Technical Pitman arm removal
Discussion in 'The Hokey Ass Message Board' started by sgtlethargic, Jul 8, 2025.
  1. I borrowed a good puller and tightened it till a wing nut (that was barely threaded on) popped off. Should I try again with the puller as-is? Add some rust penetrant? Break out a MAPP gas torch and heat the arm?
  2. MAPP gas works for me.
  3. TA DAD
    TA DAD
    from NC
    A good puller with a wing nut ? lol
  4. alchemy
    alchemy
    warbird1, 4ever18, Boneyard51 and 5 others like this.
  5. What's supposedly wrong with a puller with a wing nut?
  6. TA DAD
    TA DAD
    from NC
    Nothing until it flies apart and hits you in the face !
    warbird1 and 19Eddy30 like this.
  7. Here's what I'm using. I don't see it being a problem, as long as the wing nuts are threaded on more than I had them. I also have one like in post #4.
  8. Doublepumper
    Doublepumper
    from OR-WA, USA
    Longer bolts, bailing wire, hose clamps...welder:D
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    Universal ANYTHING is never as good as a dedicated tool , that just looks cheap ... Sometimes you'll get by with them , most times not so much ..
  10. Tighten up the top big bolt
    Whack that bolt with a hammer
    Repeat.
    warm up if that fails
  11. deathrowdave
    deathrowdave
    from NKy
    I just recently stripped the center bolt on my MAC pitman arm puller . I had to do as Mr.Anthony suggested , smack hell out of it tighten heat , smack hell out of it , repeat .
    anthony myrick likes this.
  12. 19Eddy30
    19Eddy30
    from VA
    No line up pin
    & arms
    & some time Heat Needed .
    captaintaytay likes this.
  13. captaintaytay
    captaintaytay
    I have one of these. Been using it for years, works everytime.
  14. Yep
    Tighten it
    Whack it
    Repeat
  15. Boneyard51
    Boneyard51
    deathrowdave likes this.
  16. rusty valley
    rusty valley
    And, what is a "sung"nut? new one on me
    Boneyard51 and captaintaytay like this.
  17. patsurf
    patsurf
    prob on ALL of us...
    captaintaytay and rusty valley like this.
  18. lostone
    lostone
    from kansas
    IF it's going to be replaced and it's a junk piece I take a 4" cutting disc and cut a deep slot on the back side of the pitman arm, straight opposite of the arm part and then put a puller on it and a couple smacks and it's off.
    If I need to save it, put puller on, put pressure against it but not maxed out on pressure, then again I heat a line up and down on the same spot as above. Once I get a line good and hot then I max out the air wrench and a couple smacks with a hammer.
    Sometimes I've taken a big punch and with the puller on it and hit the back side of the pitman arm in the same spots as above. So I'm hitting the thick ring side of the pitman arm straight with the long arm, straight hits into the shaft. But I only do this as a last ditch effort as I don't like banging the shaft into the lower bearing/bushing....
    rusty valley likes this.
  19. 69fury
    69fury
    from Topeka
    I've found success twice by using a good puller, giving her the business with the impact, a few smacks, more business, then go have a sammich for lunch and mow the yard. When I come back, it's laying on the floor. *shrug*
    -rick
    borntoloze, buffaloracer and Algoma56 like this.
  20. captaintaytay
    captaintaytay
    Yes, I got to know what "sung nuts" are...
  21. Andy
    Andy
    I have a large two jaw puller. It always has worked for me. I have never smacked the puller. I would expect that to damage the worm or bearings. If did want to smack the puller, I would take the cover off the end of the pitman shaft so the shaft could bottom on the housing. Vega boxes are really delicate and if you try to beat the tie rod ball joint off, you will dent the worm bearing surfaces.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Budget36 likes this.
  23. Budget36
    Budget36
  24. patsurf
    patsurf
    :eek::eek::eek:
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Oop’s, thought I read snug. Damn dyslexia! :oops:
  26. nrgwizard
    nrgwizard
    from Minn. uSA
    Tighten the correct-type puller up hard, use an airgun w/a wide/thick tip on either the pitman arm top, or against the puller shaft. Maybe both, alternating. If you do soak the splines w/penetrant, careful w/the airgun, it'll send that stuff flying, miraculously, into the eyes 1st. What you want is vibration(s) to help loosen it up, while exerting pressure in the "off" direction. Saves a lot of cussing... . I mean, you can still cuss all you want, but it's usually not *needed* . :D .
    Marcus...
  27. 1971BB427
    1971BB427
    from Oregon
    The absolute best pitman arm puller is the cup style. They don't use separate arms with hooks that can spread the more pressure you put on the T screw to pull an arm. Of course they cost a lot more, but I've never found a pitman arm they wont pull the first try. About $90-$200 depending on where you buy one. This one is on Amazon for $89.
    clem, 69fury and TA DAD like this.
  28. jaracer
    jaracer
    That style was puller was the Ford Rotunda service tool back in the 70's. Use one like many times when I worked at the Lincoln Mercury dealer. It always did the job.
  29. Acres
    Acres
    from Sweden
    I would say some heat, thats been the only way those time I had to remove pitman arms.
  30. Bob Lowry
    Bob Lowry
    As Clint Eastwood said, "A man's got to know his limitations...."
