Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Bandit Billy
    Bandit Billy
    That looks to be a nice little hot rod your playing with.
  2. IMG_9662.jpeg IMG_9663.jpeg IMG_9652.jpeg When we were at Bowling Green last month, I scored a set of 15x7 Aluminum Slots for $150. Someone had sandblasted them and I’m in the process of sanding them out. I don’t want polished aluminum, I’ve ridden Harley Davidsons for almost 30 years and hate maintaining it, just a smoother finish than what’s on there now. I believe these will look nice on Papaw. I also swapped the 600 Edelbrock for a Quadrajet. It runs better all over and makes that glorious Q-Jet music when I kick it in the ***.
    sixty3, 6inarow, Stock Racer and 13 others like this.
  3. Kosmos55
    Kosmos55
    Finished putting the grille in.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    New power supply wires for a Logan 820 lathe IMG_4360.jpeg IMG_4361.jpeg IMG_4362.jpeg
  5. saltflats
    saltflats
    from Missouri
    Well made it this far on the crossmember project. Having some trouble with my tig welder I need to figure out. Seems to what to run too hot or not hot enough. Maybe the amptrol.
  6. patsurf
    patsurf
    better go into manufacture w/ a jig that nice!
  7. saltflats
    saltflats
    from Missouri
    Does look like the amptrol has a problem. The little white gears are not secured to the shaft of the rheostat.
    Could be an interesting fix.
  8. patsurf
    patsurf
    how many wires go to it?
  9. BigRRR
    BigRRR
    Spent day repairing rotted soffits on the house and then Tonight worked in some free time to slice and dice some flat stick to create curved ends for a frame to mount my grill pieces. I dissected a mercury grill to straighten and lengthen it … IMG_2577.jpeg IMG_2840.jpeg
  10. saltflats
    saltflats
    from Missouri
    It's a 5 wire with 2 different plugs. Old Lincoln 300/300.
  11. patsurf
    patsurf
    is there a way to use only three and put a generic rheostat on it or can you buy one on ebay?
  12. saltflats
    saltflats
    from Missouri
    No it needs the 5 wires to work. I'll look into fixing this one first. It went together it has to come apart so should be able to fix it.
    Dick Stevens and deathrowdave like this.
  13. CruznArt
    CruznArt
    from Germany
    Currently working on this one.
  14. Clydesdale
    Clydesdale
    Made a start on the Nose and Deck job on my ‘51.
    Kinda wanna lose the ornament but keep the hood seam trim, need to figure out a way to get a bullnose trim over to Scotland without either needing a second mortgage for the shipping or it arriving folded into a useless ball :(
    Also filled in the holes where the backup lights used to be
    pila38, 61Cruiser, Sharpone and 9 others like this.
  15. saltflats
    saltflats
    from Missouri
    Got the amptrol working. Guess I'll see how long it works. I used some super glue to hold the little gears in place a secured to the shaft.
  16. squirrel
  17. deathrowdave
    deathrowdave
    from NKy
    Mr Squirrel that front suspension has lots of moving parts . Keeping it lubed well is a great thing to practice .
    osage orange and Sharpone like this.
  18. atch
    atch
    Jim,
    I was having a hard time understanding the steering setup looking at your pic. So I googled a diagram of it. That's a quite interesting geometry.
    Does it handle well?
    Sharpone likes this.
  19. squirrel
    It's just like a 49 Chevy. It handles fine, compared to my old truck....
  20. patsurf
    patsurf
    worked well enough they kept it almost 15 yrs--or more likely the general was being cheap!
    squirrel and Sharpone like this.
  21. swade41
    swade41
    from Buffalo,NY
    I gave the tire s****s and me a workout in the sweltering outside heat, mounted the slicks and tubes for the Henry J.
    I still need to change the antifreeze out for water but the next cooler Tuesday I'll drag it out for test n tune and see if it goes straight and stops at the big end.
    Okie Pete, pila38, rod1 and 9 others like this.
  22. deathrowdave
    deathrowdave
    from NKy
    Brother you made the best move you possibly could have from drivability, the QJet is King
    Robdski, Stock Racer and Sharpone like this.
  23. Thank you Dave! The drivability is much better all over and it has more power as well. The Edelbrock had its signature hot start issue and the Quadrajet fixed that too.
  24. Stock Racer
    Stock Racer
    Enjoying another hot summer evening and making some progress on my 327
  25. saltflats
    saltflats
    from Missouri
    Got a chance to visit the 62 biscayne project this afternoon. Got the inner fenders installed and the front clip aligned and some of the front sheet metal installed. Still a bit to do but progress is progress.
  26. 31Apickup
    31Apickup
    My projects have come to a complete halt, but the good thing we bought a different house and it has a huge shop. Busy moving all my stuff. IMG_4174.jpeg
  27. patsurf
    patsurf
    wow!
    osage orange, porkshop and Sharpone like this.
  28. choptop40
    choptop40
    Turbo 400 acquired and mocked up with tubular cross member..no modifications to floor or tunnel PXL_20250730_173345430.MP.jpg
    Okie Pete, Oneball, pila38 and 6 others like this.
  29. chevyfordman
    chevyfordman
    Thought it would be a good idea to try and make the radiator cap look a little better. IMG_3001.jpeg
  30. Sharpone
    Sharpone
    IMG_3332.jpeg IMG_3329.jpeg Built a yo yo shifter knob for a B&M Unimatic, made a shifter cable mounting bracket. Cleaned up the unimatic, also ground deeper notches on the Drive and Nuetral detents . It feels a little better, not as easy to shift into N or R. Working on making a physical reverse lock out. Most likely a bar or rod located at the lever to keep shifter from engaging reverse. Is physically locking out neutral a good or bad idea? It would be nice not to worry about hitting neutral under full acceleration.
    Dan
