Technical Rust removal off chrome rims
Discussion in 'Traditional Hot Rods' started by Eth727, Jul 21, 2025.
  1. Eth727
    Eth727
    IMG_8349.jpeg Hey guys I tried using 0000 fine steel wool on my chrome rims but it didn’t remove this rust. Any recommendations? Thanks
    Sharpone likes this.
  2. Rickybop
    Rickybop
    Have you tried chrome cleaner?
    Works pretty good.
    If that doesn't take care of it...
    Soak them in a container of citric acid dissolved in water. Overnight, a day, two days, whatever it takes. It'll remove every molecule of rust and it won't hurt the Chrome at all.
  3. A fine 'toothbrush' wire brush with some chrome polish will work. The rust will come back, a heavy coating of wax will slow the process. I've also had decent results by lightly spraying some gloss aluminum paint over the area after getting as much rust off as possible with the wire brush, then using a cleaner wax to remove the excess paint, leaving just the paint-filled pits. It can be time-consuming...
    Pretty typical of Cragar SS wheels, or any chrome steel wheel with a welded-in center. The problem is these aren't triple plated, these are nickel/chrome, lacking the copper 'sealer coat'. This is done because the copper will contaminate the welds.
    Sharpone and hotrodjack33 like this.
  4. Kiwi 4d
    Kiwi 4d
    I know this doesn’t help your situation. But I had a set of new American racing chrome smoothies sitting in a shed maybe 3 years that went rusty before I even got to use them. Frustrated I got them stripped and powder coated.
  5. Sharpone
    Sharpone
    Soak with Gibbs oil let sit for a day or so then wipe with a soft rag, maybe do Gibbs 2 or 3 times then use Turtle Chrome cleaner, then a good wax.
    Dan
  6. Eth727
    Eth727
    Oh by the way I’m too lazy to remove the rim
    Bandit Billy likes this.
  7. Budget36
    Budget36
    Heard many mention using tin foil and soapy water, ball of the foil and scrub.
    Also heard not to use steel wire brushes or steel wool as steel rusts.
    Personally I’d leave as-is, because I recall you are using aged tires.
    Once the tires are off do as @Rickybop said, put the wheels in CA mix.
    I posted up results of doing the CA mix on old chrome backing plates, still look good, took two treatments, as the light rust that was left came back, but after second soaking, still good.
    I’ll see if I can find my thread.
    Edit: Here it is with 8x10 color, glossy photographs, but no writing on each one;
    https://www.jalopyjournal.com/forum/threads/citric-acid-mix-on-chrome-it-works.1332821/
    shart1079 and Sharpone like this.
  8. Bandit Billy
    Bandit Billy
    My daughters OT PU has factory chrome wheels and are rusted in the same spot as the OP's. You can clean off the rust but it will return fairly fast. I plan to clean them again, and paint that area with a contrasting paint that matches the stripes on her truck. Likely a grey metallic. I think it will look good and far less than refinishing them. I don't know how that would look on cragars though.
    reagen and Sharpone like this.
  9. Kerrynzl
    Kerrynzl
    Scrunch up some aluminum foil into a ball.
    Then use a solution of water and vinegar (10-25%)
    Scrub away until there is a bit of heat from friction.
    The foil is soft enough not to scratch, and the vinegar (acid) and friction creates a galvanic reaction and "plates* aluminum into any pitting.
    Try it ....... it works
  10. squirrel
    after a while you'll get used to the rust, and you won't notice it.
    Nothing will put the chrome back on, so don't worry about it too much. They're old wheels. Enjoy them for what they are.
  11. GuyW
    GuyW
    Use any type of oil with your steel wool.
  12. twenty8
    twenty8
    My vote too.
    Just Gary and Sharpone like this.
  13. I have used the aluminum foil trick, but used Coke (the black one) and it took the rust off and left a dull grey coating. This, and oil stain removal on concrete is what I do with the black poison.
    rattlecanrods, Sharpone and twenty8 like this.
  14. Doublepumper
    Doublepumper
    from OR-WA, USA
    It's the loosened rust that scratches the good chrome. The foil (or steel wool), will pick it up and hold it...and scratch the chrome. Using acid to remove the rust first will help with that.
  15. JD Miller
    JD Miller
  16. Bandit Billy
    Bandit Billy
  17. Eth727
    Eth727
    I’m surprised nobody has mentioned Coca Cola. I ain’t wasting a can if it doesn’t work.
  18. twenty8
    twenty8
    It has been. Have you been reading the replies...?
    Slopok, Sharpone and Budget36 like this.
  19. captaintaytay
    captaintaytay
    What happens if you get a flat?
  20. 29Sleeper
    29Sleeper
    from SoCal
    In some of the heavy areas it looks like the chrome has flaked off. This happens just like when rust makes bubbles in paint. Don't use steel wool on chrome. Little pieces of steel embed themselves in the chrome and cause rust. Get some Bronze Wool - the finest you can find. Then use that and Br***o to clean them up. For rusty areas that have lost their plating you can touch them up with some silver or chrome paint. It hides it pretty well for the casual observer.
  21. RodStRace
    RodStRace
  22. jimmy six
    jimmy six
    The nemesis of the safety bead rim. Even new ones today. Wipe at least once a week and heavy on the paste wax..
  23. I used tinfoil to clean aquarium gl***, doesn't scratch gl***.
    I used the same tinfoil with coca cola to clean the stainless on my 50 coupe, worked great!
  24. vintage colors
    vintage colors
    Evaporust would do it, the trouble with it would be the tire would have to be off an tub big enough for the rim to lay in is needed . I would try the aluminum foil/vinegar mix
  25. kracker36
    kracker36
    Concrete / metal etch from Home Depot
    ( phosphoric acid ) .. dilute 4/1 with water and scrub with fine steel wool. Then rinse with water and apply a wax
