Technical Oil Filter Diameter
Discussion in 'Traditional Hot Rods' started by greg37, Jul 19, 2025.
  1. greg37
    greg37
    from mi.
    Hey everyone, I have a 1939 Ford Coupe with a 350 Chev. ( # 397001, 4 bolt main, 1969-80 ) I'm using a Wix 51069 oil filter however the diameter is just small enough to cause a small leak . Does anyone know of a slightly larger diameter filter . I used a dye / UV light to find the leak. Thanks Everyone !!!
  2. Fordors
    Fordors
    That Wix filter is correct for your engine, is it possible that you missed seeing the rubber gasket from the old filter stuck to the block? I did that once and had more than a slight leak :eek:
    Chris Nantus, vtx1800 and Budget36 like this.
  3. Budget36
    Budget36
    You and me both!
  4. greg37
    greg37
    from mi.
    Thanks, I'll check.
  5. lostone
    lostone
    from kansas
    Also check for scratches and gouges where the filter screws on the block and seals.
  6. rusty valley
    rusty valley
    I left the old rubber on once, double gasket, it sounds like someone vomiting, then by the time you can say"what the hell?", you got about 3 quarts on the floor
    Chris Nantus and Budget36 like this.
  7. squirrel
    There are other places that oil will come from. The oil filter to block seal on those engines never causes a problem unless you leave the gasket on, or there's some **** between the gasket and filter, etc. There's only one diameter, although there are a few different lengths.
    so look for other places that could be leaking, valve covers, rear seal, rear cam plug, rear oil galley plugs, block plug under the edge of the head, oil sender, oil pan, intake, gage sender/light switch, etc.
    leon bee and TRAVLR like this.
  8. TRAVLR
    TRAVLR
    Oil pressure gauge line/sender port is bad about leaking and running down the drivers side of the block making you think the oil filter is leaking. Seen this more times than I can remember.
    leon bee and Just Gary like this.
