Projects 1922 Dodge Bros Roadster (almost none of this is true)
Discussion in 'Traditional Hot Rods' started by fatassbuick, May 21, 2025.
  1. Mikko_
    Mikko_
    from Sweden
    Cool project.
    A bit off topic but I'll ask anyway; In your last post, is that a trunk lid for an Opel 1900 wagon hanging on the wall?
  2. fatassbuick
    fatassbuick
    from Kentucky
    Thanks. No sir, that's from a Chevy Vega Wagon.
    Mikko_ likes this.
  3. 4ever18
    4ever18
    In my humble opinion, the Dodge cowl & windshield is the best looking of the early cars. Checkout a movie called “The Lively Set”. That bucket was built using a Dodge cowl. Also, checkout Ed Roth’s OutLaw and its cowl & windshield. IMG_2034.jpeg
  4. dwollam
    dwollam
    I agree! Looks like '18 to me. The curved angle iron rear fender mounts is one clue. A year or two either way is possible too.
    W/S post leaned back starting in 1920. Doors and hinges changed in 1920 as well.
    Dave
    chryslerfan55, Okie Pete and 4ever18 like this.
  5. 4ever18
    4ever18
    Thank you, Dave
    chryslerfan55 and dwollam like this.
  6. fatassbuick
    fatassbuick
    from Kentucky
    I'm not the fastest turtle on the log, but I eked out some time to get side two tacked in.
    Also started taking the axle apart. She's a little tight, but some magic elixir will help.
    Poured half a jar of poor man's Kroil into the spindle and let 'er eat. DS came right apart, but I think due to not having an brake hardware inside.
    I'm hoping my new shift makes finding time a little easier. I reckon I'll sleep when I'm dead.
  7. fatassbuick
    fatassbuick
    from Kentucky
    Well, the new shift ****s. Something between jet lag and never knowing what day it is sort of ****s. Maybe 44 years of mostly day shift on a normal Mon-Fri schedule has made a wuss out of me.
    Anywho, here's a bit of an update.
    I decided to stop clutching pearls and terminate the body with the piece I already had. I'm guess this is never going to be a Rodder's Journal feature car, I am not a body man, and this is not a pristine car to start with...so here it is.
    Messing around with the turtle deck height. If I Z the frame, it will move it up around 3", unless I narrow the rear of the frame....etc
    20250828_170837.jpg 20250828_174257.jpg 20250904_175852.jpg 20250904_175904.jpg 20250908_212048.jpg 20250909_194653.jpg
    The last two pics are my new and improved front spring mount. We'll see how everything sits once it has weight and a full spring pack mounted up. Nothing is forever.
    chryslerfan55, dwollam, GuyW and 2 others like this.
  8. fatassbuick
    fatassbuick
    from Kentucky
    Second awkward post.
    Got these puppies out with a heat wrench. Waiting on new ones from Dennis Carpenter.
    20250922_160016.jpg 20250922_172303.jpg 20250922_172406.jpg 20250922_204036.jpg
    My neighbor gave me his rims and tires since he replaced them on his '35 Ford. I mounted the tires on the rims I'm using.
    Then I stuck the axle about where I think it's gonna be. It's sitting pretty high, but, in memory of Billy Coates, I'll lower it a little bit later. Don't want any basketballs rolling under it.
    Probably the coolest thing that's happened is getting a true running '47 59AB for pretty cheap. It came with a side shift trans, radiator, original carb and a few other things. I'm gonna get it running and tuned on the "custom dog **** welded" engine stand, then mate it up with a '37 trans I have and plug it in, after I mock the rear end. Then I can work on ride height.
    That's it for now.
  9. fatassbuick
    fatassbuick
    from Kentucky
    Not sure how to embed this, but I made some progress on my engine stand. So far, so good. Oil pressure runs 30psi and up. Temps seemed pretty good, but they didn't reach what I'd expect (around 130°?), but I'm gonna run it a little longer this afternoon and and shoot it with a heat gun to see if anything crazy happens.
    https://youtube.com/shorts/npHzRjb-R3g?si=s9miYHN1m5u6Dylm
