Technical 32 front shocks
Discussion in 'Traditional Hot Rods' started by jdpaxton, Jul 18, 2025.
  1. jdpaxton
    jdpaxton
    I am tired of loose teeth after a short cruise in my 32 coupe with flatty 8. The car has stock suspension and examination of the front tube shocks someone years ago installed, are Monroe Sensi Trac AM10028BTO and googles "made to replace air leveling rear shocks". Said to be a gas shock. My buddy thinks these look exactly what Speedway sells. Aside from the terrible choice to use a "rear leveling shock," Bishop/Tardel Ford Hot Rod says to stay away from gas-charged units as they are much too stiff for a light car. Use a conventional tube shock. The tech sheet on mine show 9.75" and 14.75" extended. Anyone have a favorite?
  2. Andy
    Andy
    I had the best ride with Houdai? shocks. There is a pair for sale in the cl***ifieds by Contintaljohn for 50 bucks.
  3. Bandit Billy
    Bandit Billy
    I have to respectfully and vigorously call ********. I have chrome, gas charged, Bilstein shocks on my fender-less 34 and the ride is fantastic (I have them in the rear as well). I also run a flathead and br***/copper radiator so the noses on our cars are in same arena, weight wise. I notice no bone jarring, teeth shattering harshness to my ride. I liked them so much I put them on my 41 PU as well. But beware, not all gas shocks are created equal. Too light for gas shocks? Pshaw!
    dana barlow, HemiDeuce and 19Eddy30 like this.
  4. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    How did you grease your leaves.
    How is the ride with out shocks.
    Not for usage, only for testing.
    dana barlow likes this.
  5. 19Eddy30
    19Eddy30
    from VA
    Air pressure ?
    On 5w
    Front 25
    Rear 27
    Sedan
    25 F
    29 R
    I know some run
    32 on all four
    On one original Ch***is , original
    Friction shocks
    Then have Gas , & none
    & coil overs
  6. jdpaxton
    jdpaxton
    My next step I will indeed remove the shocks for testing. I have not lubed the front spring so that will be included. I can not stand on the bumper and get much movement. Thanks for the ideas.
  7. krylon32
    krylon32
    from Nebraska
    Done many 100's of 28-34 ch***is thru the years. My go to shocks are still the hydraulic tube shocks sold by Pete & Jake' s. No gas no nothing just a hydraulic shock with the right dampening for a light hot rod. I tried quite a few sets of gas hot rod shocks and found them to stiff. My latest experiment has been on Howard, my daily driver deuce pickup with Ride Tech Shocks. I've now got about 12,000 miles on the R T shocks which replaced P&J's. Is there a $1000 difference between R T shocks & P&J's? Not in my opinion. I've also sold a couple pairs of the Ford style lever shocks made in England and they appear to work good. P&J over R T. You may need to buy new shocks a little more often?
    ckh, NJ Don, bschwoeble and 2 others like this.
  8. xix32
    xix32
    How are yours positioned for travel? They could be bottoming out too soon.
  9. deathrowdave
    deathrowdave
    from NKy
    I was donated a pair for my 32 front a year ago . I think they had a QA2 sticker on them . I’d love to find a pair for the rear . Any help on where or who sells this brand ? Thanks and be safe
  10. jdpaxton
    jdpaxton
    At rest, the exposed shaft is 2 3/8". The installed height of the shock is 11.75". These look exactly like the gas shock and mounts speedway sells for common ford axle style so the specs are about correct for travel. Collasped 9.75 and extended @ 14.75.
  11. DDDenny
    You might have better luck if you Google QA1 shocks!
    19Eddy30 and Andy like this.
  12. deathrowdave
    deathrowdave
    from NKy
  13. NJ Don
    NJ Don
    I've tried many shocks on my avatar roadster and go with what Krylon said ... Pete& Jakes.
    Both their covered and uncovered shocks have the same dampening.
    Just Gary and ckh like this.
  14. jdpaxton
    jdpaxton
    The front P&J 1084 uncovered. What is the front covered P&J please. 1086 says for rear. Thanks
  15. ydopen
    ydopen
    Pete and Jakes front and rear on my A roadster. They make 2 lengths that will fit most uses.
    Ride quality also depends on spring flex. Spring needs to match weight and not stick.
    John
    NJ Don likes this.
  16. jdpaxton
    jdpaxton
    1 lowr shock bracket loose. Both shocks are not "smooth" when collasped. Stick in the collasped position and eventially extend. (Gas must still be there) Will be getting new P&J ordered after a short drive.
  17. NJ Don
    NJ Don
    P&J front covered shock # is 1086, same as rear covered. Same dampening front and rear. As "ydopen" says above the spring rate has a lot to do with the ride quality.
    Just Gary likes this.
  18. Airborne34
    Airborne34
    from Texas
    Does P & J make the 1086 in black vs the crome.
  19. krylon32
    krylon32
    from Nebraska
    1086 is a plain shock that comes in a silver color. 1086C is the number for a chrome shock.
    Airborne34 likes this.
  20. fastcar1953
    fastcar1953
    I used speedway 3 way adjustable shocks up front . coil over rear. helped a bunch. Set my front on #2 setting.
