Projects Traditional Banger Build
Discussion in 'Traditional Hot Rods' started by reffiesj, May 17, 2023.
  1. reffiesj
    reffiesj
    V8-m - I agree with you - I wound up using some material I had around the shop and I think they will be fine for the upcoming RPM National drag races which require them to be installed but I will redo them in a thicker gauge for use on the street.
    chryslerfan55, winduptoy and V8-m like this.
  2. reffiesj
    reffiesj
    Overflow tank installed and drum retainers painted. Getting close to being fully prepped for RPM Nationals and Antique Nationals!
  3. reffiesj
    reffiesj
    Punch list just about complete.
  4. reffiesj
    reffiesj
    Made it out to RPM Nationals on Saturday. Unfortunately, Antique Nationals on Sunday was cancelled due to wet weather. Had a great time at the track even though I was likely the slowest car out there - thankfully, nothing broke on the car in its inaugural outing.
    I was running gravity feed which was a mistake - fuel feed was cutting out about 2/3rd of the way down the track even with a full tank. I am going to install a fuel pump and swap over to dual carbs so I am hopefully a little more compe***ive the next time out.
    Someone left the key chain for me in the car while it was sitting in the pits - love it!
    IMG_3006.jpeg IMG_3007.jpeg IMG_3008.jpeg IMG_3012.jpeg IMG_3013.jpeg IMG_3016.jpeg IMG_3023.jpeg
  5. Mikko_
    Mikko_
    from Sweden
    Looks like a fun time.
    PGA STUDIOS, winduptoy and CruznArt like this.
  6. reffiesj
    reffiesj
    Finally got around to getting the fuel pump installed. Decided to put it on the firewall on the p***enger side. Might paint it black down the road so it is less noticeable. Next up is converting the intake over to dual 81s - need to order some hardware to fit the fuel block - nothing in my stash fit…
  7. Rand Man
    Rand Man
    I like what you’ve done with that one. I had a model C banger engine collected and wanted to do something pretty close to this. You’re pulling off a good build here.
    Outback, winduptoy and chryslerfan55 like this.
  8. Dan from Oakland
    Dan from Oakland
    Info on the fuel pump please! How much pressure does it supply?
  9. reffiesj
    reffiesj
    Thanks Rand Man - I have a B block that I am going to build up once this engine is where I want it to be. Thinking of building the B block with an overhead valve setup but still TBD.
    Dan - it is a Facet low pressure pump - no need for a regulator. See pic below.
    Outback, chryslerfan55, GuyW and 3 others like this.
  10. reffiesj
    reffiesj
    Got the intake, carbs and fuel lines installed. Decided to go with a T connection since the fuel block was making the firewall really crowded. Got the carbs synced and mixture in a reasonable place. Will need some fine tuning. Linkage needs to be reworked quite a bit so that is next up on the list.
  11. Mikko_
    Mikko_
    from Sweden
    Looking real good.
  12. reffiesj
    reffiesj
    Thanks Mikko.
    Reworked the linkage - going to give it a road test tomorrow to see how it performs.
    hotrodfil, Hotrodmyk, Outback and 8 others like this.
  13. reffiesj
    reffiesj
    The 3/16” rod was too small a diameter to handle the force from the pedal and was deflecting. Reworked it with heavier diameter (used an old radiator support rod). Works much better but I am getting a bit of an on / off action with the gas pedal - I think I may have overdone it with the return springs - have one on each of the throttle arms on backside of carb, the two accelerator pump arms and the long spring on the linkage arm plus the spring on the pedal ***embly itself. Does anyone have any suggestions on the geometry or examples of how they have hooked up dual carbs using a model a pedal and zepher intake - any suggestions appreciated. When it is “on” it runs like a scalded dog.
  14. Dedsoto
    Dedsoto
    from Australia
    Is the pedal ***embly moving freely? they can bind up if never oiled. I'd also be tempted to try flipping the bell crank up the other way to change the ratio.
  15. reffiesj
    reffiesj
    Thx Dedsoto - flipping the bellcrank made a huge improvement. Pedal modulation is terrific now.
    woodiemike, J.Ukrop, Outback and 5 others like this.
  16. trikejunkie
    trikejunkie
    from Scotland
    Outback and winduptoy like this.
  17. reffiesj
    reffiesj
    Finally got around to bracing the side skirts - need to get them painted but they eliminated all the noise from vibrations while running - made a huge improvement to my sanity…
    Ragged Edge, Jeff34, Outback and 4 others like this.
  18. reffiesj
    reffiesj
    Working on some mounting plates to get the front shocks set up. Figure that was easier and quicker than welding up the egged out holes in the frame.
  19. reffiesj
    reffiesj
    Finished up installing the rebuilt shocks on driver’s side and took it for a test run. They made a huge difference in ride / stability.
  20. reffiesj
    reffiesj
    Everything painted and back in place. Will be at RPM Nationals at Santa Margarita Ranch in September to see how she goes w fuel pump and dual carbs. Post-races, I am planning to swap out the rear spring for a reverse eye T spring, swap the gearbox over to a 39 and maybe put an F100 steering box in while I have the pedals out.
  21. Jalopy Joker
    Jalopy Joker
    Deutscher, reffiesj, GuyW and 2 others like this.
  22. reffiesj
    reffiesj
    Made it up to Santa Margarita Ranch - curious how she goes tomorrow. IMG_3362.jpeg
    Jeff34, woodiemike, GuyW and 10 others like this.
  23. reffiesj
    reffiesj
    Great time today out at the RPM Nationals at Santa Margarita Ranch. Car was a lot quicker than the last outing and ran well but ultimately lost in the second qualifying round to a much lighter race prepped Model T frame and bodied car.
  24. winduptoy
    winduptoy
    [​IMG]looks like you had fun...it is a great venue...I was planning to be there this year but......
    looks like you got a great back shot of @patina steve with his hand on his hip
    your car is certainly a looker
  25. reffiesj
    reffiesj
    Finally got around to getting things rolling on the gearbox upgrade.
  26. reffiesj
    reffiesj
    Got a little bit more clean up and paint prep done today.
    winduptoy, Deutscher, CSPIDY and 2 others like this.
  27. reffiesj
    reffiesj
    Santa brought a vintage plate - looks so much better.
    winduptoy, Outback, Jeff34 and 6 others like this.
  28. reffiesj
    reffiesj
    Stripped down the 39 transmission. Getting the input shaft out was a bear - cluster gear seemed to not be dropping quite enough but it finally came loose. Figured if I needed to swap out the clutch shaft for the Clings version I might as well throw on a new coat of paint as well.
  29. AmishMike
    AmishMike
    You might remember my previous comments. I see your light reflecting floors, not a speck of dust or dirt. Clean towels under parts. New cooking trays hold parts. Clean white painted walls. It must be nice to work in a hospital operating room. Can I schedule a tour of your operating garage?
    Outback, woodiemike, GuyW and 3 others like this.
  30. reffiesj
    reffiesj
    AmishMike - you are exposing my OCD…
