Hot Rods Straight vs Bent spokes
Discussion in 'The Hokey Ass Message Board' started by Chris Haynes, Jul 5, 2025.
  1. I recently bought a car with sixteen inch wires on it. Two have straight spokes, and Two have bent spokes. So being as I have to buy two more rims to match them up is there a noticeable improvement in either one? Which came first? When did the other appear?
    Inquiring minds need to know.
    Tow Truck Tom and chryslerfan55 like this.
  2. Model A Gomez
    Model A Gomez
    The bent spokes are Kelsey Hayes and are more desirable and there were a lot more of the straight spoke wheels made by Ford. I prefer the look of the Kelsey Hayes but they generally sell for more.
  3. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Bent spokes should be aftermarket like "Kelsey Hayes" they were stronger than the stock 1935 Ford straight spokes.
    Problem solved, put bent spokes on one side, and straight spokes on the other side of the car. It would throw some folks off for sure!
  4. rusty valley
    rusty valley
    IIRC, bent spokes-40 spokes. Ford wheels-36 spoke. Stronger? They just look cool
  5. I'm a straight spoke 1935 Ford wheel kind of guy, But everybody claims that the Kelsey Hayes 40 spoke 16" bent wires are a little stronger and they are considered the holy Grail of wire wheels for the traditional hot rod world That being said to me they look busy and they also are really expensive, a nice set can be around a thousand bucks or more, on the other hand a nice set of 1935 Ford wires I literally sold some 48ish hours ago that were painted red and it took me a few weeks to get 200 bucks... Sometimes you can find 1935 Ford 16-inch wires for as little as 20 bucks each in usable condition, The going rate is usually about 40 to $50 a wheel that needs sandblasting but looks to be usable A Kelsey on the other hand if you only have one is probably around a hundred bucks some people will ask $200- (to future readers This is 2025 pricing and my prices are from Southern California And my love for swap meets and old wheels).
    Here is my almost Model A/HupMobile jalopy with its 1935 Ford wires. 0702252028.jpg
  6. '29 Gizmo
    '29 Gizmo
    from UK
  7. dwollam
    dwollam
    I like the straight spoke '35 wheels better than the bent spoke but maybe I'm just cheap!'
    Dave
    Tow Truck Tom likes this.
  8. '29 Gizmo
    '29 Gizmo
    from UK
    Straight spoke ford wheels have welded spokes. Makes a very neat spoke profile. Bent spokes tend to have seperate bolt in spokes that can look a bit more cluttered at the rim when the spokes are very short. Just my observation.
  9. uncle buck
    uncle buck
    The Kelsey wheels are prone to cracking around the spokes so look at them closely. I have seen a lot of them welded
  10. HOTRODPRIMER
    HOTRODPRIMER
    Different spokes for different folks, Personally I prefer the bent spoke Kelsey Hayes.
    16" Kelsey - Hayes bent spoke.
    16" Ford straight spoke.
  11. RICH B
    RICH B
    Always felt that wire wheels are obsolete and any self respecting hot rodder would have switched to disc wheels as soon as the '40 Fords came out.
  12. HOTRODPRIMER
    HOTRODPRIMER
    I have been known to color outside the lines, Both of these '32 Fords were powered by Flatheads, nothing strong enough to damage a wire wheel, I also believe the Kelsey - Hayes are a much stronger wheel. HRP
    Tow Truck Tom and bchctybob like this.
  13. lostn51
    lostn51
    from Tennessee
    Hell I like them all:D
    Just Gary and Tow Truck Tom like this.
  14. silent rick
    silent rick
    don't forget the special spacers to prevent damaging them when tightening them to a drum with a flat mounting surface
  15. tubman
    tubman
    They're both cool. I've never seen a lot of difference between the two of them, so when I decided I wanted wires on my Tub, it was an easy choice to go with the regular Ford wheels. Most people couldn't tell the difference if they tried.
  16. alchemy
    alchemy
    If a bent spoke crosses another once it’s a Motor Wheel brand. If it crosses twice it’s a Kelsey Hayes brand. Both of those are the welded spoke type.
    Then, KH also made an adjustable spoke wheel for Fords in 16” that looks very similar but has the little adjustable nut thing at the base of every spoke. These are worth twice what the welded bent spokes cost. They have the 5.5” bolt pattern and take regular Ford hubcaps.
  17. 51 mercules
    51 mercules
    Aren't Motor Wheels 36 spoke and Kelsey Hayes 40 spoke?
    Tow Truck Tom and 34 GAZ like this.
  18. GuyW
    GuyW
    I apparently have Motor wheels but I'd rather have Buffalo wires....
    ...an inconsistent position, because 1. Buffalo wires are retro as compared with any of these wire choices and 2. I also agree with RichB above...
  19. 51 mercules
    51 mercules
    I pprefer the bent spokes over the straight. Some pics of my roads 97.jpg DSC03443.JPG ter with bent and straight.
  20. alchemy
    alchemy
    Good enough for Jake’s coupe, good enough for me.
    Just Gary, Tow Truck Tom and mvee33 like this.
  21. rusty valley
    rusty valley
    I like wires, have had a few sets on the road. If you are a hillbilly like me and drive gravel roads, they are a ***** to wash, and the center hub sticks out further than the tire so within a thousand miles the paint around that front hub is all beat up from gravel off the back wheels
  22. I've had both here and if i remember you are correct.
    Tow Truck Tom and 51 mercules like this.
  23. Fortunateson
    Fortunateson
    I agree and I AM cheap!
    dwollam and Tow Truck Tom like this.
  24. Andy
    Andy
    Funny swap story. I was selling some NOS Kelsey's and a guy wanted to know if they were straight, I told him they were never on a car. He started rolling them across the bumpy dirt isle to check them. He would roll and roll and he could not determine if they were straight. They were bouncing up and down in the dirt. He p***ed.
    Papas32, 34 GAZ and Tow Truck Tom like this.
  25. My bent spokes are riveted.
