Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I'm on my flight home from a very fun Fourth of July weekend in Michigan. I don't really have any updates, except that I've ordered a handful of parts—including a pair of original rear axle nuts and washers from All Ford and some detail pieces for the grille shell. I meant to sketch out my wiring diagram while I was at my parents', but I didn't get around to it. That's on the agenda for this week.
    Here's an old rod for inspiration.
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    There's no denying that the "To-Do" list is shrinking, but you'd be mistaken to think that this car is almost ready for the road. This week, I plan to sketch/start laying out the wiring diagram, as well as ordering any components I need to make that happen. I'm also going to bolt in the gas tank, order straps, and begin routing the fuel line. This weekend, I'm bleeding brakes.
    A-V8, with driver for scale.
    Random shot of roadster and waste receptacles.
    IMG_0596.jpg Justin modeling the correct driving footwear. Superrrrr long shot, but does anyone have a chrome 1930-'31 Model A roadster dash rail?
    There you have it—we're all caught up. Looking forward to being back in the garage to keep making progress on this project!
  3. RodStRace
    RodStRace
    On the hubcap front, there are a few things. First, the wheel must be wobble free and stiff enough not to flex much around corners. A great cap won't stay on a bad wheel. Wobble can be checked, flex not so much. A lower tire pressure will help with this, flexing more and transferring less jarring force.
    Next the spring teeth need to grab well, and evenly. I saw way too many just plier out the inside ones and make it even worse. The spring band must be solid on the cap. One bad spot weld and that section can flex. Check the teeth on the cap, they need to be sharp. They will dig into the paint and metal.
    Get a hubcap pry hammer.
    https://www.jegs.com/i/JEGS/555/80857/10002/-1
    When everything is right, they will hurt your hand/wrist knocking them on.
  4. winduptoy
    winduptoy
    we aren't so concerned with them being stolen..and yes they are nice! they have honest use and add tremendously to the look!!...
    it is you loosing one while driving and not knowing it until you are at your destination.....that is our concern
    @RodStRace covered it and....
    with the heal of your hand, at the edge of the cover so as not to distort it....
    41 GMC K-18, J.Ukrop, Outback and 2 others like this.
  5. Tim
    Tim
    from KCMO
    Exactly! I know a lot of guys with back up wheel covers for just that reason!
    I’ve seen people put a little wire leash on them but I’d rather it get pitched to the ditch than bang around the side of my car getting beat to hell when it pops off
  6. Six Ball
    Six Ball
    from Nevada
    I have 15" Olds caps on my pickup. 3 fit fine. The spring clips on the other is are a little different and it is a ***** to get on. Tens of thousands of miles on freeways and dirt roads and I'v never lost one. The only hubcap I've ever lost in 65 years was a screw on Moon. It went out into a corn field in Texas and looked like a UFO!
  7. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks for the wheelcover advice, guys! No big updates from the 5R bus this morning, but here’s a little comparison between the reproduction axle nuts and the original Ford components. IMG_0801.jpeg
    BigJoeArt, Outback, pprather and 10 others like this.
  8. Tim
    Tim
    from KCMO
    Man that’s waaaaay off!
    Outback, richard noble and Six Ball like this.
  9. Deeluxe
    Deeluxe
    from island
    Re: Parts. Old is Gold.
    Your rod is becoming rad. Thanks for these posts along the way.
    J.Ukrop, Outback, Six Ball and 2 others like this.
  10. NealinCA
    NealinCA
    The 15/16" hex were used pre-war, the 1-1/4" hex were post war and became popular with hot rodders, as they were heavy duty. I use them just because.
    winduptoy, Outback, Six Ball and 3 others like this.
  11. Jeff34
    Jeff34
    I have the 15/16” on my ‘40 rear. I bought new felts and one new washer (missing)
    winduptoy, Outback and warbird1 like this.
  12. richard noble
    richard noble
    Joey, those are reminiscent of the old EELCO racing nuts, back in the 50’s. This is a photo of an original pair. They were used for track and drag cars, for the extra safety. If you choose to run them, make sure they are 18 thread pitch, check them first before installing…..
  13. Six Ball
    Six Ball
    from Nevada
    I've never seen one of those. :confused:
    J.Ukrop and richard noble like this.
  14. trevorsworth
    trevorsworth
    Yeeeaah those are some big nuts. Of all the old banjos I have laying around now I'm sure none of them have nuts like that & there are a couple I know haven't been messed with. They look bad *** though.
    J.Ukrop, Six Ball and richard noble like this.
  15. NealinCA
    NealinCA
    The chrome "big nuts" on my 5w...
    Plus the 3 different varieties Ive seen.
    Far right, Model A up to 34 I think
    Middle 35-41 or 42
    left are 42 or maybe 46-48
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Woah, I didn't know Eelco made nuts. I've been an Eelco fan ever since learning about them in TRJ #23. Thanks for the additional history!
    Wow, now that is perfect. They look great in chrome!
  17. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you! I never intended to use so many vintage parts, but it seems like they just so happen to be the best ones.
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    It's Sunday night here in San Francisco and the fog has rolled in, blanketing the city in a cool, gray mist. Off in the distance, the fog horn echoes out into the darkness. I've shut down the garage for the night, so it's time for a recap.
    On Thursday, I broke out my new stepped bit and got to work on the dash panel.
    After much thought, I found the perfect spot for my NOS chrome starter ****on compliments of @Hitchhiker. I have a new headlight switch on the way, so I'll share the photo of the full panel once I have it installed.
  19. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    On Saturday morning, my alarm sounded at 5 a.m. and I made my way up to Petaluma for the Northern California Roadster Run. I can't believe it has already been a year since the last one. Where does the time go?
    I didn't shoot too much, but it was great to see everyone at Twin Oaks prior to the run.
    As much as I wanted to tag along as a navigator this year, I knew I had a car to build. Before I returned to the city, I spent the morning at David's hanging out and asking many questions about everything from bleeding brakes to fuel line specs. It felt great to be back at my favorite hot rod shop in the world.
  20. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Two more stops in Petaluma.
    First, breakfast feat. TRJ.
    Second, I picked up my essential oils at the local auto parts store.
  21. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Last photo for the night. I'll share more about brakes, neighbors, and other happenings tomorrow IMG_0864.jpg
  22. Jeff34
    Jeff34
    Hallie's for breakfast?
    Looking great, Joey! I've got next year's roadster run in my sights...
    J.Ukrop, Outback and winduptoy like this.
  23. Jeff34
    Jeff34
    which oils did you choose for the trans and QC? I see the DOT4 brake fluid.
  24. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I went to Petaluma Brunch Station. All that hot roddin' was making me hungry for some flapjacks.
    I've said "next year" for the past two years. Next year is our year.
    I need to check when I go back down to the garage, but I went with Royal Purple for the QC and Sta-Lube for the transmission. Exact weights and measures to follow.
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Just got in from the garage and have enough time for a quick update.
    On Sunday, I dedicated much of the morning to the roadster project. During my time at the shop, David gave me some great advice about order of operations as far as the brakes were concerned. Before I could even think about bleeding them, I had to install all the drums and torque everything to spec.
    As I have mentioned on this thread, that last part made me anxious. By this stage of the game, many of you on here know me, either through this thread or out in the real world. I'm not a nervous person by nature, but I knew I had to be extra careful with these axle nuts. David showed me some tips for cleaning up the threads, and Justin lent me his high-torque torque wrench. "Nothing left but to do it," I said, carefully applying pressure to the wrench. Click. Increase torque. Click. Increase. I began to sweat. Off came the sweatshirt. Increase. Click. Castle almost aligned. Click. We're in. Cotter pin set. Aaand exhale.
    To say I was relieved was an understatement. I took a step back and prepared to approach the other side. IMG_0872.jpg
    And as I pulled the drum off, I was greeted by this unsavory sight. My new, made in the U.S.A. dust boot had cracked. Upon further inspection, it was only on the outside. But still, I rebuilt the brakes last March. A fresh one is en route and should be arriving tomorrow. I'm hoping I can pull off the swap without too much dis***embly. I guess we'll see!
  26. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Over the weekend, I also torqued and cottered all of my front spindle hardware. I wanted to grease the bearings and finalize the spindle nuts, but I realized I'm missing the seals. All Ford hooked it up, and I have a trio of them en route too. IMG_0866.jpg
    Not tightened or cotter pinned, but yes, I did install chrome castle nuts on the tie rod. If you can't have fun, why even build a car?
    Speaking of fun, a new neighbor's parents saw me wrenching and came over to see what was going on. Her mom loved the car, and I told her to try it out. She said she'll be coming back to check on progress!
    BigJoeArt, The 39 guy, Silva and 24 others like this.
  27. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Other Odds'n Ends
    Enjoying the view as I prepped the rear seat mount.
    Tonight, I dedicated 30 minutes to the starter solenoid installation and battery cable measurements. Vintage hardware from my recent estate sale haul was used.
    That's all for tonight. Who remembers when I made that stainless heater block off plate? And does anyone know what the "Z" stands for?
    BigJoeArt, Ragged Edge, rod1 and 10 others like this.
  28. winduptoy
    winduptoy
    Looking good Joey....it all has to be done and you are getting it step by step....Z, isn't that the last step?...you are out of sequence....
    ...and I like to use star lock washers on the electrical cable connector to the mechanical fastener
    Carry on!
    41 GMC K-18 likes this.
  29. Mikko_
    Mikko_
    from Sweden
    Regarding that cracked dust seal on the brake cylinder I have noticed that a lot of new rubber seals and boots made today crack like that in no time.
    Must be very poor rubber quality these days.
