Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. X-cpe
    X-cpe
    It is called cove cutting. You can usually go wider and deeper than with a router. Width is controlled by the angle of the fence board to the blade. I can't tell you what the go/no-go angle is. The fence board can be on either side of the blade so long as the far end is angled away. If the bottom end of the fence is angled away from the blade, the force of the blade will pull the workpiece away from the fence. Like the video showed, you have to make incremental cuts. A push stick or board is absolutely necessary. This is NOT a finger friendly procedure.
    chryslerfan55, Six Ball and Sharpone like this.
  2. deathrowdave
    deathrowdave
    from NKy
    “ You can usually go wider and deeper. “
    Hey wait a minute , ahh never mind
  3. lilredex
    lilredex
    Yes, but also use br*** fittings with ferrules. I hate those rubbers on transmission lines, they always give out when you are out in nowhere land.
    chryslerfan55, hammer-time and BJR like this.
  4. RodStRace
    RodStRace
    I was going to go out and set up a picture, but naw...
    When you are taking it apart to rebuild, you use baggies for the hardware, right?
    Get those magnetic trays from HF, set it close, then flip the baggie open on top. The bits stay in place and just pick up the bag when done with that part.
  5. s.e.charles
    s.e.charles
  6. atch
    atch
    I haven't counted lately, but I think I have about 20 of these. I'm not entirely sure I have enough. These are, to me anyway, probably like addictive drugs. Once you start using them you keep finding more and more uses for them.
  7. RodStRace
    RodStRace
    Sure beats old speakers! :D
    I'm lucky with the new project having so much access, but they were huge timesavers on stuff with non-flat inner fenders and floors. I even place screws as they come out in clumps, so they are first off, last off = first in, last in or 'clocked' if different lengths. Great to have 'em sticking up for threadlock, too.
  8. atch
    atch
    More tips:
    • Buy several 4" or 4 1/2" angle grinders. Last time I checked I think I have 13 of them. I almost never have to switch wheels/disks out. Just lay one down and pick up a different one with the disk I want to use already installed. I said lay down but actually they hang on racks.
    • Buy a bunch of identical tape measures and hang them around your shop. I have 12 that I bought all at the same time. They hang on these sectional sofa connectors. 61bBheFvkbL._AC_SX522_.jpg NOTE: when doing anything critical use ONLY one tape measure. Like squaring up a frame or such. For most things when using a tape somewhere in the shop to measure and then cutting a 2x4 somewhere else (using a different tape) being exact usually isn't of the utmost importance.
    • S**** 2x4's to hold pencils. Drill several holes of various sizes in 8-12" long s****s for pens, pencils, carpenter pencils, Sharpies, etc. Screw these to shelves or walls around your shop so you never have to go very far to get a pencil. Especially put some near drill presses, chop saws, table saws, welding table, etc. And if you ever use a silver Sharpie you'll wonder how you ever got along without them. I keep black and silver ones in all the pencil holders but in one toolbox drawer there are blue, red, black, silver, and maybe some other color Sharpies.
    • I use an old boom box for music. I wired an outlet on the main lighting circuit so that when I open the door and turn on the lights the music comes on.
    • Lots of folks have done the same thing with their compressor using relays but I never have. The compressor can only run when the lights are on, i.e., when you turn the lights off your compressor can't come on. It has happened (not to me) that an air fitting has failed when no one was in the shop and the compressor ran indefinitely until someone entered the shop (next day or after a weekend) and turned it off. That's probably a good idea but I've just never gotten around to doing it.
    • In my roll-around toolboxes I use plastic dividers in several drawers. That is, in my screwdriver drawers I put the small screwdrivers in a small tray inside the drawer with all the other screwdrivers. Same with the punch drawer and several other drawers. I'm talking about the plastic trays that some food comes in. Like carrots etc. where there is a plastic tray with clear plastic wrap over the food.
    • My big door is a 10' x 10' overhead door. Recently I had a door opener installed on it. Wish I had done that 25 years ago. Sure is easier, especially since I keep Clarence in there and now I don't have to get out, open the door, pull in, and close the door like I used to. Not really a tip but consider this for your door(s). I had put it off for years because openers for that large of a door are somewhat pricey. False economy.
    • I have about 15-18 of the H-F 4-wheel dollies that you move furniture around on. They are really handy to store transmissions and other heavy items that you don't want to be picking up to move. Mine are usually all holding something in semi-permanent storage.
    • I have two very nearly identical Craftsman cast-iron drill presses from the 1950's. One is strictly for wood and the other is strictly for metal. That way I never get metal shavings in wood projects and never get sawdust in metal projects. Same thing with two band saws; for the same reasons.
    • I have two "main" benches but my toolbox towers are all adjacent to the largest one. In order to eliminate walking across the shop every time I need a wrench at the secondary bench I painted and hung up the metal tine portion of an antique yard rake over that bench. I hung one each of combination open/box end wrenches from 3/8" to 1" on the rake. Sure saves a lot of steps.
    • a 2x4 is just the right width to make shelves to store rattle cans: paint, oil, spray adhesive, etc. I started with a plywood s****, about 2' x 4', with 2x4's screwed onto it. After hanging that on a wall I've made more of them whenever I had a plywood s**** of about that size. I now have about 8' x 8' of rattle can storage. Sounds like a lot but I still have some rattle cans stored in milk crates.
    • Speaking of milk crates, you can't have too many of them. They are uber useful for dozens of uses. I was fortunate in that about 25 years ago the US Postal mailman brought some of the mail for the hospital into the building in milk crates but never took the empties away. I was able to snag about 30 of them. Very useful.
    • File cabinets: In addition to the tool towers I have about 15 file cabinets. Most are "normal depth" drawers but 4-5 of them have half-height drawers. That makes them 10-drawer cabinets. The thin drawers are useful for storing hardware (bolts/nuts/screws), small seldom used items like zip ties and the tool to tension/cut them, S-hooks, calipers & dividers, plumbing fittings, tubes/bottles of lock-***e/RTV, etc. Half-gallon milk jugs cut down to the height of the drawers make storing hardware, nails, etc., especially easy. The full height drawers are great for storing skill-saws, battery chargers, sanders, sandpaper, jacks/jack stands, and lots of other things including car parts.
    • Log chain storage: I have 5-6 log chains. Each one is in a white 5-gallon bucket. The buckets are stacked inside each other, so in total all the chains occupy only the footprint of one bucket. Each bucket has a couple of inches showing at the top and the size (length and link size) of chain is written in this space in black Sharpie.
    I want to thank each and every one of you who have contributed to this thread. I've been subscribed since it was first started and have used many of the tips mentioned.
    b-t-w; please forgive me if I've posted any of the above tips before.
  9. Fabber McGee
    Fabber McGee
    Some wives might be a bit fussy about where you hang the red light.
    fauj, Six Ball, chryslerfan55 and 3 others like this.
  10. Lone Star Mopar
    Lone Star Mopar
    Smarter than my way. I have a sign on the door. "Turn off compressor" after an air line gave up & left it running overnight.
  11. Fabber McGee
    Fabber McGee
    My phone lives in a safe spot on the side of one of my tool boxes while I'm in the shop. When it's time to go to the house, I have trained myself not to reach for the phone before checking that the compressor and gas bottles are off. If I forget the phone and have to go back, the same rules apply.
    Not fool proof, but at least fool resistant.
  12. atch
    atch
    The sign I put on the inside of my exit door says "turn off the welding gas."
    jet996, seb fontana, Robdski and 7 others like this.
  13. atch
    atch
    To quote my late best friend Ed: "nothing is foolproof to a sufficiently talented fool."
    jet996, seb fontana, fauj and 9 others like this.
  14. mamllc
    mamllc
    The jig in the video looks a little Rube Goldberg-ish to me. Back in my boatbuilding days we used to build a part like the one in the drawing. A table saw with a straight edge clamped to the table works just fine. The size of that tube is only limited by the size of your saw blade, and can be any length you want. For smaller coves, which I would think would be more common in cars, a router would make more sense. Router bits with guide bearings can be had in many shapes and sizes. A bearing with the right OD and ID can be added to a bit with a shape you want. A bit without a bearing can be used by running the router base against a straight edge or pattern, or in a router table. Many possibilities. The smaller bits pictured here are 1/2" OD, the larger half round bit is 2" dia and the bigger one is 2-3/4".
  15. X-cpe
    X-cpe
    Folding arms for a horizontal ladder rack on the side of my shelf on wheels.
    Jeff Norwell, Robdski, fauj and 9 others like this.
  16. GuyW
    GuyW
    the above ladder storage device looks su****iously like a bicycle kick stand.....
  17. I kept leaving the lights on in my pit, because it is covered with a row of short planks which I can drive over if necessary, and can't be seen once a car is parked over it. I wired a small indicator light across the main pit light, in a spot where it can be seen when I lock up for the day. It is in a direct line of sight when I am about to latch the door closed. You could use a flashing light if you want to get more attention.
  18. X-cpe
    X-cpe
    No, just a piece of 1/2" rod, a vice, heat and a BFH.
    fauj, Six Ball, GuyW and 5 others like this.
  19. atch
    atch
    Everyone on here has his/her favorite method for temporarily labeling spark plug wires. I needed something several years ago. A quick trip to sweetie's laundry room, a few seconds with a Sharpie, and here's my quick and extremely cheap solution. This has been hanging on the wall over my bench for years. Used it again today.
  20. cshades
    cshades
    from wi
    I started saving the plastic square ties from bread and potato bags for spark plug wire labeling. they are easy to clip on and off but dont get in the way like clothes pins do
  21. Fortunateson
    Fortunateson
    I do the same thing for the same reason...
    osage orange and Six Ball like this.
  22. Six Ball
    Six Ball
    from Nevada
    But if you can store the wooden clothes-pins on the fuel line to prevent vapor lock. :)
    jet996, LAROKE, 2devilles and 2 others like this.
  23. jnaki
    jnaki
    Hello,
    That is a great idea that has been around for a while. The clips we see most are in two sizes. They are on some of the brand name loaves of whole wheat bread.
    upload_2025-7-25_4-27-58.png about the actual size
    We used to use the smaller opening holes as they were the ones on the bread we used to buy. But, we changed the types of bread we buy and now, the clips are a little larger in openings. The clips still open and close to keep things organized.
    The 4tb external hard drive is handy as it can be placed in a jacket pocket easily and the dangling wire is safely curled. The larger hole bread clip is clipped onto the curled cord and now, it keeps the small (smaller/thinner than a cigarette pack) hard drive in the pocket or purse.
    Jnaki
    We have several 4 tb versions with the latest stuff we have saved. They are handy and are a part of our “emergency grab bag” for such things that happen or are about to happen. The clips keep the wires all neat and tidy. There are two small hard drives with the same stuff copied on to them. (back up to a back up.)
    When our granddaughter was a teen, she was staying with us and happened to hear some noise outside of our house. So, we investigated and the street was busy with police cars, red fire captain’s cars and a small fire truck. Up the street toward the taller mountain, we could see the taller hook and ladder truck spraying water down the other side of the hill. Then slightly down the trail from the watering truck, flames were shooting up higher than the top of the hill.
    So, we got our grab bag and told our selves what to do if we had to leave fast. We watched for a little while and went back inside. 30 minutes later, the commotion died down and now the flames were not shooting high and it seemed to be under control. There were more fire trucks spraying water from all directions. Soon, the fire was out. And we put our “go bag” back in its closet space. With the portable external hard drives all located inside. All important papers are copied onto the hard drives. Grab and go...
    Note:
    If the house burns, we will be sad, but then we will start rebuilding a new house… our current small house is 40 years old, but nice.
    There are varying colors as manufacturers have their own choices and products. It is not the color, but the opening “mouse ears” inside as to giving you more room... YRMV
    Sharpone, Six Ball and osage orange like this.
  24. Wobbly
    Wobbly
    from UK
    While recently being treated in the back of an emergency ambulance and struggling to keep good oxygen levels I was given 3 oxygen bottle nebulisers. During the course of this I came up another use for the air/nebuliser hose that fits from the oxygen bottle that I was using . I asked if I could keep the hose as the paramedics were only going to bin it as bio waste.
    Chopped it to a shorter length and it makes a great brake bleeding pipe. It can even be joined up when not in use.
    jet996, 61Cruiser, Robdski and 7 others like this.
  25. Six Ball
    Six Ball
    from Nevada
    So they are trying to keep you alive and you are thinking of how to better use their equipment?
    Friggin' hot rodders.
    rpm56, jet996, X-cpe and 13 others like this.
  26. Sharpone
    Sharpone
    @Wobbly has his priorities straight!
    Dan
    Hudson31, Butler 32, fauj and 8 others like this.
  27. Fabber McGee
    Fabber McGee
    I brought home a couple of those hoses many years ago when my dad was in the hospital. The ones I got had a little rib on the inside that kept them from sealing on a standard fitting. About all they were good for was siphoning small amounts of liquid. Like getting the antifreeze out from under a layer of oil in a bucket.
  28. patsurf
    patsurf
    shows how valuable antifreeze is up there!!-wow...
    Wobbly and Sharpone like this.
  29. Fabber McGee
    Fabber McGee
    At 20 bucks a gallon, I'd say it's pretty valuable everywhere. If you buy 50/50 mix at 17 bucks and consider that half the volume is water which most folks get for free, then your ethylene glycol cost you 34 bucks a gallon.
  30. Fabber McGee
    Fabber McGee
    Another way to get a little oil off the top of a pan of antifreeze is to lay an oil absorbent pad on top. They soak up the oil, but won't accept any antifreeze.
