Technical Building a new Winfield...
Discussion in 'The Hokey Ass Message Board' started by Kevin Pharis, Nov 1, 2020.
  1. Kevin Pharis
    Kevin Pharis
    from Califunny
    So here we are, the custom cast plenum design manifold would not allow the carbs to be aligned in the “correct” orientation, so I have been running on a single pot since the head went back on. The plenum works well enough that there is no noticeable imbalance running just the one carb
    Still have the desire to run the duals, so the dual manifold was cut up, reconfigured, and welded back together. No longer a plenum design but will allow the carbs to be oriented and spaced properly. Hoping to get it back together in the next couple of weeks. Last thing to do is build some venturi reducers to put the carbs on a diet, lookin for about 100 cfm each
    0CE49CE4-8460-4CF4-A9F5-BC3C3BB13CE5.jpeg A6246675-F462-4BB0-B7E2-0CE1B00881E0.jpeg 73AEDDB4-227C-42C6-BCEE-E80C19F14A9B.jpeg
    rod1, BigRRR, Blown Red Ram and 5 others like this.
  2. The37Kid
    The37Kid
    Great looking Speedster, hope the mechanical problems are behind you now. Bob
    41 GMC K-18 likes this.
  3. Kevin Pharis
    Kevin Pharis
    from Califunny
    I hope yur right! So far all of my mods are holding up nicely, it’s just the insanely ****py design of the cylinder head that keeps me up at night. Only way to see if it breaks is to drive it!:cool:
    41 GMC K-18 and loudbang like this.
  4. The37Kid
    The37Kid
    Ok, your machining skills are light years ahead of mine, I'm trying to understand what I'm looking at. The replacement valve seat SOULD HAVE been cut for equal material in 360 degrees, NOT using the valve hole in the head, correct? Then the valve hole could be plugged and a hole matching the new seat could be drilled and the rocker adjusted to match contact.
  5. Kevin Pharis
    Kevin Pharis
    from Califunny
    Sooooo… this head design is ****pier than that. The port is actually larger diameter than the valve opening on this head, rather than a smooth flow like we are all used to. Additionally, there is no water jacket between the combustion chamber floor and the port. With only a 1/4” thick web of iron to set a hard seat into, they broke thru as seen in your pic. Moving the stem location would not have helped. Only bribing a cast iron welder would have helped this damn thing!
    I ended up machining a stepped hard seat to create a full circle contact at the base to correct the settling. If this doesn’t work… next step is begging for bribe money:eek:
    2C9CD4BF-F3BE-43B3-9630-2EF0C33CE4CC.jpeg 0807DA33-F50A-4611-B540-6B9798BD4F26.jpeg
    40 Olds and 41 GMC K-18 like this.
  6. Kevin Pharis
    Kevin Pharis
    from Califunny
    Oh yeah, don’t want to mess with the custom machined rocker geometry
    rod1, 40 Olds, Carter and 4 others like this.
  7. The37Kid
    The37Kid
    That does look lighter than the tubes of ball bearings. :confused:
    41 GMC K-18 and fauj like this.
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I've been burned several times by "professionals" who did sub-standard work on my junk and either ruined it or required extensive rework.
    SUX
  9. It's such a cool project, and thank you for the updates.
    41 GMC K-18 and SS327 like this.
  10. Kevin Pharis
    Kevin Pharis
    from Califunny
    Been a while since the last update… got it up and runnin before summer and all is well again. The reworked dual manifold is working fantastically! The venturi reducers did the trick also. Idle is good, transition is good, just a bit of lean miss when shifting into top gear after winding out mid range. Oh yeah, the 2 speed rear end shifts with a dog clutch so not much time for fuel to flood the accelerator wells, no suprise on the high shift miss
    rod1, GuyW, BigRRR and 16 others like this.
  11. 41 GMC K-18
    41 GMC K-18
    Hey @Kevin Pharis
    Simply magnificent!
    Indeed perfection cannot be rushed!
    I think my friend @Hitchhiker would be very impressed at how all of this turned out!
    Thanks from Dennis.
    BigRRR likes this.
  12. Kevin Pharis
    Kevin Pharis
    from Califunny
    Been workin on makin some more AA-B choke horns, but this time adding the raised lettering. Hope to start on a BB-C choke horn tomorrow…
    y'sguy, rod1, rusty valley and 12 others like this.
  13. Cliff Ward
    Cliff Ward
    This AA-B choke horn looks great Kevin...thanks for continuing to build out the list of available parts for these wonderful Winfield carburetors.
  14. Kevin Pharis
    Kevin Pharis
    from Califunny
    DUN! Winfield S/SR choke horn size C. Also fits BB
    And after much pestering for far too long, I finally started up a website. Not much on there yet, but trying to add something every couple of days. Now I have to start taking better pics:rolleyes:
    https://eraspeed.com/
    G Baese, 42merc, 41 GMC K-18 and 10 others like this.
  15. Kevin Pharis
    Kevin Pharis
    from Califunny
    Received a new toy today! Hoping to make more interesting carb parts soon…
  16. 1-SHOT
    1-SHOT
    from Denton
    That’s a big toy
    Sharpone and 41 GMC K-18 like this.
  17. patsurf
    patsurf
    how many axis?-fun!!
    Sharpone likes this.
  18. Kevin Pharis
    Kevin Pharis
    from Califunny
    Only the important ones… X/Y/Z/B/C:D
  19. RodStRace
    RodStRace
  20. patsurf
    patsurf
  21. noboD
    noboD
    Where are the handles?
  22. Now it's time to get serious. Keep the updates coming.
  23. Kevin Pharis
    Kevin Pharis
    from Califunny
    It’s alive! Hope to level and square it tomorrow morning, and be making parts by lunch:D
    Sharpone, elgringo71, G Baese and 6 others like this.
  24. nrgwizard
    nrgwizard
    from Minn. uSA
    Hmmm...
    Boy howdy; I can think of more than a few parts I'd like to see that thing kick out. Not that I could do it, much less afford them... ;( .
    Marcus...
  25. Kevin Pharis
    Kevin Pharis
    from Califunny
    Success! Well… partial success. Got er all squared up and runnin, but still need to add coolant and order some workholding. So workin with what I got! An old Kurt vice, a little imagination, and some WD-40 will get a few small jobs done:cool:
    Sharpone, rod1, elgringo71 and 5 others like this.
  26. RodStRace
    RodStRace
    The old shop had one of those old candy style scoops to slog out the chips. Very handy.
    That and a small rectangle of soft aluminum to get the last bit in the corners made short work of it.
  27. Kevin Pharis
    Kevin Pharis
    from Califunny
    Slowly getting the new toy set up with better tooling, and starting to make noticeable progress. This week’s project was the Winfield CC/D choke horn.
    Choke horns for AA/B, BB/C, and now CC/D!
    Sharpone, Ken Smith, GuyW and 11 others like this.
  28. Kevin Pharis
    Kevin Pharis
    from Califunny
  29. The37Kid
    The37Kid
    Horns look great! What were the originals cast in that give them that unique look?
    Bob
  30. Kevin Pharis
    Kevin Pharis
    from Califunny
    The original castings are of zinc alloy (pot metal), but not a typical blend as they are unusually heavy. Mine are machined from solid aluminum, but have been looking into alternative materials that accept plating better…
    Sharpone, porkshop, rod1 and 3 others like this.
