Hot Rods Weird-Ass Fuel Pump.
Discussion in 'The Hokey Ass Message Board' started by Sskirch, Jul 8, 2025.
  1. Sskirch
    Sskirch
    I originally posted this on What's It Worth, but got tumble weeds. 20250707_110827.jpg
    This came off a flathead in a AV8.. The previous owner was just using it as breather as the car has an electric fuel pump. He called it a "school bus pump" and I have no idea what that means, and can't find any useful references on the internet. It almost looks like the bowl is mounted upside down, but I don't think that's the case.
    Any ideas on what it is or it's value?
  2. GuyW
    GuyW
    I think it's an upside down water trap for the gasoline line
  3. rattlecanrods
    rattlecanrods
    Definitely looks more like a separator than pump. I don't see any mechanical means to actuate a pump.
  4. Sskirch
    Sskirch
    I don't know. It definitely looks like it receives push rod from the cam.
    rattlecanrods likes this.
  5. NoSurf
    NoSurf
    That pocket in the end of the arm goes over the pushrod.
    I think it was bolted on upside down.
    Try lining it up properly and see.
    deathrowdave likes this.
  6. Oneball
    Oneball
    There’s a few cars I can think of that came with pumps that way up. Citroens for one. IMG_7611.jpeg
    leon bee likes this.
  7. 42merc
    42merc
    Hi volume early Ford flathead fuel pump.
    Early racers used it.
    Originally was equipped on 1944 rear engine Ford busses, city buss, not school buss.
    Okie Pete, clem, leon bee and 2 others like this.
  8. Sskirch
    Sskirch
    If I flip it over, it won't clear the manifold. Also the actuator arm is spring loaded to be pushed upward. Its definetly not upside down.
    leon bee and NoSurf like this.
  9. Sskirch
    Sskirch
    Thanks. I think this makes the most sense.
  10. 42merc
    42merc
    Makes sense because it's fact.
    leon bee, Sskirch and Toms Dogs like this.
  11. NoSurf
    NoSurf
    With the sediment/separator upside down? How's that work?
    GuyW likes this.
  12. Bentrodder
    Bentrodder
    from Cotati
    Looks to me that it's more of a sight gl*** to see that it's pumping than it is a separator. We have some old water cooled TIG welders here that has that same type of gl*** on top that is just so you can see that coolant is flowing.
    deathrowdave and NoSurf like this.
  13. alchemy
    alchemy
    The push arm cup has obviously been modified. We probably need pics of it from its natural environment to know how it fit on that bus.
  14. seb fontana
    seb fontana
    from ct
    How could it be mounted up side down?
  15. NoSurf
    NoSurf
    The two bolt holes reversed?
  16. Sskirch
    Sskirch
    As requested, here's a photo of it on the car:
    rattlecanrods, Okie Pete and leon bee like this.
  17. 42merc
    42merc
    Here is one in the wild. All Ford all the time.
    Okie Pete, leon bee, NoSurf and 4 others like this.
  18. Sskirch
    Sskirch
    The modification on the cup could also be a repair.
  19. theHIGHLANDER
    theHIGHLANDER
    41 and 47 Cadillac has the gl*** up. That does look hi-volume. Kool, I'd kit that ****er and run it.
  20. Tim
    Tim
    from KCMO
    Not the first time seeing the bowl orientated like that on a flathead but it is the first time I’ve seen it as part of the pump like that.
    cool find.
  21. 57Fury440
    57Fury440
    That is a nice looking piece.
  22. AccurateMike
    AccurateMike
    Hijack...
    This came in a box of parts I got with a V8-60. Not for the 60. Had a gl*** bowl once.
    It is huge compared to the 60's pump. Any guesses ? It is an AC and has a "Rebuilt" tag on it. Mike
    Okie Pete likes this.
  23. inthweedz
    inthweedz
    Looks like a common old "AC" fuel pump, lots of GM 6 cylinders run them, I think the Ford 6's also had them.
    In operation, the fuel comes in to the bowl/gl*** area thru the shorter tube (inside the bowl) any water/crud falls to the bottom, the fuel level builds up until it overfolws into the larger opening, don to the diaphragm area, and exits out the other side. There is usually a fine gauze type filter, in this case it's missing from the top of the large outlet tube..
  24. clem
    clem
    the bus version of the flathead also had longer snouts on their water pumps.
    Once you get away from the standard cars, there are going to be variations of what most of us are used to seeing.
    Just the other night this popped up on trademe, (NZ version of ebay)
    I have never seen one before.
    Guessing it was for a stationary engine, fire pump or similar ?
    (Someone on here is sure to know).
    Lots of interesting stuff out there……
  25. Onemansjunk
    Onemansjunk
    from Modesto,CA
    upload_2025-7-9_3-51-7.jpeg That fuel pump is exactly what dad was running on his 41 Ford pick-up. He was a Air Force mechanic during the FORGOTTEN WAR. He drove his 41 daily, rain or shine and some of the worst Colorado snow storms. We would pull the bed off so he could run chains and get to work, without destroying his fenders and bedsides. I remember that fuel pump very well.
    NoSurf and Okie Pete like this.
