 sleeper like this.
  30. ronzmtrwrx
    ronzmtrwrx
    I am in awe of your workmanship. That is some fine work.
