Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. 26 T Ford RPU
    26 T Ford RPU
    Those mounts would flex quite a bit, most likely crack over time. JW
    saltflats and Sharpone like this.
  2. swade41
    swade41
    from Buffalo,NY
    They have a gusset on the bottom, the fenderwell headers are what's moving/shaking at idle.
  3. Voh
    Voh
    Jetted down the carb and replaced the power valve. Need to replace the sparkplugs down to R43's and confirm the timing. Chasing a funky spot at about 2800 RPMs on the 283.
    Okie Pete, saltflats, pila38 and 7 others like this.
  4. deathrowdave
    deathrowdave
    from NKy
    What size is that carb ? It has a 50cc pump on it
    427 sleeper and Truckdoctor Andy like this.
  5. winduptoy
    winduptoy
    IMG_20250630_121156412_HDR.jpg getting more bugs on the radiator
  6. Voh
    Voh
    It is the Holley 2bbl, 500 cfm.
    porkshop likes this.
  7. swade41
    swade41
    from Buffalo,NY
    I dug out my windshield wipers I took off 30+ years ago and fitted them back on the 41.
    I particularly don't like the look but at least no water will go down the holes in the cab anymore.
  8. swade41
    swade41
    from Buffalo,NY
    Today I put a little elbow grease towards the 41's aluminum, spit shine style
    Then hit up one of the local cruise nights with the Henry J
  9. 0704252017.jpg Unfortunately today I did not get to work on my car but I did waste 4th of July sweating on the side of my house wondering why my easy up is slowly getting holes in it Anyways I got the engine installed in the car... I kept going back and forth if I was going to make it a stock model A engine and then build it or just put the built one in it to begin with But because this is my first banger project I've got a scratch this itch and I want to do it stock And then see how much of an improvement higher compression, a cam, a downdraft intake and all that other erasmatazz actually makes these perform better.
    So here is my car as of July 4th at about 8:30 p.m. as my neighbors are just starting to light fireworks off tomorrow is Sunday the 6th and I'm going to work on it some more. I am shooting for this car to be drivable by Labor Day I don't know if that is obtainable or not because I get distracted pretty easy by shiny objects but here's my progress thus far
    alanp561, Sharpone, Okie Pete and 8 others like this.
  10. swade41
    swade41
    from Buffalo,NY
    I pulled the single adjustable Koni coil overs off the Henry J to replace the springs and I had forgotten that they were different from a standard coil over.
    After a few attempts at compressing the springs I said screw it and ordered new double adjustable shocks. Sometimes you just never know where things are going to lead.
    I did get the 41 inspected yesterday so now I can street flog it without worry of getting ticketed for an expired anual inspection, the sticker on it had expired 6 years ago. Lol
  11. 26 T Ford RPU
    26 T Ford RPU
    trying the get this race ready for March. JW
  12. saltflats
    saltflats
    from Missouri
    Working on a fixture to recrate a crossmember to install a Richmond 5 speed in a X frame Chevy. I had one for a project coming up so I one for the pattern.
    Tickety Boo, pila38, das858 and 11 others like this.
  13. 1pickup
    1pickup
    Tried my hand at the acetylene smoke trick for the first time. It's my son's Triumph tank. Clearcoat to come.
  14. swade41
    swade41
    from Buffalo,NY
    Today I redid my newly installed new coilovers to get another inch of throw on the shocks. It's not perfectly centered between the extension and compression but it's pretty damn close.
    I'm sure it'll move a bit after the test drive anyhow and I'll be back under there further dialing it in.
    pila38, alanp561, porkshop and 7 others like this.
  15. Damn, James! Nice work.
    I've about finished wiring my '29 AA and will probably start it up for the first time in a week or two. Got to change out the brake light switch, which isn't working (hydraulic switch that everyone says will fail sooner than later). Once I spin the oil pump to try to push some pressure through the 351W oiling system I'll spin the motor with the plugs out to get everything lubed prior to connecting the carburetor with the accelerator pedal and hooking up the TV cable to the carburetor. Then it's time to test it all out. Maybe before August? Damned heat and humidity looks to become unbearable for the next few weeks.
  16. 1pickup
    1pickup
    Finished. Good enough for an old Triumph.
    Couldn't resist adding a little Spindrift flake too.
    It's Black. With HOK Gold base graphics. Then acetylene smoke. HOK Candy Tangerine over that. Urethane clear with the flake. Other than the black, the paint I used is VERY old.
    king4144, Rodsports, clem and 18 others like this.
  17. DDDenny
  18. saltflats
    saltflats
    from Missouri
    I built one similar to that for a 84 Camaro to be able to run the exhaust from the headers back.
  19. DDDenny
    My Nova is pretty low, nothing I hate worse than the sound of expensive mufflers s****ing pavement.
    porkshop, Tickety Boo, pila38 and 3 others like this.
  20. alanp561
    alanp561
    Whoa! How cool is that?:cool::cool:
  21. pila38
    pila38
    She moves under her own power, so why not see if it does burnouts? No real need for brakes for this experiment.
  22. swade41
    swade41
    from Buffalo,NY
    I made that access panel to cover the hole in the floor for the master cylinder on the 41 pickup, damn hole was like a blast furnace on my leg.
    Then I made up these little cables to hold my hood pins and keep them from disappearing. I had cut the pins down so the rings had an interference fit over the ends to keep them from walking out by themselves but I still didn't trust it.
  23. atch
    atch
    The bead in the MC cover is a nice touch.
    How did you get the wiring terminal onto the ring?
    osage orange and swade41 like this.
  24. swade41
    swade41
    from Buffalo,NY
    I chucked a chisel in the vice, slipped the ring over the chisel, then put an awl on the other side of the ring and pulled it out of that little block. It put up a fight but I was able to get one side out just enough to slip the terminal end in there.
  25. seb fontana
    seb fontana
    from ct
    15/32-32 thread nut, weird but I think I saw a listing for 1/4-100 in McMaster-Carr
    Adriatic Machine and Sharpone like this.
  26. grdra1
    grdra1
    Currently making new headers for my coupe 20250720_184822.jpg 20250720_184829.jpg 20250720_184836.jpg 20250720_184841.jpg 20250720_184848.jpg 20250720_184859.jpg
  27. grdra1
    grdra1
    A couple more pics ccd336b0-3904-4874-b9ec-26238f5eeb31.jpg cf629b05-df7b-47e7-88a3-d91e990e914b.jpg
  28. I'm finishing up wiring my '29 Model A truck. Cory at Rebel Wiring has been amazing in helping me diagnose so many issues. I still have some things to sort out, but they'll have to wait until the dangerous heat wave subsides. I work as long as I can in the morning, then the garage just becomes an oven and I retreat inside for the rest of the day. My latest challenge: I pulled the distributor and used a shaft and my drill to turn the oil pump on the 351W to prime the engine but it wasn't showing any pressure on the gauge. Yes, I was spinning it counterclockwise and yes, I have the correct oil pressure sender for a gauge, not an idiot light. Next time I get out in the garage I'll do a continuity test to make sure the gauge is getting power and is wired properly. One thing that makes me think the problem isn't with the pump is that just a few seconds after starting the drill it slowed down under load, which seemed to indicate it was pumping oil. However, I hesitate to crank over the engine until there's evidence that the oil pump is providing pressure. It's a fresh rebuild (non-roller) and I don't want to ruin it if it is starving for oil.
    Any insight?
  29. Bandit Billy
    Bandit Billy
    clem, 427 sleeper and Sharpone like this.
  30. grdra1
    grdra1
    Bandit it is an illusion as the pipes are about 3/4 to 1 inch away from paint at the closes point, once I fully weld them up I will post more detailed pics. Glen 340107ba-6520-42ec-9e77-de4ab9d983dd.jpg
    swade41, Okie Pete, loudbang and 4 others like this.
