Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. The37Kid
    The37Kid
    Top looks great!
    Stogy, Dino 64, hrm2k and 2 others like this.
  2. 05snopro440
    05snopro440
    Looks awesome! There are some great tips in there, thanks for sharing!
    Stogy, hrm2k, Robdski and 2 others like this.
  3. mad mikey
    mad mikey
    Very well done Gary, great job. Your hot rod is stunning.
    Stogy, Dino 64, Robdski and 2 others like this.
  4. lothiandon1940
    lothiandon1940
    Chatted with both Gary and Dean, @Dino 64 at the Hot Rod Annual last year at Lincoln Speedway. So proud of BOTH of these guys for home-building two fabulous Hot Rods. They prove that with dedication and perseverance, it doesn't always take a professional shop to turn out some truly incredible cars. Thumbs-up to both of you. Love both rides.
    Stogy, brady1929, mad mikey and 7 others like this.
  5. Blues4U
    Blues4U
    from So Cal
    Wow, great job Gary! That looks fantastic!
    Stogy, mad mikey, Dino 64 and 2 others like this.
  6. Just Gary
    Just Gary
    Thanks, guys.:)
    Now to replace the 97-year-old threads:
    Stogy, Joe Blow, swade41 and 12 others like this.
  7. catdad49
    catdad49
    I Loved all the Orange, but that black top will make it a "Gotcha"!
  8. swade41
    swade41
    from Buffalo,NY
    That top turned out great, nice job
  9. Dino 64
    Dino 64
    from Virginia
    Thanks Don !! See you at Jalopyrama :)
  10. chevy57dude
    chevy57dude
    Gary, you have put in the time on this car, and the results are just top notch. You're going to be inside the show this October, right?
  11. flamedabone
    flamedabone
    Fantastic job on the roof and congratulations on having a cool wife.
    -Abone.
    Stogy, chevy57dude, mad mikey and 2 others like this.
  12. Just Gary
    Just Gary
    Yes- looking forward to it!
    Meanwhile, the new interior is pretty spartan.
    I mostly followed @skipstich 's no-sew tech thread....
    No-Sew door panel tech...
    ... and for storage, copied 50's sports car doors' (non-waterproof) cubby holes.
    door 59 lister jag 01.jpg door porsche 356.jpg door Triumph tr3.jpg seat ah sprite 59.jpg
    First, came butcher paper patterns.
    Then 1/8" thick plastic-coated hardboard. I cut it a bit large and "snuck up" on the final size.
    20250802_184447.jpg 20250802_184500~2.jpg 20250802_184557.jpg 20250802_184620.jpg
    More shortly.
    bchctybob, Stogy, Joe Blow and 15 others like this.
  13. chevy57dude
    chevy57dude
  14. Just Gary
    Just Gary
    Auveco #808 trim clips attach the doors.
    https://www.amazon.com/dp/B0058W0FDC/?tag=atomicindus08-20
    3M-90 spray adhesive (expen$ive but seems worth it) attaches 3/8" foam to the hardboard.
    I slightly beveled the foam edges with a Dremel.
    Then Hobby Lobby black marine vinyl is glued to the foam. Its texture matches the seats.
    catdad49, Stogy, Dino 64 and 9 others like this.
  15. Just Gary
    Just Gary
    Each cubby hole is backed by a vinyl covered panel.
    Quarter panels are attached with wood screws into the B-posts and small bracket holding the upper rear corner.
    Simple kick panels attach with sheetmetal screws.
    bchctybob, catdad49, Stogy and 8 others like this.
  16. Just Gary
    Just Gary
    Done.:)
    The foam is too thick to use the stock crank escutcheons.
    20250822_210131.jpg 20250822_202328.jpg 20250822_164610.jpg 20250822_235739.jpg 20250822_190108.jpg 20250822_235859~2.jpg
    bchctybob, catdad49, Stogy and 14 others like this.
  17. Tim
    Tim
    from KCMO
    Looks good!
    any idea what you’ll
    Use the little cubby’s for?
    Stogy and Just Gary like this.
  18. Happydaze
    Happydaze
    Not sure how I've missed this over the years! Great job. Love the look, but I'm a ****er for big n littlies, a good rake and low mounted big lights!!
    Chris
    Stogy, Johnny99 and Just Gary like this.
  19. Just Gary
    Just Gary
    Thanks! Don't know yet.
    Since the car has no trunk or glove compartment, I wanted some incon****uous storage space.
  20. lothiandon1940
    lothiandon1940
  21. mad mikey
    mad mikey
    Hey, Gary ,I have hide spaces under my seats and in the doors. Good for keys, registration, insurance. and more.
    Stogy, chevy57dude, Joe Blow and 2 others like this.
  22. Joe Blow
    Joe Blow
    Have been in and out of this thread sporadically over the years. Raining and cold here today....so put a pot of coffee on, started on page 1 and got after it. Incredible attention to detail and craftsmanship. One hell of an achievement Gary and just an incredible build.....a *****n', bad***, beautiful hotrod.
    Gotgas, Stogy, RodStRace and 2 others like this.
  23. 19Eddy30
    19Eddy30
    from VA
    Yes thats bad part of Sedan ,
    Maybe GloveBox like 32 or so.
    Or double line your tunnel p*** shifter
    To flip up , or maybe box in floor like Original battery box just shorter,
    I just stuck papers in seat ,
    I was pulled over One time , was asked for papers , I told the Man I need to get out so I could show paper's , Was Question why, because paper in seat .
    My A still had Flip up front buckets.
    Also Mine I left rear seat in & used the storage there ,
    Just Gary and lothiandon1940 like this.
  24. Just Gary
    Just Gary
    Cardboard flooring templates.
    1/4" thick rubber gym flooring; commonly used in weight rooms.
    It's reasonably priced and is a great sound / heat insulator.
    It's also dense. A box cutter & hole saw can cut it, whereas a gasket hole punch doesn't even leave a mark.
    Two-sided tape holds it in place.
    Like Trinidad carpet in late '50's & early '60's kustoms, the gray flecks "really tie the room together".
  25. lothiandon1940
    lothiandon1940
    WOW! Great job, Gary. Innovative use of available material. Love it.
    catdad49, Stogy, Joe Blow and 2 others like this.
  26. sidevalve8ba
    sidevalve8ba
    Where did you purchase that gym flooring?
  27. Just Gary
    Just Gary
  28. Dino 64
    Dino 64
    from Virginia
  29. Just Gary
    Just Gary
    sknz, bchctybob, Gotgas and 24 others like this.
  30. lothiandon1940
    lothiandon1940
