Projects A Michigan Model A build
Discussion in 'Traditional Hot Rods' started by Hot Rod Apprentice, Feb 4, 2022.
  1. Hot Rod Apprentice
    Hot Rod Apprentice
    Haven’t had a lot of progress on my coupe in the last couple weeks. My 3yo daughter on the other hand has switched from saying “daddy’s hotrod” to “our hotrod”. But with the school year winding down work has been very busy. We do go karts the last day for seniors. Every year I make modifications to make the our karts a little less high maintenance. Last year I installed cross steer steering linkages to wear tires less. This year I’m fabbing and installing chain tensioners so I won’t have to do chain adjustments anymore. Unfortunately I’ve been off for a couple days with a nasty sinus infection. I was going a little stir crazy so I masked up and ran up north to pick up a few vintage Mallory Distributors . IMG_5848.jpeg
    Outback, Deutscher and Jeff34 like this.
  2. HankAz
    HankAz
    How did you break the profile hammer? Just asking because I just cut one out and I might be better off cutting it out of 3/8ths to begin with. Also did you make the dies to make the body lines on the front of the cowl? Would like to see some pictures of them if you could.
  3. Hot Rod Apprentice
    Hot Rod Apprentice
    The profile hammer frame itself is fine in 1/4”. The driven arm seems to be the problem. I’ve made it in 1/4 and 3/8” both struggle. It keeps cracking an 1/8” below the weld. I messaged Carl Fischer on instagram asking if he had had any issues. He said “I’ve been able to keep together a quarter inch upper holder but you definitely have to gouge the corners out and really weld it”. I suspect the 16 gauge is pretty brutal. I think I may eventually mill an arm from tool steel. I made my front cowl in 4 stages. I started tipping the front lip with tipping pliers. Don’t use a metal brake, it’s not a straight line. Ask me how I know. I then did the narrow bead, followed by the joggle, then the joggle with the bead. I will post some pictures tomorrow of the dies.
    Outback likes this.
  4. HankAz
    HankAz
  5. Hot Rod Apprentice
    Hot Rod Apprentice
    IMG_5867.jpeg These are the profile does I used and abused to make my front cowl. It took several attempts to make one that I was happy with.
  6. Hot Rod Apprentice
    Hot Rod Apprentice
    Progress!!!
    I haven’t posted in a bit. Project car time has been limited between work, house projects, and taking care of family. Still have to ****on up the lower quarters and remake the lower trunk pan. Slowly but surely we are getting there.
    05snopro440, Stogy, Okie Pete and 7 others like this.
  7. Hot Rod Apprentice
    Hot Rod Apprentice
    IMG_6558.jpeg IMG_6559.jpeg IMG_7104.jpeg IMG_7111.jpeg IMG_7574.jpeg IMG_8062.jpeg IMG_8072.jpeg IMG_8070.jpeg IMG_8096.jpeg IMG_8097.jpeg
    Here is my past due photo dump. I haven’t posted much in the past year. It’s been one of those situations where toys often have to be put on the back burner. Family, work, and home ownership can often cut into “garage time”. Progress has been slow but my ‘31 has continued moving forward. In fact, so much so that I am now finally attaching body panels to the subrails. I had a buddy over to check my work and give me a
    second set of eyes before I locked everything down. Then I had my little inspector come out and share her thoughts. She just said “it needs to be loud”.
    I am very excited to move away from body work for a little bit and begin some ch***is work.
    My goal for the summer is to have a tack welded rolling ch***is come its end. I think I am right on par for end of August.
  8. Deutscher
    Deutscher
    from Germany
    You've done a great job, the Model A is going to be fantastic, and you're a great dad to a sweet girl.
    Keep up the good work, life has so much to offer.
    Greetings, Harald
    Hot Rod Apprentice likes this.
  9. Outback
    Outback
    from NE Vic, Oz
    Well done, my lil gurl loves our model A too! - The louder the better she says!
    Sounds like you are doing a good job with the juggle Resized_6E8CC782-_1719708486350.jpeg
  10. Deutscher
    Deutscher
    from Germany
    My daughter was born in 1993.
    Time has flown by so quickly.
    I always worked shifts.
    She's a young woman now.
    Where has the time gone?
    Have a wonderful time with your children. Oh... I'm getting sentimental, sorry.
    Greetings, Harald
  11. Jason Lemon
    Jason Lemon
    Just joined the page today. I live down in Battle Creek Mi. I have a 1930 Tudor. I haven't started anything yet due to trying to finish up my 71 F-100. Once I get that on the road I wanna start the A. Haven't decided on a direction for it yet though. Probably traditional, mild chop, leaning towards fenders, engine will either be a banger or flathead.
    Okie Pete likes this.
  12. Three97’s
    Three97’s
    from SE MI
    Wow, from a fellow Michigander, very impressive work. I just picked up an A Tudor a month ago, so I'll be following along!
    Outback and Okie Pete like this.
  13. Jason Lemon
    Jason Lemon
    Three97's. What city are you in?
  14. Hot Rod Apprentice
    Hot Rod Apprentice
    Lansing
    210superair likes this.
  15. Jason Lemon
    Jason Lemon
    get ahold of me if you need a hand or if you come down around Gilmore car museum. I am finishing up a different project and will be starting on my 30 ASAP!! I worked at the GM plant a few times. That's about 40 minutes from me here north of Battle Creek
  16. Hot Rod Apprentice
    Hot Rod Apprentice
    Thank you. I will keep that in mind!
    Outback likes this.
  17. Three97’s
    Three97’s
    from SE MI
    Brighton area, if it was really me you were asking, lol.
  18. Jason Lemon
    Jason Lemon
    I was. Do any of you Michigan guys plan to attend relix riot at Gilmore car museum in a couple weeks. I might try to get my other motor in my Tudor and try to get it moving to take there.
    Outback likes this.
  19. Hot Rod Apprentice
    Hot Rod Apprentice
    I’m trying go to Relix. It’s my favorite show in Michigan. I’ve got a pile of parts to sell and they usually have a pretty decent swap meet there too.
  20. Hot Rod Apprentice
    Hot Rod Apprentice
    Got it off the table a few days ago and mocked the axle in place.
    Today was three hours to remove two bolts. They were teasing me through the whole process. But my ‘63 Chevy 283 is mocked together with my S10 T5. Tomorrow we start on the front Hurst motor mount. IMG_8166.jpeg IMG_8169.jpeg IMG_8171.jpeg IMG_8173.jpeg
    Needless to say the 10mmx1.5 bolts are now 7/16NC.
  21. Deke
    Deke
    I'll be there In a black 37 Ford Coupe V860, I live 10 minutes from there and yea it's the best show around at the best location. Might even put on a reliability run on Friday for anyone interested in checking out the area and getting some beers!
    Dave
    Outback likes this.
  22. Jason Lemon
    Jason Lemon
    My car is still a project. I live about 10 min east of gilmore. I'll watch for you.
  23. Jason Lemon
    Jason Lemon
    Do you have a Model A or AA transmission bell housing?
  24. Hot Rod Apprentice
    Hot Rod Apprentice
    So although I have not made as much progress as I would like, progress has been made.
    The front axle has been tacked in place. I actually purchased the my drop axle a while ago from a reputable seller. More than a year later, I went to mock-up I could not get any of my dimensions to line up square. Come to find out my axle was twisted. I contacted the seller and they had me ship it back for them to repair. The seller apologized and reimbursed me for the shipping cost. Only cost me time. Once had a straight axle the wishbone mounts were able to be tacked in place.
    After the front axle was in position I began on the rear. Unfortunately I found that my Ford 9” axle was bent as well. Luckily a friend had a jig. I replaced the axle tubes with DOM and switched from the old style big bearing to the new style. widened the axle length from 55” to 57.5”.
    Originally I planned to used 35-36 wishbones and triangulate them to the transmission crossmember. Well that wasn’t going to work. They either interfered with the clearance between the frame and axle or the would interfere with the Z of the frame so we moved onto plan B. I had several sets of wishbones I had acquired over the years. I had a set of what I believe were 42-48 long and 46-48 short. Both having the same ends (Please correct me if I’m wrong).
    So a funky bracket was necessary. The bracket needed to allow for additional clearance for the leaf spring and provide a mount for the wishbone to compensate for the aftermarket bearing ends. I stumbled my way through CAD and sent some plans to the plasma table. They were cut from 3/8 plate and after several hours of welding, grinding, and using a needle scaler I have something that hopefully looks like it was forged.
    Originally I planned to run the long wishbones and still triangulate to the crossmember. But at the recommendation of a friend and knowledgeable builder who had a set of the long break in the past , I’m running the shorts. But… they don’t reach the transmission. Now I’m leaning towards parallel wishbones with a pan-hard rod. My other option would be a K member to anchor the wishbones.
    I will keep you posted.
    210superair, BigRRR, AHotRod and 3 others like this.
  25. Itchy
    Itchy
    Looking good.
    Hot Rod Apprentice and Outback like this.
  26. Outback
    Outback
    from NE Vic, Oz
    Can answer the long/short question.
    But a friend of mine has a 34 roadster & has 35/6 bones in the rear, after he had it on the road a year or so added a 3rd arm (torque arm) which went from the top of the diff forward to the pivot on the wishbone's & he was amazed at how much better it handled. It has a warm flatty, 4speed & early diff converted to open drive, he doesn't drive it hard.
    I have heard of those rear wishbone's (35/6) cracking/breaking if they aren't strengthened or have a 3rd arm. Just a thought
  27. Hot Rod Apprentice
    Hot Rod Apprentice
    Change of plan. Initially I wanted a bracket that would act as the spring hanger and wishbone mount. Figured it would be a nice clean look. Well due to the narrow model A frame that is not an option. So plan B; two separate brackets. Gotta make every hour count. IMG_9286.jpeg IMG_9287.jpeg IMG_9302.jpeg IMG_9303.jpeg
    210superair, Deutscher and jaracer like this.
  28. Hot Rod Apprentice
    Hot Rod Apprentice
    I’m a teacher and got a snow day. So I claimed an early morning in the garage before my daughter woke up. Decided to make my k-member holy enough for the church of speed.
  29. 210superair
    210superair
    from Michigan
    I'm about an hour south of you in Brooklyn. Hmu when it's done and we'll do a cruise...
  30. Hot Rod Apprentice
    Hot Rod Apprentice
    I look forward to it
