Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. Tim
    Tim
    from KCMO
    I know that had to grate on your emotions watching then all tear away with out you. It so close! But you taking your time will let you enjoy it a lot more when the time comes.
  2. 41 GMC K-18
    41 GMC K-18
    Hey @J.Ukrop
    Hey Joey, "Imitation is the highest form of flattery"
    That being said, when I saw the very cool "Echlin" starter solenoid that you are using, I said, that is the most unintended, kick ***, natural robot face, that reminds me of cool vintage toys and space stuff from the 50's.
    So I had to tinker with it and use it as one of my many whacked out avatars for the H.A.M.B.
    Thanks for all of the continuing cool updates on this magnificent obsession that is culminating in one cool, kick *** ride!
    Thanks from Dennis.
  3. Tim
    Tim
    from KCMO
    Ya know while you wait on parts you could “bench bleed” the master while it’s mounted in the ch***is.
    Six Ball, winduptoy, J.Ukrop and 2 others like this.
  4. warbird1
    warbird1
    Check the torque on those axle nuts periodically. The first season I was driving my '40 I checked them 3 times and they tightened up a bit each time. Now they get done once a year even though they've stopped moving... just ensuring there's no movement of the hub on the axle.
    Six Ball, winduptoy, Jeff34 and 3 others like this.
  5. Outback
    Outback
    from NE Vic, Oz
    I'm yet to have a proper look at my axle tapers, but since I've been in this job I have learnt the value of a well lapped taper, the key shouldn't be doing the work, but the fit of the taper. We aim for some where near 8 tons of 'break away' albeit a larger shaft size.
    Your roadster is coming along so nicely Joey, it's exciting to see!
    Six Ball, winduptoy, warbird1 and 3 others like this.
  6. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    So so true. Everything in due time.
    Hahahah I love it, Dennis. And I'm honored to have one of my shots as your avatar. Or should I say "001010001000100100101010."
    Good advice, thanks!
    Thank you so much. We're getting there!
  7. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Okay @Jeff34, here's what I got:
    • Sta-Lube SAE 140 Gear Oil for the transmission
    • Royal Purple 75W-90 full synthetic, which should be the right one according to our friends at @Winters Performance.
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Tonight's update is a minor one, but I'm pretty excited about it. IMG_0986.jpg
    My mystery dash knobs arrived in the mail, and they're just perfect. They have a great feel to them, and the textured pattern is right at home with the pitting on the steering wheel and the insert's wrinkle finish. The black washers will be replaced by chrome ones once I can make it to the hardware store before it closes.
    While I was mapping out my wiring the other day, I decided I wanted matching switches with a refined personality. The one on the left is for headlights, and the one on the right is for the electric fuel pump.
  9. Six Ball
    Six Ball
    from Nevada
    Good stuff. Outback is right about the taper fit. It should be possible to run without the key. It is just an aid to make it last longer and be tougher. At any rate a good fit makes it less likely to shear a key. Maybe more likely to break an axle. Do you have safety hubs?
    There is a version of that solenoid with a ****on on the bottom. Several of my old Fords had them, some tractors & Internationals too. It allows you to turn the engine from under the hood without help to getting to the dash ****on. Very handy.
  10. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Today I was greeted by two great packages on my doorstep. We now have wheel bearing seals and battery cable. IMG_1026.jpg
    Two of the cables have already been installed, and the starter solenoid is bolted in. I'm looking forward to getting out to the garage this weekend and making some progress!
  11. Crusty Chevy
    Crusty Chevy
    Keep an eye on the new tie-rod rubber boots as well. They are made of the same junk rubber. I had some that look just like yours go bad sitting still in the garage after 0 miles and 1 year. Replaced with old ones and no issues.
  12. Six Ball
    Six Ball
    from Nevada
    Do you have a can of black shoe polish? You could do a Burt Munro.
  13. "I didn't see that."
  14. Jeff34
    Jeff34
    Just watched that movie again last night! filling the cracks on the tires with shoe polish is magic!
  15. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Hahahah I was considering it! That movie is the absolute best.
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Luckily, no shoe polish was needed. Tonight's tasks went about the opposite of how I expected, which I should expect by now. I had figured the dust seal swap was going to be tricky with the brake shoes still in place. Well, with some jockeying and a little bit of strategy, I successfully removed the cracked boot and slid a new one on. I think I learned the tape-on-brake-shoe trick from one of you guys, but it's a technique that I'll use for the rest of my life.
    I wouldn't say that that first part was easy, but it was much simpler than getting the drum in position. Both the keyway and the key needed to be cleaned up, but when it was all said and done it slid together. Some choice words were used (not loud enough for the neighbors to hear) and I was 15-minutes late for dinner. That said, I think I'm on the right track. Tomorrow, I'm going to finish torquing and installing the cotter pin.
  17. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Here's the closing shot for the night. I had to pop open the quickchange cover to see what my starting gear set will be. In its current configuration, it's a 4.11. If I flip them, it's a 3:48. I'm thinking I'll start with 4.11 because it will be a bit of time before this guy sees the 101 down to SFO.
    That's all for tonight. Maybe I'll do front wheel bearings and seals tomorrow. We shall see!
  18. Tim
    Tim
    from KCMO
    Awesome! Care to clue me in on the tape trick?
    winduptoy, 41 GMC K-18 and Six Ball like this.
  19. Likely to keep dirty fingerprints and other stuff off of the linings.
    winduptoy, Six Ball and RodStRace like this.
  20. Dedsoto
    Dedsoto
    from Australia
    That axle taper looks pretty beat, I'd be lapping the hub to the taper with some valve grinding paste before installing. As is, it looks like you'll be putting a fair bit of the drive through the key, not the taper
  21. Six Ball
    Six Ball
    from Nevada
    "and I was 15-minutes late for dinner. "
    Next month my wife and I will celebrate our 56th anniversary. In that time I have learned that breakfast is the most important meal. You can be late getting home for lunch or dinner but if you are late getting home for breakfast you are in a lot of trouble!:eek:
  22. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Sidebar 220: On Hold IMG_1138.jpg Summer is always a busy time, and this year is no exception. There are many exciting things in the works, including a big move across town into my own apartment. Seeing your car on a rollback is usually a bad feeling—but not this time. As I write this, it's tucked away in the ba*****t of my new building. It's going to take some time to get things set up over here. But as soon as I rolled the car into the garage, I realized that this is where 2.0 will have its first drive. Stay tuned.
  23. Dubonet Garage
    Dubonet Garage
    from France
    Hey Joey,
    A certain nostalgia invades me while reading this.
    Your street in San Francisco, so far from the suburbs of Paris, has become so familiar!
    But I have no doubt that the future will be even better.
    So, let's go and happy moving!...
    Hugues
    J.Ukrop, winduptoy, Deutscher and 3 others like this.
  24. 41 GMC K-18
    41 GMC K-18
    "The only thing certain is change"!
    Bravo, the kid gets his own crib and a new adventure is beginning!
    Bravo from Dennis.
    Farewell "Loyola Terrace"
  25. "The only thing certain is change. . ." but don't go asking for change. That just makes you a panhandler.
    I moved my hotrod twice through the 51+ years I've been building it. Sometimes garaged, sometimes wholly out in the open, sometimes a combination of pieces in barn haylofts, rafters of cramped garages, and an attic. I'm about a week away from starting it for the first time in more than half a century. You're faster than me by a long shot.
    rod1, J.Ukrop, 05snopro440 and 9 others like this.
  26. gimpyshotrods
    gimpyshotrods
    Which neighborhood is the new one?
  27. Outback
    Outback
    from NE Vic, Oz
    Have you got a thread telling your story?
  28. Outback
    Outback
    from NE Vic, Oz
    Exciting times for so many reasons, I"m sure we'll at least see 2.0 back in Loyola for a photo shoot! Keep enjoying the journey :cool:
  29. I never felt like I was doing a good enough job, or making enough steady progress to post glimpses of this journey. Now here I am, about a few days or weeks away from a start-up, and I guess it's time to drop a few photos. I'll have to do it on the off-topic forum because Moriarty points out that this thing is on an AA frame with 1960 F-350 duallies, rear axle, front spindles and brakes. Stay tuned, and thanks for the interest.
  30. Tim
    Tim
    from KCMO
    Good stuff man.
    winduptoy likes this.
