Technical Remote reservoir for stock master cylinder
Discussion in 'The Hokey Ass Message Board' started by 55willys, Jan 5, 2017.
  1. 55willys
    55willys
    This all started when I got a 55 Willys wagon. I learned right away that the master cylinder was near impossible to fill from the top and you can't see how much is in it when filling from the bottom without a mirror. I wanted to put a remote reservoir on to it to make it easier to fill. The choices I found were either billet aluminum or plastic and that looks completely out of place under the hood of a vintage car.
    I have built many hot rods professionally and run into the same problem of hard to access master cylinders under the floor. For the Willys I got an FC170 (Forward Control) master cylinder cap as these cab over trucks had a remote reservoir mounted to the dash. The first thing I saw was that the fitting was recessed into the cap and held lots of debris around the threads. I also needed a can for the reservoir and I found a place that sells cans with delta thread caps. Basically the type of can you get pvc glue in. I also found a vented cap that would screw on.
    In the end I had a rubber bellows in the top to separate the brake fluid from the atmosphere, a stainless barbed bulkhead fitting in the bottom of the can, and I sourced reproduction master cylinder caps that I modified to accept a 1/4" barbed fitting. After doing this for mine I thought that it would work on almost anything that had the master cylinder under the floor. I started to do some research into what master cylinder cap sizes there were. The Willys uses a 1-5/8" cap, Ford uses a 1-1/4" cap, Mopar and GM both use a very strange thread 3/4x18. GM also uses 1-1/4" caps on their trucks.
    So seeing a need I filled it, here are some pictures and contact info can be found in my signature below or you can PM me.
    IMG_20161015_145149593.jpg IMG_20161015_145544726.jpg IMG_20161015_150249481.jpg IMG_20161015_150355684.jpg
    Tim and Los_Control like this.
  2. 55willys
    55willys
    I will be at the 4x4 swap meet at the Puyallup Fairgrounds this Sunday the 12th and at the Almost Spring swap meet the weekend of the 18-19 also at the same location. If you are interested in these you can catch me at the swap meet or click on the link below in my signature file.
  3. bangerbob
    bangerbob
    I need this kit for a 48 ford reservoir
    Grisbobsue@juno.com
    Sent from my SM-J327P using The H.A.M.B. mobile app
  4. 55willys
    55willys
    I am at the Almost Spring swap meet at the Puyallup Fair grounds selling today. You can buy them from my website highway101ind.com , I have master cylinder adapter cap's to fit most master cylinders. You will need to know the size of master cylinder cap and what size reservoir you want to run, 4oz or 8oz. You can call me at 360-536-1441 if you have any questions.
  5. 55willys
    55willys
    I have upgraded some of the parts in theses kits. The bottom fitting is now adaptable to either 1/4" hose or 1/4" hard line. The master cylinder caps are now custom machined and accept an 1/8" pipe thread. It comes with a straight 1/4" hose fitting but we can subs***ute a 90° fitting at no additional cost. Don't put plastic on your vintage hot rod or cl***ic car.
    highway101ind.com
    Tim, Bowtie Coupe and tb33anda3rd like this.
  6. Sandman614
    Sandman614
    The website is still live but no products are showing. Curious if you still sell them?
  7. gimpyshotrods
    gimpyshotrods
  8. 55willys
    55willys
    Yes, but still need to put my website back together. What size do you need?
  9. gimpyshotrods
    gimpyshotrods
    The aforementioned, shown in-place:
    kadillackid likes this.
  10. Sandman614
    Sandman614
    Glad to hear it!! A 4oz reservoir for clutch and a 16oz dual outlet for brakes would be perfect.
  11. 55willys
    55willys
    I have 4oz and 8oz they discontinued the 16oz. I can offer a dual outlet 8oz.
  12. pprather
    pprather
    Dual 8oz should be big enough for an automotive size master cylinder.
    Sandman614 likes this.
  13. Sandman614
    Sandman614
    Sounds like a dual outlet 8oz will be good then. Plus the 4oz for the clutch.
  14. 55willys
    55willys
    Most master cylinder chambers are about 4oz and if you use a master cylinder like a 78 Corvette you will add to the already large volume of fluid. PM me and we can work out what you need.
    Sandman614 and Tim like this.
