Projects The "Red '34". 1934 Ford 5 window project.
Discussion in 'The Hokey Ass Message Board' started by flamedabone, Dec 1, 2024.
  1. flamedabone
    flamedabone
    Couple of knick knacks before this roof cutting party. The FlamedAbone Pretty Much Universal Steering Column Drop Kit. (tm)
    The stock dash puts the speedo just a bit too far left to be centered with the steering wheel.
    Not moving the column, so...
    If you move the dash insert, then you have to move the glove box hole or the whole thing will be ***-eyed.
    And, it's in there. Hard to take a good shot of a dash, so just imagine it looks pretty OK.
    Speedo is now pretty close enough to dead nuts.
    The old alternator bracket was bugging the **** out of me. I got it down nice and low, but I was going to have to run an electric fuel pump, which I am not a huge fan. So, I built another set up that allows the stock pump and the alternator to co-exist.
    Up a bit higher than the old one but it misses the pump by a good bit.
    Fortunately, that ugly ******* is pretty much covered by the fender apron.
    I think that's it. Next pics should be *******.
    -Abone.
    RMcCulley, Stogy, Deutscher and 25 others like this.
  2. Robdski
    Robdski
    *** eyed is a term I have never heard. Very funny!
    Your fixes are far from *** eyed.
    Nice solution to the dash and alternator.
  3. RodStRace
    RodStRace
    Looks like that lower rad hose is going to be a lot happier.
  4. flamedabone
    flamedabone
    This is fixin to be an *** load of pictures and all of the "don't chop it" guys should turn back now.
    Somewhere along the line, the roof got a fake soft top kit.
    Held on by 76, 843 rivets.
    Pretty decent roof opening underneath.
    Last chance...spoiler alert...
    Modern 2 inch tape doesn't measure 2 inches anymore, so you have toss in a little pinstripe tape or you might end up with a sissy chop rather than the 4 big ones.
    There are lots of different ways to cut a 34 and lots of fancy ways to do the rear window, but I'm a bit of a caveman, so there you go, right through the middle.
    Way better already.
    There are a couple ways to do the quarter window and this is the point where you have to make a choice. For this chop, I lined up the very rearmost edge of the roof.
    That method, like all the rest has some consequences. Now your B pillar doesn't line up.
    But here is where the magic happens. Looks like a bold move, but it is actually pretty simple.
    See, that wasn't that bad after all.
    And that gets the rear section in its new forever home.
    Here is one I didn't see coming. The stock roof had a pretty big gap between the A pilar and the door top, but when I lined up the roof forward and the door backwards, it made it ever bigger. Yikes!
    Moved a chunk of the roof and added a bit to the leading edge of the door top and she's all better.
    This style of chop leaves the roof body line a bit goofy.
    Cut that ****er out and move it forward.
    The rear window gets a bit buck toothed.
    Same deal, cut out a skooch it over.
    Some of you sharp eyed HAMBers noticed the p***enger door was a '33.
    Now identifies as a '34.
    Tacks ground.
    Finished 1/4 window.
    Everything needs finish welding and a bit more metal work, but this is the general idea.
    Done for the day.
    3/4 front.
    Everybody has their own opinion on what a chop should look like, but this one ended up about right for what I was going for.
    Next up, garnish moldings.
    See ya, -Abone.
  5. lo c dan
    lo c dan
    I was just wondering how this was going. . Dig those wheels
    Just Gary likes this.
  6. flamedabone
    flamedabone
    Dan it is very handy that you popped into this thread. For those that don't know, our very own Lo C Dan is the baddest *** louver guy in the country. Fortunately, he is only an hour and change from me in Lexington SC. Look him up, he's a bad mofo and his louvers are perfect. His louvers are the only straight thing on the car.
    -Abone.
  7. lo c dan
    lo c dan
    Thanks for the props. . Happy, repeat customers keep the dream alive. .Thank you sir!
    Stogy, Deutscher, 427 sleeper and 3 others like this.
  8. Tim
    Tim
    from KCMO
    Looks sporty I dig it.
    Stogy and chryslerfan55 like this.
  9. Robdski
    Robdski
    Do you ever sleep?
    Perfect chop, clean roofline too.
    Excellent!
  10. jim snow
    jim snow
    Nailed it. Snowman ⛄️
    Stogy, chryslerfan55 and pprather like this.
  11. drdave
    drdave
    Plenty solid chop right there! I really like them with the door windows reasonably parallel. When the tops and the bottoms of the windows start going at different angles to each other it kinda starts looking wonky to me. Nice job!
  12. panhead_pete
    panhead_pete
    Nicely done! Not that its worth anything, for a 3W I love seeing the windscreen laid back, on 5W this way looks better to me. Excellent! Was worth the wait to see this done!
  13. HOTRODNORSKIE
    HOTRODNORSKIE
    Like it, I gave my 35 olds a haircut and it's never as easy as it looks nice job.
  14. akoutlaw
    akoutlaw
    Looks great! Keep the pics coming!!!
  15. What a great way to chop the roof. As always, keep up the great work and posts.
  16. Just Gary
    Just Gary
    Beautiful! The chop looks su****iously like the 554 Fuel Coupe's. :cool::cool::cool::cool:
    chryslerfan55, Thor1 and 427 sleeper like this.
  17. flamedabone
    flamedabone
    That is one of the cars I keep in the back of my mind at all times.
    -Abone.
  18. brady1929
    brady1929
    Love the chop.
    Stogy likes this.
  19. RodStRace
    RodStRace
    Gotta chop it enough that you don't mistake it for a Plymouth, right?
  20. 59sedandelivery
    59sedandelivery
    NOW THAT LOOKS BAD***!!!!!!!! love it...
    Stogy, chryslerfan55 and 427 sleeper like this.
  21. flamedabone
    flamedabone
    The hero part of the chop gets done in a weekend and you stand back and think about how cool you are. But, there is another good three or four weekends of mindless tiny patch panels, meticulous welding, grinding and shaping. Some of it, like the roof skin and garnish moldings aren't too horrible, so here they are in all their mediocre glory.
    A 1995 Caprice gave its one and only roof to live on in something a bit cooler.
    Trim it just a tiny bit larger than the hole.
    Weld that ***** in there. Yea, I know the hard core traditionalists will accept nothing but an original roof, but I did that on the last one and will again on the next one. Just not this one.
    A kind HAMBer from Cleveland, Ohio came across with a nice new windshield frame.
    On to the pile of garnish moldings.
    The 1/4 window moldings are extras from my old '36 coupe, which are pretty close. I'm sure there is a '36 guy cursing my name right now. Real sorry.
    See? Fits right in there.
    I like to cut the door garnish at the corners.
    If you do it right, it leaves a pretty simple seam in case you are heading to the chrome shop with them.
    Don't forget the rear window.
    Same pile of moldings, all just 4 inches smaller.
    And here is today, all garnished up and a windshield that cranks out. Not sure what is next. Probably something.
    See ya, -Abone.
    rod1, RMcCulley, ratster and 37 others like this.
  22. lurker mick
    lurker mick
    That is looking good!
    Mick
  23. lo c dan
    lo c dan
  24. Robdski
    Robdski
    Thanks for the excellent update!
  25. alchemy
    alchemy
    Headlights next. The headlight placement on a 34 is so important, and easy to get wrong.
  26. Build plan, check, vehicle, check, transmission, check, engine, check, rear axle, check, the boss’s approval, double check, paint, it’ll buff out, mufflers? You don’t need no stinking mufflers!!!, carry on.
    Just Gary and warhorseracing like this.
  27. ronzmtrwrx
    ronzmtrwrx
    Man that’s lookin good. It’s just right for my tastes.
  28. -Brent-
    -Brent-
    Lotsa work!!! Nice job.
  29. motoandy
    motoandy
    from MB, SC
    Great Job Jeff. Very methodical and deliberate.
    jim snow likes this.
  30. Just checking in on the awesome progress.
