Technical Out of Balance "Feel" - out of ideas, got any?
Discussion in 'The Hokey Ass Message Board' started by chop&drop, Jul 19, 2025.
  1. chop&drop
    chop&drop
    I've got two '32 Fords and I have the same issue with both of them - what feels like an out of balance tire from about 62-66 mph. They're both set up the same as follows:
    4" forged dropped axle
    Hairpins
    So-Cal "shorty" shocks
    Reversed eye spring with ****ons
    Panhard bar
    So-Cal steering stabilizer
    Vega box
    So-Cal spindles and disc brakes
    Toe set at 3/16"
    Caster set at 7 degrees
    15X4.5 wheels with 145X15 Michelin XZX tires at 32 psi
    Both sets of front tires have had the balance checked three times and balanced perfectly with little weight added.
    I'm open to any ideas. Whatcha got?
  2. 325w
    325w
    What company made the steering box? How much torque on the pitman nut?
  3. chop&drop
    chop&drop
    I don’t know who made the boxes. They both came from So-Ca but years apart. Neither one has any noticeable play. As for the torque on the pitman arm nut, I don’t recall. I can probably put a torque wrench on them to find out. They both have lock washers on them and are definitely tight.
    winduptoy likes this.
  4. catdad49
    catdad49
    Play with your front tire pressure, 32 psi is a little much.
  5. 5w Jen
    5w Jen
    from Sweden
    We had the nut on the pitman arm bottom out so the pitman arm still had a little play. A large dia washer solved that.
    winduptoy and ffr1222k like this.
  6. chop&drop
    chop&drop
    I’ve had as little as 28 psi in them - no difference. I’m back at 32 psi. because they’re small and carrying a sbc.
  7. chop&drop
    chop&drop
    Both pitman arms are definitely tight.
    winduptoy and 5w Jen like this.
  8. Jmountainjr
    Jmountainjr
    When you say "feel": vibration / shake in steering wheel; vibration in the seat; excess road shock???
  9. chop&drop
    chop&drop
    I can feel it through the wheel, and seat. Road surface doesn’t seem to affect it.
  10. manyolcars
    manyolcars
    check the wheelbase on both sides. it should be the same
  11. Jmountainjr
    Jmountainjr
    I would feel more confident in the following if it was just the steering wheel. You might not feel play in the steering but the center pre-load adjustment could still be off and maybe the stabilizer is masking part of it. I would disconnect the steering box from the draglink and also disconnect the input connection. You should be able to find a 12 point socket that will fit the input spline. Then center the box and go through the process of setting the specified center pre-load with an inch-pound torque wrench.
  12. captaintaytay
    captaintaytay
    I was reading somewhere that a seat vibration can be detected to a issue from the rear of the vehicle. Possible drive train issue.
  13. chop&drop
    chop&drop
    I’m sure they are but I’ll check them anyway.
  14. Happydaze
    Happydaze
    Avatar 5w looks like ****. You'd best send it to me.
    Agreed on looking beyond the front end. Engine mount, trans mount, tailshaft bush, universal joints, rear end link bushes, rear wheel balance, rear wheel bearings. Those big rear meats chew bearings. First had experience here. 2 similarly set up 32's here, but no 5w!
    Chris
  15. chop&drop
    chop&drop
  16. chop&drop
    chop&drop
    I’ll try checking that kind of stuff, but everything you listed is new (2k miles) on the coupe. The roadster has @20k miles on it but I haven’t found anything worn on it. Weird thing is they both feel the same at the same speeds. Both 350 sbc’s but the coupe has a Tremec 5 speed and a Winters QC and the roadster has a Super T10 4 speed and a 9”.
  17. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Any Check on U joint angles?
  18. lostone
    lostone
    from kansas
    Get it up to speed, right in the middle of the vibration, let off on gas and kick it in neutral, does that change anything? If it goes away kick back in gear and back to speed. Does vibration return? If so kick it in neutral again, does it go away again? If so it's drivetrain/engine related not tire.
  19. chop&drop
    chop&drop
    I’ll try that
    I hadn’t thought of that. I might try it but it only happens in a narrow speed range so it might be hard to catch it. Weird thing is that it’s the same on both cars.
  20. lostn51
    lostn51
    from Tennessee
    I’m voting driveline on this one just because I had a very similar experience. Pinion angle is what fixed it.
    tractorguy likes this.
  21. 2OLD2FAST
    2OLD2FAST
    from illinois
    Out of round , slipped belts , belt separation on front and/or rear tires , especially if the cars sit alot will cause this
  22. lostone
    lostone
    from kansas
    By trying it in and out of gear and engine idling IF it changes nothing then it rules out engine/drivetrain and just leaves suspension/tires.
    Went thru this on one of those 12 p***enger box vans. A vibration just like you described. Several shops had looked at it and given up so they brought it to us.
    We noticed in neutral and idle it went away. So we knew it was drivetrain. Long story short, after drive shaft balancing etc. We removed the seats and I crawled around on the floor at speed and mid vibration until I pinpointed it one spot. Brought into the shop and crawled under to that spot. Lo and behold a heat shield on the floor right above the muffler, removed it and vibration was gone. Re-installed and it was back, took it off and it was gone again. Thru shield away.
    GuyW, leon bee and BigRRR like this.
  23. Montana1
    Montana1
    I had a set of Speedway ll" GM rotors (5 on 4.5") on the front of mine that had that out of balance shake at 50-55 mph. I tried everything I could think of and couldn't find the problem. After 7 years, I discovered the lug bolt centerline was out of round by .035". They were drilled wrong!
    I ended up putting some Mopar rotors (5 on 4.5") on and they were perfect, and the shake was gone! ;)
    I got them from Johnny Law Motors: https://www.johnnylawmotors.com/cat...ake-rotor-with-5x4-5-ford-bolt-pattern-1-pair
  24. Bandit Billy
    Bandit Billy
    Where did you buy your tires?
    jaracer likes this.
  25. leon bee
    leon bee
    How did you discover that?
  26. jamesgs4
    jamesgs4
    from denver
    bias ply tires? might be out of round.
    Bandit Billy likes this.
  27. Happydaze
    Happydaze
    2000 miles? About the time it takes for a poor quality th350 style trans mount to fail. Don't ask me how I know! Hard to spot too as it doesn't have to collapse much for the outer steel casing to bottom out on the mounting plate, giving metal to metal. Any misalignment between the ch***is mount and trans mount just accelerates the process. I'm looking to fit an alignment wedge. Trans down 3 degrees, ch***is mount level with ch***is which has about 3 degrees of rake, so 6 degrees of misalignment, in my case.
    Chris
  28. jnaki
    jnaki
    Hello,
    Wow, here we go again. It is not a new thing but plenty of mysteries have been solved with a simple technical procedure called “tire shaving.” When we all get cars, new or old, we ***ume the tires are well balanced and the wheels aligned for smooth driving down the road. Most go the normal speeds on city streets for daily driving and do not go on freeways above 55 mph.
    But what we all ***ume are suspension problems may turn out to be simple out of round tires. If the wheel balancer on the machine is showing a lot of weight on one side, then perhaps the tire is out of round. What??? Tires not round? Aren’t they all in machines that get the same amount of rubber poured into the mold and popped out at the end?
    When we buy tires, we ***umed they might need some balancing and then mounted on our cars, old or new. But, perhaps one needs to take a closer look.
    That funny handling of your tires may be as simple as your tires not being round. Yes, not round. It depends on the brand and quality of the casings, but the rubber sometimes gets thicker on one side or the other. The 50s-60s solution was to balance them with new weights. But, with new weights, you were just counter balancing and not making the tire ride in a round fashion.
    So, the proper thing was to shave the tires. Sometimes the shavings left on the floor of the shop was horrendous. 1000s of miles seemed to be laying in a pile at the base of the tire shaving machine. But, it did make balancing simple and no use of m*** quan***ies of weights. Now that the tire is round and balanced, the wheel alignment can take place.
    If one just rebalances the wheel/tire and gets a new alignment, it still will give the same results. So, get those tires to a tire shaving place and watch how much rubber it takes to get it round. It will break your heart to see so much rubber on the ground.
    upload_2025-7-20_3-9-27.png Lion's Dragstrip 1958-59
    We had all of our Firestone stock factory tires shaved and balanced on the 58 Impala. No one wants to go through the 1/4 mile with tire shaking. It definitely lowers the resistance as the tires were round.
    Every time we got a new set of tires for any of our cars, tire shaving was the second thing done.
    Jnaki
    upload_2025-7-20_3-10-20.png It was the same for stock Firestones, Goodyears and other narrow tires.
    But, when I got a new set of Inglewood wide tires for my 65 El Camino, the shaving place was close by. So, I spent an hour of so getting those new tires shaved. My amazement was the rubber on the ground at the shop. But, the balancing took less weights and alignment made driving wonderful. No shakes, no drifting, added to the total miles cruising and long road trips until I got my second set.
    I put on more miles on my shaved tires, than my friend who just bought a new set the same time as I did and he did not get the tire shaving. 125k miles of no hands straight line driving and no shimmies, shakes or drifting at any speed. YRMV
    catdad49 likes this.
  29. 2OLD2FAST
    2OLD2FAST
    from illinois
    Are you saying the front & rear motor mounts are at different angles
    Happydaze likes this.
  30. Mr48chev
    Find a tire shop that still has an on the car spin balancer. If they have one with a strobe so much the better. But first you need to be able to just have the tires spun on the car to see if there is any vibration caused by the hub or drum or anything that wasn't on the wheel/tire ***embly when it was done on the machine. Do that before you drive yourself nuts trying to put the blame on some other part.
    I don't know if the on the car unit that I used at Frank Weaver Pontiac in Waco in the mid 70's is still around but I could balance tires to the knat's *** with that thing.
    captaintaytay, hotrodA and Moriarity like this.
