No wonder we prefer old cars.
Discussion in 'Off Topic Hot Rods & Customs' started by lothiandon1940, Jul 18, 2025.
  1. lothiandon1940
    lothiandon1940
  2. slowmotion
    slowmotion
    That's a sensitive post! :D:eek:
  3. squirrel
    missed an increasingly important one... the spy cam! sits at the top of the windshield and nannys your driving.
  4. J. A. Miller
    J. A. Miller
    from Central NY
    In our old cars, the sensors are part of the organic interface behind the wheel... :D
  5. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    I've got more of a beef with CANbus vehicles than EFI in general. I want to put a window down. Why in the blue hell does it need to route this command through a computer first? One thing goes on the fritz and the whole damn vehicle is disabled.
  6. FrozenMerc
    FrozenMerc
    This is about 30 years old. Today's stuff is exponentially more complex.
  7. RodStRace
    RodStRace
    Yep, that is the SIMPLE version!
    Back in 2004 I wrote some of the testing for the Blackwood, the Lincoln truck that they kind of swept under the rug.
    It had rear view mirrors on each side. Sure. They were power. Okay. Then they were memory too. Okay. Then they tilted down at different angles when the thing was in reverse. Yes, the TCM reported the trans position to the PCM, which sent a signal to the memory module to tilt down the mirrors.
    The 7 series BMW of that era had no throttle. The intake had a scroll inside a scroll to adjust the intake runner length and the intake valve opening was computer controlled allowing the PCM to take your request for throttle and determine how much to open the valves to get that engine speed. That was 20 years ago.
    Now almost everything is a request and software issues are huge. Look at electric door handles, trunk and seat controls for new to 2 year old stuff. There will be deaths.
  8. chevy57dude
    chevy57dude
    Makes me hungry for a magneto fired push start racer with only a kill switch and an oil pressure gauge.
  9. lothiandon1940
    lothiandon1940
    ...Absolutely!
  10. Zottel
    Zottel
    A good 90's Efi is ok, but non of this "multimedia tracking your life" BS
  11. AldeanFan
    AldeanFan
    Yep,
    My 2010 Ford Flex had a problem where the computer thought the engine was 500° when it was stone cold and would shut down the engine.
    Two dealers and two independent shops gave up trying to fix it.
    Lucky I had the Y-block powered ‘54 Country Squire to drive when the new ford wouldn’t run.
  12. twenty8
    twenty8
    ... A little bit misleading maybe for some....
    It is a lane ***ist camera that faces forward to read the road lane markings. It is not actually facing the driver.
    This, however, does not mean that it is not capable of recording where you have been......
  13. Sharpone
    Sharpone
    Some cameras look at the driver. DMS driver monitor systems. I will not drive any vehicle with a camera pointed at traffic, or the driver. Back up cams are Ok in my book, Do as you want but I think this **** is a slippery slope.
    Dan
  14. squirrel
    I meant it's a nanny, watching how well you're driving.
    Yes, it's forward facing.
  15. Sky Six
    Sky Six
    from Arizona
    I, unfortunately, had to go to Oklahoma for the funeral of a fellow Marine this past weekend.
    Avis gave me a brand-new Toyota Corolla. This thing had a huge screen right in the middle of the dash.
    I made it to my destination before I knew how to turn on the radio.
    I'm so old.
  16. twenty8
    twenty8
    In the litigious world we now live in, a dash cam could be a good idea.
    Just make sure it is one that you control, not one that can send footage who the hell knows where.
  17. twenty8
    twenty8
    Condolences. Days like that are never good days.
    down-the-road, Wobbly, Deuces and 3 others like this.
  18. Sky Six
    Sky Six
    from Arizona
    Thank you, I appreciate it.
    twenty8, Deuces, RodStRace and 2 others like this.
  19. Paulz
    Paulz
    Sensors. No problem. The **** is the 20 different modules that all have to be friends in order for the car to do car things. And using electronic control to do things that have been mechanically controlled for a hundred years. Tesla door handles, I'm looking at you.
    And touch screen radio and HVAC controls ****. Push a ****on, turn a knob, it works without having to look at it first.
    TerrytheK, lostn51, Ned Ludd and 7 others like this.
  20. Sharpone
    Sharpone
    Condolences to you and your friends family and friends.
    Thank you for your service!
    Dan
  21. rustydusty
    rustydusty
    My first vehicle (‘41 Chevy pickup) had numerous sensors. My eyes, my ears, my nose, hands, feet, even my ****, all giving me feedback on what was happening with the truck while driving…
  22. My 1st efi vehicle was 1983. That's 42 years ago. Doesn't that qualify for old? :)
    porkshop and Sharpone like this.
  23. As RodStRace said most driver inputs are a request on new cars. On lots of cars the brake pedal is no longer connected to a pushrod into the master cylinder. You press the pedal and feel resistance from the emulator spring. The computer than decides how hard to apply the brakes or in the case of electric cars it decides if it will use regenerative braking or the brakes. Press the gas pedal and the computer decides if it will open the throttle. Even steering is starting to go computer ***isted. I was moving a car with a bent tie rod at work and the car didn't like that the steering wheel was not straight, it spun full lock to the left then full lock right before centering. Luckily I was only going 5mph.
  24. RodStRace
    RodStRace
  25. leon bee
    leon bee
    I have a 2015 where I'm still pissed it doesn't have a transmission dipstick. None of that other stuff has gone wrong yet, but I been trying to modernize a little bit anyway.
  26. 41 GMC K-18
    41 GMC K-18
    Back in a time period, when things were more simple and more easily accessible !
    miller shift and tach 1 (2).JPG miller cockpit 2 (2).JPG miller duel distributor (2).JPG pontiac flathead 6 banger (2).JPG engine right side 2 (2).JPG miller left side (2).JPG eddie miller Jr. reader board (2).JPG
    Deutscher, lostn51, Ned Ludd and 7 others like this.
  27. Kerrynzl
    Kerrynzl
    Good ol' 90's technology
    What about the infamous "Matty Box" United States Patent # 5,051,935 - Date Awarded: 9/24/91
    It was used for bracket racing
    https://patents.google.com/patent/US5051935A/en
    They used a wheel speed sensor [or electric speedo drive] then it was connected to ignition retard and nitrous.
    Triggered from a transbrake ****on and if you used a delay box a monkey could win the bracket nationals
    Fitty Toomuch and 41 GMC K-18 like this.
  28. Matt Dudley
    Matt Dudley
    from New York
    I work on modern GM vehicles daily. Some of the stuff is crazy. Radio updates crippling brand new cars. I appreciate things like the 360* cameras ( our shop is wayyyy too narrow ) and the adaptive cruise is nice. But there is something about an old car that is just ‘right’. I bet I’m the only guy there that can set points beyond one other guy that I know can, but probably never will because he hates working on the owners ‘65 C10 when it comes around. It has an HEI tho
  29. jazz1
    jazz1
    When i set the engine in my last build i found there were an overwhelming number of wires and sensors to deal with so changed intake and added a carburetor. Problem solved, no sensors, no ecm.
  30. Damon777
    Damon777
    Outside of the big screens, my issue is the need for everything to be friends.
    Why does water intrusion in a taillamp need to brick the truck?
