9s for $9k
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Mar 18, 2025.
  1. I wouldn't say no way..
    There's what I do>
    Put you back brace in place and trace it on the main hoop it with soapstone or whatever.
    Remove back bar, and build up a little nub of weld on the main hoop at 12 o'clock , right above your marking .
    Now, put your brace back in.
    Shoot out about a half in. of wire from the nozzle.
    Get you head up there as far as you can.
    When the wire hits the nub, your arc will start.
    Drop down a tad and bring you bead down to where can see what you're doing .
    Same thing on the other side.
    If you've got a spare nozzle , you can squash it down in a vise to give yourself a bit more room.
    A clamp on bucket light helps a bit too , for us old fogies.
    It may not look perfect up there when you're done , but I've checked out the welds with mirror, but you should end up with a 360 deg. weld ;-)
    porkshop and rod1 like this.
  2. swade41
    swade41
    from Buffalo,NY
    I thought of this rollbar debate when I seen this truck, can't say as I've ever seen the curved bar to main hoop before.
    Screenshot_20250620_191134_Facebook.jpg Screenshot_20250620_191118_Facebook.jpg
    porkshop and Sharpone like this.
  3. DDDenny
  4. Dick Stevens
    Dick Stevens
    I'd say, not ideal but better than nothing
  5. squirrel
    My reading of the rules does not require the rear bars to exit the cab. But maybe someone will show me where it says it has to. (I mean for a roll bar, not a cage)
    porkshop, 41 GMC K-18 and 19Eddy30 like this.
  6. swade41
    swade41
    from Buffalo,NY
    My friend that owns the Bizio truck had to go with a funny car cage to keep from cutting the truck cab for rear bars.
    porkshop likes this.
  7. squirrel
    That makes sense.
    They specify a minimum angle for the bars on cages, but not roll bars.
    porkshop and 41 GMC K-18 like this.
  8. snoc653
    snoc653
    from Iowa
    I’m certainly not an authority on this subject. But if the bar had to be braced rearward, I would think the same plate mount system as on the floor to subframe would work and allow bars to p*** through the rear of the cab.
  9. swade41
    swade41
    from Buffalo,NY
    Model A coupes have the sme problems with getting the correct angle on the rear bars without sticking out like the old 70's bolt in 4x4 bars with KC lights.
    My ch***is builder friend worked hard to get these as low as he could while still being legal.
  10. I'd ***ume if that rule does exist, then it's cl*** specific and laid out in SFI Spec.
    For your typical roll bar or rollcage, I'm thinking as long as the bend is done by being drawn over a die and not crunched or kinked, then you're all good.
    porkshop and RodStRace like this.
  11. 19Eddy30
    19Eddy30
    from VA
    Support other Sanctional bodies
    Out side of NHRA ,
    ottersea and porkshop like this.
  12. AmishMike
    AmishMike
    Best recent post by “borntoloze” - “carry on”.!!! Squirrel - how goes the “Ceep”???? Get or try 15 lbs boost yet?
  13. squirrel
    And there are no SFI specs for roll bars or 8.50 and slower cages.
    Thanks for the update.
  14. oldiron 440
    oldiron 440
    Maybe it’s changed or more thorough at other tracks than the ones I’ve been at but tech doesn’t seem to spend much time on a cage in a 10.0 car, everything gets a quick look with the most attention given to the bars around the driver and window net installation. Nothing really sends you home but fix it before you come back is what I’ve seen. I’ve seen a few swing out bar ideas not go over well but have seen some **** aloud on the track that shouldn’t have been.
    porkshop and squirrel like this.
  15. Exactly.
    I really wanted to put a cage in my '56, but I didn't want to put the rear down bars through or above the rear window, and there's no way to have a legal cage without those bars unless a funny car enclosure gets installed, which now puts it into SFI territory and is way too much work and effort for a truck that may never see single digit ET's. I'll p***.
  16. The last car I had to run through tech was my last Foxbody Mustang. It had a 6-point mild steel bar in it. The tech inspector barely looked at the roll bar, and if I remember he basically reached his arm up and felt the weld at the main hoop and rear down bars on the drivers side. He was more concerned with the battery box hold-down bolts and that I didn't have a "push/pull" sticker that told what the battery disconnect did.
  17. 1964countrysedan
    1964countrysedan
    from Texas
    As long as you roll bar engineers realize what yall did to an otherwise great focused Squirrel build thread...
    NoSurf, dogwalkin, porkshop and 7 others like this.
  18. 19Eddy30
    19Eddy30
    from VA
    I do not under stand , Yes there Is rules,
    Recommendations , ext !
    There Is No guarantees even Over built more then Certain rules ,
    Thousands of people get on a commercial plane every day
    No parachute,
    If on a Water craft Need Life preserver!
    Ride a Motorcycle some wear Helmets,
    Now there is Air Bag suits for Motorcycles,
    Horse ?
    Bull Riding,
    Running with the bulls .
    Life is full of Dangers , even walking
    Watch Ferrari : Race to Immortality , do***entary theres a part around
    1950 Race maybe 24 hours at
    Le Mans ? Or another famous Race Track, car coming into pits , clip wall
    Car came apart threw pit lane & spectator crowd Like 180 People
    Injured 90 or 100 something killed .
    Study , watch History of
    Coney Island NY
    1920 - 40s Many injured and killed ,
    Close 20 year ago Eric tire when Square,
    Scotty
    Australian pro mod driver , car crashed
    @ bottom end jumped wall , are born
    Clipped Concrete telephone pole over
    100-200 feet side of track Cut car in half
    Final Round , Word Champion Run
    Won ,
    2010 ,Friend of mine Neal Parker A/Fc driver .
    Back in 70s I was up in burn out to starting line , I was about 8 , match racing Funny Cars , Spark plug came threw body peg me in chest ,
    To this day when @ track I stand on line
    Narrow track 40 foot wide after Tree
    Staging about 10 foot between fender's
    We get cars in 4:20-60 in 1/8
    Fastest and record Is a Funny , 3:70ish
    & Small tire , 3:83 car was set up to click
    Off @ 3 sec into run ,
    If Scared dont show or Do ,
    I feel safe in my full race car , but it can happen ,
    My street I will only run 1/8
    its @ the three digits little over ,
    Another friend of mine Would always say Jonny Rocca
    Happy Motoring
  19. DDDenny
    What was the question?
    impala4speed and squirrel like this.
  20. 19Eddy30
    19Eddy30
    from VA
    Roll bar , Roll cage , debate
    Safety , One that think Rule book
    Prevents death , Is false
    dogwalkin likes this.
  21. swade41
    swade41
    from Buffalo,NY
    Sounds a little like our local track, I guarantee you won't get closer to a car going down track as a spectator.
    Right on the other side of that fence is the racing surface, not a shoulder, some cars are so close it'll **** the beer cups right onto the track from the vacuum. They run top fuelers here and everything, Shirley Muldoney held the record forever with a 3.50 then Todd Paton came in with a 3.306-second p***, and also the speed record at 233.00 mph, both set during Nitro Night of Fire.
    upload_2025-7-17_13-7-4.png 100_2467.jpg 100_2463.jpg Screenshot_20221202-085323_Message+.jpg
    19Eddy30 likes this.
  22. AmishMike
    AmishMike
    Wonder what will happen to sport of drag racing if bunch of people get killed standing next to a fueler. How is the squirrel’s build coming?
    Hope everyone can understand my sentence structure & wording
    Kommuter, 427 sleeper and Baumi like this.
  23. squirrel
    I'm going to go racing again when there's a chance, the drag strips around here mostly shut down for the summer rains.
    Still other things to tinker with on Cheep, though.
    and there's a LeMons Rally coming up soon, in the PNW, and I have to go on it just because. Corvette? Cheep? Which would be worse?
  24. AmishMike
    AmishMike
  25. Harv
    Harv
    from Sydney
    That photo reminds me of Jake and Elwood playing a bar in Kokomo...
    Benaraby Dragway in Central Queensland gets you almost that close:
    Cheers,
    Harv
  26. noboD
    noboD
    Thank you Squirrel, for returning your thread to what it's supposed to be. This my **** is bigger then yours argument gets old. I enjoy reading all the tech in your threads but the bickering gets old real quick.
  27. 41 GMC K-18
    41 GMC K-18
    Definitely take "CHEEP", its an adventure, and it will be a fun challenge to see what you may have to fashion from found objects out on the road, to protect the engine from hostile weather related elements !
    Your results may vary greatly!
    Perfect driving hat, to fend off the hail stones, the chin lanyard is a must!
  28. squirrel
    well, I decided to take the Corvette on the rally.
    I think it might be a more fun drive through the mountains.
  29. squirrel
    The Vette did fine on the rally..Drove 70 mph a lot of the time, it was happy, although the weather was a bit warm at times (105 on the way up through Las Vegas, 111 on the way home through Blythe).
    Now that's over...time to think about Drag Week and Cheep. I talked with my wife and she said she'd go if I hauled the car up to MD on the trailer. So I'll do that. Not that I don't have a lot of confidence in it...well, I don't...but just to have a car adventure with her, and keep her slightly comfortable. She's ridden in Cheep a few times, and says it's a lot better than Plan II was :)
  30. gene-koning
    gene-koning
    It does seem the wife has a different view of how a performance cars should be then we do, especially when it comes to long road trips.
    If we want to keep them involved, there are times compromises have to be made.
    Is you wife going to be the "pit person" with you while the two of you participate in the Drag Week event, or are you planning on trailering Cheep between the strip events?
