Technical New and confused by a loose drum
Discussion in 'The Hokey Ass Message Board' started by tedx5, Jul 15, 2025.
  1. tedx5
    tedx5
    I’ve got 28 model an and few days ago the LF wheel became loose, luckily didn’t fall off. Felt like loose lug nuts but tightening them didn’t help, I noticed the drum was moving so I tightened the wheel bearing up to no avail. I tryed swapping wheels no help. I took the whole hub and when the lug nuts are tight the drum and wheel are loose. im very new to model a stuff so some insight would be appreciated. Thank you
    dana barlow and chryslerfan55 like this.
  2. Sounds like a bearing issue if you “snugged” the hub nut and it’s still loose.
    Possibly damaged threads.
    Maybe something is missing
    dana barlow likes this.
  3. squirrel
    pictures! Maybe one with the wheel on, the other with the wheel off.
    sounds to me like it might have the wrong wheels on it? so the wheel is not contacting the hub "flat"
  4. hotrodjack33
    hotrodjack33
    A loose feeling wheel ***embly could also be a worn king pin.
    tb33anda3rd and anthony myrick like this.
  5. tedx5
    tedx5
    Left to right had the same play in the king pins.
    Just Gary likes this.
  6. tedx5
    tedx5
    I have 30-31 19in wire on it. I’ll post a picture of the wheel and hub in a bit (I’m at work)
  7. tedx5
    tedx5
    I have the hub off the car and the drum and wheel are loose in relation to the hub. The hub is tight when in the spindle
  8. Generic ford hub diagram
    basic king pin diagram
  9. Need pics
    19Eddy30 and squirrel like this.
  10. rusty valley
    rusty valley
    confusing, but it sounds like the lug holes in the wheel may be shot, or the lug nuts bottom out before tightening the wheel. take it apart and give us some pics
  11. Bought like this?
    or were ya working on it before the issue?
  12. 19Eddy30
    19Eddy30
    from VA
    Model A wheels ?
  13. tedx5
    tedx5
    Bought it shook it down at the shop found nothing and then one day I noted a little shimmy then the he next day the wheel felt like it was gonna come off
  14. We need pics
    rusty valley likes this.
  15. Budget36
    Budget36
    Your drum and hub are separate? Is that how Model A’s were made? Later Fords the hub and drum were basically one unit.
  16. Juice brakes?
    losse if rocking the tire with hands at the 12:00 amd 6:00 position?
    Or 9:00 amd 3:00 position.
    or both.
  17. tedx5
    tedx5
    That was my first thought but the lug nuts don’t
    both.
    I tryed 2 different wheels on the same hub/drum and have the same amount of play.
  18. 325w
    325w
    Are only two of the lug nuts welded?
  19. Does this look odd?
    warbird1 likes this.
  20. finn
    finn
    Lug nuts are bottoming before loading the wheel.
    I’m no Model A expert, but seem to remember a spacer was once available for switching from Model A wire wheels to later model disc type wheels.
  21. rusty valley
    rusty valley
    The raised part that is circled is where it would normally be swedged down onto the drum. You can buy the tool from vendors to do that but in this case they welded it. Seen it many times, it works sorta, the welds often crack
    winduptoy likes this.
  22. rusty valley
    rusty valley
    Also, original nuts are missing a couple threads on the bottom which will clear that shoulder on the stud. Many aftermarket nuts are threaded all the way thru, and those can bottom out
  23. 1952henry
    1952henry
    I have read the lug holes get wallered out over the years. I would have a close look at the wheels. Of course, I could be waaay off base.
  24. rusty valley
    rusty valley
    Yes, model A wheels are weak in the lug hole area IMHO
  25. Stock Model A Lugnut's are closed ended and the Threads begin about .100 inside the open end of the nut. That lets the Lugnut fully seat against the wheel before bottoming out against the lug stud base. If you are using standard fully threaded Lugnut's you're not getting good enough clamp force.
  26. This is most often caused by using the Wrong Lugnuts.
  27. tedx5
    tedx5
    All are weldes
  28. Guess its time to take the other side of , find a straight-edge and compare.
  29. tedx5
    tedx5
    A
    Does that look right?
  30. squirrel
    pictures of the wheel?
    looks like it might be seating on the outer part of the drum, instead of the hub?
    anthony myrick and Pist-n-Broke like this.
