Projects The 'Preacher' '40 Coupe
Discussion in 'Traditional Hot Rods' started by Little Terry, Feb 12, 2025.
  1. 55 Ford Gasser
    55 Ford Gasser
    Nice work being done. I have been following as I have a '40 coupe also. My question though, what year is the Mk1 Cooper in the background? I have one of those in my garage as well. Although, it's not a Cooper. It was built by Clive Trickey in 1967 when he wrote for Triple C Magazine.
    Stogy and chryslerfan55 like this.
  2. Dak Rat
    Dak Rat
    from NoDak
    A bit of advice to folks using the Speedway T-5 trans adaptor. Cut an inspection window in the same area that Ford had on the original 3-speed. It helps a lot to check on the throw out bearing clearance to clutch fingers and to replace the return spring if that fails. Make the window the same size Ford did and use the small cover off the 3-speed or make your own. You will thank yourself later.
    Stogy, chryslerfan55, Tim and 6 others like this.
  3. Little Terry
    Little Terry
    I'm not sure, sorry - that's another customer's car at the body shop I use. Not mine.
  4. Little Terry
    Little Terry
    That sounds like a great tip. Thanks.
  5. joel
    joel
    I like the structure you made to position/locate the new floor. there is no way the body shop can mess that up.;)
  6. Little Terry
    Little Terry
    The guys at the body shop did all the bracing before they took the floor out. The panel gaps were all pretty good before dis***embly, so we wanted to try and keep it that way.
  7. Little Terry
    Little Terry
    Trunk floor is going in…..
    Stogy, Thor1, chryslerfan55 and 9 others like this.
  8. 31 Coupe
    31 Coupe
    Hi Terry,
    Really love your coupe and what you're doing.
    I also know all about what you've gone through ..... I brought the '46 Tudor below from California a few years ago and I was just going get it good enough to put on the road but unfortunately things got out of hand and much like yours its since had a major and ongoing rebuild.
    Remember that it WILL be all worth it in the end ..... at least that's what I keep telling myself.
    Stogy, chryslerfan55, Outback and 3 others like this.
  9. Mart
    Mart
    Beautiful job, Mark. It takes guts to cut up what appears to be a pretty smart car. Will follow with interest.
    Stogy, chryslerfan55 and Little Terry like this.
  10. alchemy
    alchemy
    Have them fit the trunk lid before they weld up the rear floor, since they didn’t cross brace back there. That opening is just as complex as a door opening, and maybe worse. Curves in every direction!
  11. Little Terry
    Little Terry
    Thanks Mart. The hard work is in the body and my only real involvement with that bit is financial.
  12. Little Terry
    Little Terry
    Yes, I will thanks. The lower rear panel has to be offered up next and that will be done with the trunk lid in place. Once that is tacked in, the floor can be full welded.
    Stogy, Thor1, The 39 guy and 4 others like this.
  13. neilswheels
    neilswheels
    from England
    wow, big progress. Looking forward to seeing this one when its done. What mufflers did you use? (ive got Smitty's, so thinking further down the line when they fall apart :) )
  14. Little Terry
    Little Terry
    I have no idea unfortunately- they were already on the car.
  15. Little Terry
    Little Terry
    Here’s a bit more from the bodyshop boys…
    IMG_6639.jpeg IMG_6642.jpeg IMG_6644.jpeg IMG_6650.jpeg IMG_6655.jpeg IMG_6657.jpeg IMG_6660.jpeg
    Stogy, Thor1, The 39 guy and 6 others like this.
  16. Little Terry
    Little Terry
    And some detail of one of the repairs that has been done to the rear of the drip rail where it reaches the trunk….
    93526c6a-ebf0-4505-9604-559ecd2a0aab.jpeg c3602f5a-feeb-4808-ac6f-f2fbc5e45fa9.jpeg ee699b76-551d-411a-83e9-faf3223b9b3b.jpeg cc6c941f-17e5-453d-a019-fb3ee16a2a8a.jpeg 48f8cf3e-14de-428d-b209-3b8b6c9a4f80.jpeg 94f395e5-5ca5-4d3b-b4ef-7b4f92bc6ce9.jpeg 12e4389c-1f9b-4afc-858e-29df3bdbefa0.jpeg 3855d2a8-6489-4285-b9f9-5a22d507c31e.jpeg c3f96498-bc12-4cd8-ae1d-3423accc0976.jpeg b8965c80-07ab-4e26-8e22-e0f30fd0a370.jpeg
    Stogy, Thor1, fatassbuick and 7 others like this.
  17. flamedabone
    flamedabone
    Nice job on the sail panel/rain gutter repair. That is a bit more complicated than what it looks.
    -Abone.
  18. patsurf
    patsurf
    AND it looked complicated!.....
  19. DrJekyllMrHyde
    DrJekyllMrHyde
    Great work!
    I see some difference from my’40 , these slmost vertical braces under the rear windows is not on mine.
    Are there business and opera versions, or are mine just cut off!
    The corners are more round on mine as well..
    Little Terry likes this.
  20. joel
    joel
    That is a difficult repair and I'd say that you accomplished it well. I had a short section on my car along with perforations in the channel that the trunk seal occupies. I messed with that for almost a week.
  21. motoandy
    motoandy
    from MB, SC
    Looking good man.
  22. Little Terry
    Little Terry
    This one is a business coupe, which has different bracing and floor panels to allow for the 2 fold-down seats in the rear. The coupe has a parcel shelf. That is my understanding.
    Outback and DrJekyllMrHyde like this.
  23. Little Terry
    Little Terry
    Fitting up the rear fenders and adding some lead. IMG_7085.jpeg IMG_7088.jpeg IMG_7090.jpeg IMG_7095.jpeg IMG_7099.jpeg IMG_7102.jpeg IMG_7105.jpeg IMG_7106.jpeg
  24. hotrodA
    hotrodA
    WOW! Great work on your coupe!
    Little Terry and Outback like this.
  25. Little Terry
    Little Terry
    Thanks. The guys at the bodyshop are really making good progress now. Hopefully they will get it in some primer in the next couple of weeks.
    Thor1 likes this.
  26. Little Terry
    Little Terry
    A bit more progress on front sheet metal and gaps…..
    ce505b11-39e0-4d03-ba03-15f5920e0584.jpeg 6cf730e8-9a21-4052-a758-2542f35eb08f.jpeg 867971ca-2f07-47e9-8459-56f0415d28db.jpeg b59726a5-984e-461f-b736-8c8a5056a4f0.jpeg
  27. ronzmtrwrx
    ronzmtrwrx
    Wow, I have no idea how I missed this thread. Looks like the shop is doing great work and you are doing a great job dialing in the ch***is and running gear. I did wonder early on in the thread though, if maybe you and your old buddy tied one on for old times sake and that resulted in the complete dis***embly of what looked like a great car to start with. Don’t ask me why I thought that. :D Just joking, but seriously, you will have a keeper on your hands when you’re finished. Keep up the good work and I’m subscribing.
    Deutscher, hook00pad and Little Terry like this.
  28. Little Terry
    Little Terry
    The boys are romping along with this now….
    fb8c9c50-1e5d-4a32-866d-65335b8acb3c.jpeg f6edebe4-b228-41fb-853b-9a986c6f84e2.jpeg 273f0cd9-66aa-4fe0-ba59-66392d36557a.jpeg 23865b1a-1d25-47f9-ab65-438cd387feb3.jpeg 5f440071-524f-4a11-a043-4207a4c5c1c9.jpeg 9ba510e2-e8f7-48b5-a8de-7e10f0b3ab09.jpeg 32ed88d0-d8c5-4e8c-980d-87685b220318.jpeg 0332af8e-99d1-40bd-9cd6-ee5668869557.jpeg 022d876b-7bc1-4a87-92f0-bdf01d19d1a1.jpeg
  29. Baumi
    Baumi
    Wow, it really takes some guts to blow such a nice car apart! But you´ll have an even nicer one! Good work!
  30. Little Terry
    Little Terry
    The latest instalment. Final build up to check alignment and panel fit before it comes apart again for primer.
