Technical ???resharpen valve seat cutter
Discussion in 'The Hokey Ass Message Board' started by dhughens, Jul 1, 2025.
  1. dhughens
    dhughens
    Can this style of valve seat cutter be resharpened? If so, would you use a valve grinder, lathe, or some other type equipment? I have older USA made cutters and I see newer India made cutters. The ones I have are dull, they cut but just barely. I believe they were used for decades before carbides were available but I find it hard to believe they were throwaway pieces. The pics are new examples, not the ones I have. Again, can these type valve seat cutters be resharpened in a reasonable manner? cutter01.jpg cutter02.jpg
    tractorguy likes this.
  2. 302GMC
    302GMC
    from Idaho
    The first year I worked in a machine shop, the owner taught us how to sharpen everything in the shop. Ir's all in the quality of your files, and holding them right.
  3. FrozenMerc
    FrozenMerc
    302GMC is spot on. Yes they can be re-sharpened. The challenge is resharpening them without affecting the cutting geometry.
  4. Budget36
    Budget36
    I recall a friend of my dad who talked about sharpening files, if memory serves, they were put in some type of acid solution.
    I wonder if that would work for you as well?
    PS, I have the same style of seat cutters.
  5. Sharpone
    Sharpone
    I would check the local machine shops they may resharpen their own tools or have some outfit do it for them. There are many services for resharpening machine tools online.
    Dan
  6. Beanscoot
    Beanscoot
    I would imagine those are too hard to sharpen with files.
    In my machinist apprenticeship I sharpened lots of various cutters using a diamond wheel on a "tool and cutter grinder".
    You'd have to make a simple mandrel to hold those cutters in the machine's collet chuck.
    With labour rates at machine shops, it probably isn't practical to pay for the service.
    Here's a typical unit:
  7. xix32
    xix32
    I've only seen stones for grinding valve seats and valves, those can be "dressed" when they get worn.
    Sharpone likes this.
  8. TCTND
    TCTND
    As mentioned they could be sharpened with the right equipment, but those were meant for cutting the cast iron seats of the day. Even sharpened they'll have a challenge with hardened seats and won't last long.
    deathrowdave and Sharpone like this.
  9. Budget36
    Budget36
    The stone pictures is for hand cutting the seat, pilot goes through it, then (on mine) tighten a bolt on the bottom of the pilot and it expands and keeps it all centered.
  10. dhughens
    dhughens
    Thanks for all the replies. Seems like not really practical to sharpen and I don't have the equipment to do so.
  11. 31 Coupe
    31 Coupe
    Do you have access to a die grinder, preferable one with a 1/8" collet?
    If so you can carefully grind the front edge/face of each tooth ..... carefully because you must remove a very similar amount from each tooth face otherwise their diameters will be inconsistent.
    Unless they are chipped you only need to rub a couple of thou from each tooth face to get an improvement.
    Much like sharpening a HSS lathe tool.
  12. dhughens
    dhughens
    I do have die grinders as well as dremels, would you use a carbide cut off wheel to do this?
  13. Jagmech
    Jagmech
    I have used a tungsten carbide brake lathe bit to bring the edge back on reamer flutes, also try McMaster Carr for a diamond file, several types, the one I have will dress 65R steel, cost $100. Thin ones are available. Not Harbor Freight, good ones are expensive . If you want to buy a new cutter ,try Regis Manufacturing.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That equipment is called a Jack Mill. Ran one for several years in the saw room of a large cabinet manufacturing plant. That said, seek out a saw sharping shop, not a machine shop. Big difference in labor cost.
  15. Budget36
    Budget36
    Which size cutter is it? I may have, I two of quite a few of my set.
    And just for clarity, you are refacing the seats by hand? Ie not in a drill.
    Edit: I see yours screw on in place, mine fit on a taper.
  16. dhughens
    dhughens
    "Budget36"
    I have both styles in two different sets. I am trying to reface by hand and it takes extreme effort to cut the cast iron seats. It barely takes off any metal as they try to shave the seat. Five full minutes by hand with significant downward pressure gives at best .015-.020 cut surface. BTW, I do have a china clone RPM air gap for a sbm to sell but shipping would make it unreasonable. Look on ebay for one or an Edel Performer. Should be able to find one at any Stockton or Turlock car show/swap meet.
    "Johnny Gee"
    Good suggestion on looking for saw sharpening guy. Will try to find one. Thanks, dan...
  17. Budget36
    Budget36
    I’m not looking to purchase one, I thought I might be able to fix you up with a cutter.
