Technical Electric fuel gauge jumping around. Fixed. Update in OP
Discussion in 'The Hokey Ass Message Board' started by ActionYobbo, Jul 22, 2025.
  1. ActionYobbo
    ActionYobbo
    I converted my 39 ford truck over to 12v and the fuel gauge shows the correct level when sitting still at idle but if I rev the engine any the needle fluctuates. When I am driving the fuel gauge needle looks like a miniature windshield wiper. I used a sender unit from a 90’s ford the was the right depth for my tank and was the correct resistance range for the new gauges. The gauges are repro smiths made in India. I have used these brand/makers gauges on my tractors when I converted them to 12v but this is the first fuel gauge I have used. I have the temp oil and volts gauges on the tractors and truck (they work with out any problems when they have the correct sender/sensor)
    On the 39 ford truck I used the generic GM style wiring harness that has the alternator run to the fuse block then to the battery. Power for the gauges comes from the same fuse block.
    update.
    Got it working.
    After rewiring the dash and trying a bunch of ideas and suggestions the one that fixed it was running a ground from the sender unit to the ground lug on the frame rail. All my grounds are wired back to the battery. I am not relying on rusty panels to make a good ground. So in theory the sender is now grounded to the gauge
    Toms Dogs likes this.
  2. squirrel
    does it look like the gauge is showing the fuel sloshing in the tank? like it doesn't have enough damping?
    Just Gary and Johnny Gee like this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Looking forward to info on this. Auto Meter does this.
    seb fontana likes this.
  4. ActionYobbo
    ActionYobbo
    Possibly when it’s going down the road but when is sitting still the gauge moves with the engine speed
  5. squirrel
    What does a volt meter say about your system voltage when you rev the engine?
  6. pprather
    pprather
    Does this have to do with the original King Seely gauge and sending unit?
  7. ActionYobbo
    ActionYobbo
    I have a digital volt meter direct off the battery it sits at 12.7 engine on or off and I have a voltmeter in the dash that the needle points at 12 with the key on and 14.5 with the engine on. I have seen the needle move up to 16v a few times while the digital gauge stays at 12.7
    this is a new build with all new wiring for everything. All grounds are hardwired back to the battery. On the firewall there is a ground strap bolted on the outside and on the inside of that same bolt is the grounding point for all the wiring inside the cab. There is also a ground wire from that lug that goes to the rear lights. It’s lugged on the frame rail near the fuel tank and the fuel sender is grounded to that lug. So everything is directly grounded by wire to the battery. No relying on rusty metal for grounding.
  8. finn
    finn
    Sounds like perhaps he isn’t running a voltage regulator in the system and voltage changes with rpm.
  9. 19Fordy
    19Fordy
    If you are using the OEM King Seely gauge your set up will not work accurately as the OEM King Seely gauge
    only works with the OEM King Seely gas tank sending unit. They both operate on heating a bi-metallic spring inside both units NOT on the OHMS LAW Principle. This is discussed at length on Fordbarn.
  10. squirrel
    something is wrong. it's not charging the battery, is it? The battery voltage should be close to the voltage on the rest of the system.
    How is the alternator output connected to the battery?
    Tickety Boo and Johnny Gee like this.
  11. ActionYobbo
    ActionYobbo
    you missed the bit where I said the gauges are 12v reproduced made in India
  12. ActionYobbo
    ActionYobbo
    Alternator is a GM 10Si internally regulated. The output wire goes to the power distribution panel aka fuse panel then to the starter solenoid then the battery. This is supposed to be GM style of wiring according to the instructions that came with the 21 circuit universal harness. All I have running off the power while I have been driving is the ignition coil and the dash gauges unless I have my foot on the brakes
  13. squirrel
    but is there really 2 to 4 volts difference from the alternator to the battery when it's revved up?
    Tickety Boo likes this.
  14. ActionYobbo
    ActionYobbo
    The problem only happens with the engine running. With the key on/engine off the fuel gauge gives a constant reading of 1/2 full which is what’s in the tank. I can bounce the truck around and the gauge says at 1/2 but as soon as I start the engine the gauge goes crazy.
    I will check the alternator output and I will disconnect the output wire from the alternator and run a new wire straight to the battery and see if that makes a difference.
    Toms Dogs and rattlecanrods like this.
  15. Has it always done this or a new issue? A good test would be to disconnect the alternator output wire to fuse block and run a jumper from the alternator to the battery and then another jumper from the solenoid/battery connection to the fuse block wire. That would make the battery the damper point and supply a more consistent voltage to the fuse block.
  16. squirrel
    no need to disconnect wires, just make sure there is a good path from alternator output to the battery. If it goes through an ammeter, make sure the ammeter is actually able to carry the current (this was a big problem with Mopars in the 60s-70s due to wiring and ammeter failures)
    Tickety Boo and Pist-n-Broke like this.
  17. ActionYobbo
    ActionYobbo
    It’s a new build with new wiring new alternator new gauges new battery
  18. Me thinks the gauge just wants a GOOD ground.
    Ben
    Kerrynzl, Jack E/NJ, Paul B and 2 others like this.
  19. Doublepumper
    Doublepumper
    from WA-OR, USA
    A picture is worth a thousand guesses...indeed.
    If the alternator is working properly, and voltage isn't fluctuating while it's spinning, there may be some inductance into the fuel sender circuit, possibly from being next to a high voltage source, like a plug wire...?
  20. ActionYobbo
    ActionYobbo
    Today’s test. I disconnected the wires for the alternator and went for a drive. Fuel gauge showed just under half a tank. Did not fluctuate for bumps or stopping suddenly. I have not run a wire from the alternator to the battery. That would involve cutting into the wiring harness which I am reluctant to do after spending hours wrapping it.
    Tested the alternator output. Off it’s 12.7 from the battery. Idle it’s 13.8 and 2000rpm it’s 14.7 the battery stays at 12.7
    from the picture I have the battery word going to thd fuse panel and the ign/acc wire going to the idiot light.
  21. squirrel
    you need to connect the alternator output to the battery!
    winduptoy and jaracer like this.
  22. 2OLD2FAST
    2OLD2FAST
    from illinois
    Running a wire to the starter post works on most wiring , if that's closer .
  23. ActionYobbo
    ActionYobbo
    It’s a 39 ford with the battery on the firewall and the starter solenoid under the battery.
    The 2 red wires at the alternator are crimped in 1 terminal and to separate them I would have to cut into the harness wrap.
    I used this (see pic) 21 circuit wiring harness and it’s pre wired for the alternator to feed the fuse block power distribution bar with another wire from the other end of the power bar to the battery.
  24. pprather
    pprather
    Run an unbundled wire, as needed, to see if the fix you discovered works.
    If it works, you seem to know what comes next.
    warbird1 likes this.
  25. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Something to consider, bad grounds can cause electric feedback. May try grounding the tank to the battery with a jumper wire and see if that helps?
    I bought a new Stewart Warner fuel gauge and it never read right, so I got tired of the weird readings, took the gauge out, pulled the second nuts holding the back cap on the gauge, and found the cap was touching one of the terminals, Yep that will do it. Now it reads right all the time.
    Jack E/NJ, Toms Dogs and 2OLD2FAST like this.
  26. manyolcars
    manyolcars
    Doesnt that cause the engine to continue running after the ignition is turned off?
  27. squirrel
    No, they have diodes in the alternator...
    Tickety Boo and 2OLD2FAST like this.
  28. ActionYobbo
    ActionYobbo
    Did the rewire of the alternator. Now have the alternator direct to the battery cable clamp at the + post. The fuse panel wire now starts at the battery side of the starter solenoid. Made no difference to the fuel gauge. Still reads good while driving with battery only and flips and flaps with the alternator hooked up. In my research I have seen references to an instrument cluster voltage regulator. So thats my next move if I can find a small 12v output regulator.
  29. 2OLD2FAST
    2OLD2FAST
    from illinois
    I believe you stated that you had seen 1- v from the alternator ? That means there may be a fault in the alternator .. Ford used to have a CVR ( constant voltage regulator)
  30. jaracer
    jaracer
    Okay, it is possible that the alternator has a diode problem and you may be seeing a stray AC signal (ripple) coming from it. The quick way to test involves a scope however, you can set a voltmeter to AC and connect it from the alternator output terminal to battery ground. A reading of over 0.5 volts suggest there is a diode problem in the alternator. Don't know if that is your problem, but it is a possibility.
